+ Post New Thread
Page 102 of 121 FirstFirst ... 2 52 92 100 101 102 103 104 112 ... LastLast
Threads 3031 to 3060 of 3628
Forum: Pool Equipment & Operations
Pumps, pipes, filters, lights; covers, valves, heaters, coolers; filling and draining . . .
  1. Sticky Thread Sticky: How Much Does Pump Efficiency Matter?
    ___________________________________ How Much Does Pump Efficiency Matter? ___________________________________ TL;DR: The difference in...
    Started by PoolDoc‎, 06-23-2018 09:02 PM
    06-23-2018 09:02 PM Go to last post
  2. Sticky Thread Sticky: FAQs & Guides: Pool Equipment & Operations
    ____________________________________ FAQs & Guides: Pool Equipment & Operations ---- June 2018 ---- ____________________________________ ...
    Started by PoolDoc‎, 06-19-2018 05:06 PM
    06-19-2018 05:06 PM Go to last post
  3. Sticky Thread Sticky: Need advice regarding cartridge filter...
    I've spent the last three years (yes, that's THREE) rebuilding my existing pool that was originally built in the mid 50's. Lots of problems, lots...
    Started by otisdog‎, 05-23-2014 03:45 PM
    05-29-2014 10:38 AM Go to last post
  1. Return Eyeballs
    Does anyone know where I can purchase adjustable eyeballs for my returns? I need to divert the water some, and haven't found any place local that...
    Started by md_rider‎, 07-06-2006 10:24 AM
    07-06-2006 12:54 PM Go to last post
  2. Question about lights...
    My light only comes on for a flicker, then the GFI pops. Is it likely to assume a bad GFI or is the light more likely to blame? I took the...
    Started by mariner09‎, 06-15-2006 06:12 PM
    07-06-2006 12:40 PM Go to last post
  3. Old Pool Pump--high electric bill
    I have seen some of the back posts about power consumption. I have an old pump wired at 220 (7.4amps) and my electric bills are high. I do not have...
    Started by Metolius‎, 07-06-2006 12:26 PM
    07-06-2006 12:26 PM Go to last post
  4. Low salt light "ON" on my Pentair SWG
    I have the Pentair IntelliChlor SWG. The unit has been in use about 2 months now (although I bought it before my pool was dug so it is technically...
    Started by mshumack‎, 05-30-2006 02:44 PM
    07-06-2006 11:52 AM Go to last post
  5. Is my pump too big for my filter?
    I've been lurking and reading through all the posts on this site for a couple of weeks. This is our 3rd season with a pool and I am just now able...
    Started by AndieP‎, 07-05-2006 02:41 PM
    07-06-2006 12:29 AM Go to last post
  6. New pump, 2 speed???
    I currently have a Jandy stealth 2.0hp pump that has become very loud, I beleive it has been compromised but still pumps water well. Before I have...
    Started by Pinman24‎, 07-05-2006 01:54 PM
    07-05-2006 10:38 PM Go to last post
  7. Picture of S 244T Hayward Valve Control?
    Almost finished installing used pump and filter but just realized the plastic sticker on top for valve control positions is missing. Does anyone...
    Started by LennPrice‎, 06-01-2006 12:39 PM
    07-05-2006 09:09 PM Go to last post
  8. anyone have time trippers from intermatic timer they will sell to me?
    hard to get unless you're a wholesaler it seems..these are the newer ones that have a gold colored on, silver colored off. there is a guy on ebay.com...
    Started by tenax‎, 07-01-2006 12:03 PM
    07-05-2006 07:26 PM Go to last post
  9. Skimmer suction
    How much suction should I see at the skimmers? I have two, with a 2hp pentair whisperflow pump. I have this new problem with unknown bugs :(...
    Started by rpoldervaart‎, 07-05-2006 03:15 PM
    07-05-2006 04:06 PM Go to last post
  10. Question How do I determine the minimum time to run my filter daily?
    How long do I run my filter to turn over the pool water one time? My manual doesn't say. Under "Specifications", it states that the design flow...
    Started by 4KidsSwim‎, 07-05-2006 01:38 PM
    07-05-2006 01:38 PM Go to last post
  11. What PSI should a filter run at?
    I have a Star DE-50 filter and a Dynamo 1hp pump. I also have an automatic chlorinator hooked up between the filter and the return. My filter...
    Started by denanbob‎, 07-05-2006 01:20 PM
    07-05-2006 01:31 PM Go to last post
  12. Hayward filter air sound
    I can hear air in the top of my filter- also little bubbles come out of the jets. I took off top valve cover today and re-sealed- nothing changed. My...
    Started by Madty‎, 07-04-2006 11:43 PM
    07-05-2006 12:33 PM Go to last post
  13. Plumbing Questions - changing from sand to de filter
    Have a 27' round AGP with a 3/4 Hayward Power Flo LX with a top discharge and a sand filter. I want to change to a de filter. I have noticed that...
    Started by let_her_flicker‎, 07-04-2006 08:59 PM
  14. Unhappy Who turned out the light?
    When I moved into my house with a pool, I noticed the light had water in it and didn't work. I didn't get around to checking it out for months but...
    Started by shadowman‎, 07-05-2006 12:30 PM
    07-05-2006 12:30 PM Go to last post
  15. Help! Losing h20
    I have a vinyl pool linear and I am losing about 3 inches of water/day out of the pool. At first I thought it was just evaporation because it's been...
    Started by timthompson‎, 07-03-2006 10:07 PM
    07-05-2006 11:42 AM Go to last post
  16. Resources for bulbs
    Can anyone recommend some good resources for replacement bulbs? I have a Hayward fixture that takes one 500W type R-40 bulb. One store said it would...
    Started by KirstenHW‎, 07-03-2006 09:59 AM
    07-05-2006 11:29 AM Go to last post
  17. Anyone know a website that has a diagram or pics of ground mounted solar panels?
    My wife and I would like to add solar heating to our IG 30k gallon pool. The filter and pool are approximately 50-60 feet away from the house, so I...
    Started by Timmy‎, 06-30-2006 08:15 AM
    07-05-2006 08:41 AM Go to last post
  18. Zodiac Clearwater Chlorine Generator maintanance chore
    I have a Clearwater salt system chlorine generator which needs attention on a daily basis. The cell unit is full of what seems to be calcium...
    Started by poolaris‎, 06-11-2006 12:03 AM
    07-04-2006 11:41 PM Go to last post
  19. Moved: how do i backwash
    Started by dawny5‎, 09-08-2006 10:09 AM
    07-04-2006 08:30 PM Go to last post
  20. pool lighting/electrical question
    This is the first summer I've been at my new house which has a pretty old above ground pool. The pool has a light which just has a cord that runs...
    Started by ryanm‎, 07-01-2006 12:19 AM
    07-04-2006 06:04 PM Go to last post
  21. Diving Board Purchase
    We need to purchase a replacement diving board, 6 feet long, and I'm looking for a recommendation to an on-line source. Local stores seem...
    Started by stlouis123‎, 07-04-2006 04:02 PM
    07-04-2006 04:02 PM Go to last post
  22. Priming the pump?
    What does that mean? I have a Dynamo 1hp pump, and a Star DE filter. As soon as my water level is 1/2 way up the skimmer, I was going to just flip...
    Started by denanbob‎, 07-03-2006 08:53 PM
    07-04-2006 11:58 AM Go to last post
  23. Couple more questions about sand filter maintenance
    There's a 1/2" PVC drain pipe at the bottom that is capped. Do sand filters ever 'need' to be drained as part of regular maintenance? I don't want to...
    Started by aquarium‎, 07-04-2006 10:03 AM
    07-04-2006 11:48 AM Go to last post
  24. Question Water won't go through skimmer
    We inherited an old pool but bought a new skimmer and installed it because it was cracked. The water was sucked through from the pool but only at a...
    Started by poolcat‎, 07-02-2006 02:10 PM
    07-04-2006 09:21 AM Go to last post
  25. Pump/motor oddity
    I switched off the pump to add tabs to the chlorinator. It was running just fine. Filled the chlorinator, switched the pump back on and ...nothing....
    Started by hoosier56‎, 07-03-2006 08:58 PM
    07-04-2006 09:05 AM Go to last post
  26. no expert but i'll challenge that blue vs clear solar cover notion
    notion i'm referring to is that a blue or opaque cover will not transfer heat to a pool, but only retain heat. i was buying that idea until today...
    Started by tenax‎, 07-03-2006 06:37 PM
    07-03-2006 09:55 PM Go to last post
  27. Advise on good solar reel. Heavy Duty.
    I have a 18 x 40 oval above ground with a bubble solar cover thats heavy. After three days of unrolling it up and out by hand, I realize I need a...
    Started by Aranon‎, 06-11-2006 10:29 PM
    2 Pages
    1 2
    07-03-2006 08:54 PM Go to last post
  28. Pre-mix DE Filter Media?
    Hi All, I installed a new Hayward Pro-Grid Vertical DE4820 this year and after backwashing and adding DE filter media (6 lbs. each time) four...
    Started by jc8988‎, 07-02-2006 10:50 AM
    07-03-2006 07:53 PM Go to last post
  29. Question Which solar cover is best
    Can anyone recommend a solar cover. I have bought several and I am lucky to get one to last more than a year. The heavy ones don't seem to last any...
    Started by opsman‎, 07-03-2006 07:57 AM
    07-03-2006 02:47 PM Go to last post
  30. Potentially dangerous electrical problem?
    Strange and potentially dangerous problem…I think. About a week after opening our pool the pool light started tripping the GFI switch. I would turn...
    Started by pabolden‎, 06-29-2006 02:39 AM
    07-03-2006 01:50 PM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
