+ Post New Thread
Page 1 of 121 1 2 3 11 51 101 ... LastLast
Threads 1 to 30 of 3628
Forum: Pool Equipment & Operations
Pumps, pipes, filters, lights; covers, valves, heaters, coolers; filling and draining . . .
  1. Sticky Thread Sticky: How Much Does Pump Efficiency Matter?
    ___________________________________ How Much Does Pump Efficiency Matter? ___________________________________ TL;DR: The difference in...
    Started by PoolDoc‎, 06-23-2018 09:02 PM
    06-23-2018 09:02 PM Go to last post
  2. Sticky Thread Sticky: FAQs & Guides: Pool Equipment & Operations
    ____________________________________ FAQs & Guides: Pool Equipment & Operations ---- June 2018 ---- ____________________________________ ...
    Started by PoolDoc‎, 06-19-2018 05:06 PM
    06-19-2018 05:06 PM Go to last post
  3. Sticky Thread Sticky: Need advice regarding cartridge filter...
    I've spent the last three years (yes, that's THREE) rebuilding my existing pool that was originally built in the mid 50's. Lots of problems, lots...
    Started by otisdog‎, 05-23-2014 03:45 PM
    05-29-2014 10:38 AM Go to last post
  1. OG stairs
    Hello, we have an above ground pool with a PT deck on the end, at this time, we have a ladder(tubular sides) that mount thru a hole into the deck. I...
    Started by Barry J‎, 04-11-2024 10:42 AM
    04-11-2024 10:42 AM Go to last post
  2. Hayward S210T
    I bought a Hayward S210 filter last Friday and installed it. When I turned it on it had a small leak on top of filter. From what I read it might be...
    Started by Barry J‎, 08-14-2023 09:51 AM
    08-14-2023 09:51 AM Go to last post
  3. Jacuzzi laser sand filter
    I have a Jacuzzi Laser sand filter, Model 190L, it is about 25 years old. I have developed a pin hole leak in the body itself, and attempting to seal...
    Started by Barry J‎, 08-10-2023 07:20 PM
    08-10-2023 07:20 PM Go to last post
  4. Jacuzzi laser sand filter
    Started by Barry J‎, 08-10-2023 07:03 PM
    08-10-2023 07:03 PM Go to last post
  5. Lubricant Types
    Hi All. I am going to install a couple of New Diverters on my J350. To help them rotate a little easier/smoother, I plan to lubricate them with...
    Started by pratzert‎, 04-07-2023 01:11 PM
    04-07-2023 01:11 PM Go to last post
  6. Pentair Intellibrite 5G
    I upgraded our pool light to LED 4 years ago and we decided to go with the Pentair Intellibrite 5G. Unfortunately, it stopped working a couple of...
    Started by matthewnadeau‎, 11-02-2022 02:16 PM
    11-02-2022 02:16 PM Go to last post
  7. Partial drain over two days?
    My pool pro says I need to drain half the water in my pool and refill with new water. Half the water is about 7,500 gallons. I don't want to run...
    Started by johninmartinez‎, 07-28-2022 04:51 PM
    07-30-2022 03:32 PM Go to last post
  8. Why can't I find the proper replacement basket for my Jacuzzi J-VSP 250 pump?
    Help. I am trying to find the correct basket for my Jacuzzi pool pump. Everything I have found seems to have different dimensions. Is the Jacuzzi...
    Started by itybitybob‎, 05-07-2021 05:59 PM
    07-01-2022 03:14 PM Go to last post
  9. Green Layer on Pool Floor (probably dead algae)
    Hello all. I cannot get rid of fine layer of what i think is dead algae on inground pool. About 25k gallons. Have a sta rite 3 sand filter....
    Started by fhorta‎, 05-19-2022 01:38 PM
    06-08-2022 08:06 PM Go to last post
  10. Polaris 380 does not run correctly
    Polaris 380 does not run correctly With the booster pump on and (backup valve & Polaris disconnected from hose), I get low water pressure from...
    Started by skos007‎, 06-06-2022 12:34 PM
    06-08-2022 08:00 PM Go to last post
  11. Repeat of cloudy water issue.
    Hi all, I've been dealing with a cloudy pool since I opened it last week. Usually with brushing, running the pool cleaner, getting the chemistry up...
    Started by beaverplt‎, 06-06-2022 06:34 PM
    06-06-2022 06:34 PM Go to last post
  12. Hose size or leak
    Pool I have an above ground pool , just started up for the season. I have excessive back pressure coming thru skimmer after I shut off filter. A...
    Started by Barry J‎, 06-02-2022 09:54 AM
    06-02-2022 09:54 AM Go to last post
  13. Hose size or leak
    Started by Barry J‎, 06-02-2022 05:12 AM
    06-02-2022 05:12 AM Go to last post
  14. Jandy RS Battery Connection
    My 9V backup battery came disconnected from my Jandy RS PCB, and I can't see how to reconnect it. There is a small screw on the top of the terminal...
    Started by matthewnadeau‎, 05-28-2022 03:24 PM
    05-28-2022 03:24 PM Go to last post
  15. Jacuzzi JCQ 420 cartridge filter replacement
    I purchased a Jacuzzi JCQ 420 pool filter and have found that the filter cartridges keep failing. I would like to purchase replacement cartridges...
    Started by itybitybob‎, 04-14-2022 06:20 PM
    04-14-2022 06:20 PM Go to last post
  16. Pump size question
    Hi all, My pool pump is going on 30 years old. This year the cover to the electrical hook up rusted away. The casing on the motor is pretty rusty...
    Started by beaverplt‎, 10-26-2021 02:33 PM
    10-26-2021 02:33 PM Go to last post
  17. Need help with new Hayward pump
    SO i just bought a new Hayward Super pump 700. Had an electrician hook it up. It starts up at a normal high speed then kicks down to a slow speed,...
    Started by wgregww‎, 08-04-2021 07:31 PM
    08-06-2021 04:22 PM Go to last post
  18. Replacing sand in filter??
    Hi, Recently I was talking with an acquaintance who also has an inground pool. She was telling me she had to replace the sand in her filter because...
    Started by beaverplt‎, 07-27-2021 01:57 PM
    07-27-2021 01:57 PM Go to last post
  19. Whining
    Hi, I noticed this morning that my pump has become noticeably louder, and higher pitched; and I'm wondering if there's anything I can do,...
    Started by Shakushinnen‎, 06-22-2021 01:53 PM
    06-22-2021 01:53 PM Go to last post
  20. Inline Chlorinator Install Question
    I am replacing my inline chlorinator (the cylinder type you drop tablets into.) My question is, because it must remain upright, when screwing in to...
    Started by Steveromo‎, 05-14-2021 06:42 PM
    05-16-2021 02:01 PM Go to last post
  21. Replacing TR 60 Sand Filter and Multi Port
    We are planning on replacing our 21 year old TR 60 Sand Filter this season along with the multi-Port. We have our pool covered for the winter. Plan...
    Started by Fiveattripp‎, 03-05-2021 12:48 PM
    03-05-2021 12:48 PM Go to last post
  22. Looking for a new salt water filer. I currently have a 20 year old cracked Hayward D
    Looking for a new salt water filer. I currently have a 20 year old cracked Hayward DE. My pool is 13Kgal I know my Hayward DE was real good but...
    Started by skos007‎, 02-23-2021 02:50 PM
    02-23-2021 02:50 PM Go to last post
  23. can you repair a maaco cover with gorilla tape?
    So all around the edges my maaco pool cover is wearing due to a lip, especially corners. Can I use waterproof gorilla patch & seal tape vs. buying...
    Started by wishIcould‎, 11-19-2020 09:59 PM
    11-19-2020 09:59 PM Go to last post
  24. Advice on new pool pump
    #1 I have to replace my current pool pump, a Hayward 3400VSP, as the drive has went out again (2nd time) and I have already replaced 4 motors. The...
    Started by Wraypau‎, 08-23-2020 12:05 PM
    08-23-2020 12:05 PM Go to last post
  25. Aftermarket pool pump motors
    I have a Hayward 3400VSP pool pump. I have went through 4 motors in last 6 years. I am unsure if a motor should only last this long, or if they are...
    Started by Wraypau‎, 08-18-2020 06:13 PM
    08-18-2020 06:13 PM Go to last post
  26. Slatted Pool Covers In US?
    I'm in San Diego. Water evaporation is expensive. My water bill last year was $750 for 2 months I think I've cut it in half by doing bubble...
    Started by atkinson40‎, 08-17-2020 10:16 AM
    08-17-2020 10:16 AM Go to last post
  27. In Spa mode only I'm pulling 20 psi. When I put pool and spa I'm pulling 30 psi
    Is this normal. In Spa mode only I'm pulling 20 psi. When I put pool and spa I'm pulling 30 psi
    Started by skos007‎, 07-17-2020 05:04 PM
    07-17-2020 05:04 PM Go to last post
  28. Polaris does not come on
    Polaris Floor Cleaner does not come on in normal mode When I put it in service mode the motor does turn on but the Polaris never moves
  29. Pool Pump
    Can someone recommend a good above ground pool pump? I don’t want to waste money and want a really good one. I have a 26ft round above ground and...
    Started by cdingess‎, 07-10-2020 02:20 PM
    07-10-2020 02:20 PM Go to last post
  30. I Replaced The Ignitor In My Jandy Model LT-400-L
    The original was definately bad, measuring 0 ohms. I replaced it with a Laars kit and hooked everything back up. Still no ignition but the ignitor...
    Started by JohnASmith‎, 07-04-2020 07:26 PM
    07-05-2020 05:07 PM Go to last post
+ Post New Thread
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 15 replies or 150 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
