+ Post New Thread
Page 77 of 77 FirstFirst ... 27 67 75 76 77
Threads 2281 to 2299 of 2299
Forum: In-Ground Pool Construction and Repair
Questions and comments about problems with building or fixing your pool -- whether you DIY, or hire a contractor -- go here.
  1. Sticky Thread Sticky: Recommended Equipment for In-ground Pools
    _________________________________________ Recommended Equipment for In-ground Pools --- being edited -- June 2018 ---...
    Started by PoolDoc‎, 06-23-2018 12:15 PM
    06-23-2018 12:15 PM Go to last post
  2. Sticky Thread Sticky: Matched Pool Equipment Sets: Pump / Filter / Valves / Feeder / [Heater] / [etc]
    ___________________________________ Matched Pool Equipment Sets ___________________________________ Matching pipe size to pool volume
    Started by PoolDoc‎, 06-20-2018 07:51 AM
    06-20-2018 07:51 AM Go to last post
  3. Sticky Thread Sticky: FAQs & Guides: In-ground Pool Construction & Repair
    S-)___________________________________ FAQs & Guides: In-ground Pool Construction & Repair ___________________________________ ...
    Started by PoolDoc‎, 06-14-2018 05:59 PM
    06-14-2018 05:59 PM Go to last post
  4. Sticky Thread Sticky: Cartridge Filters, Pro & Con
    I must admit that this advice is quite shocking to me. I've owned 5 homes with in ground pools and would take a cartridge filter 100 out of 100...
    Started by Enigma869‎, 06-13-2014 09:45 PM
    05-26-2015 11:20 AM Go to last post
  1. Unhappy leaking return valve
    I have a pool built in the 70's, inground, 15x30, that i just had redone. The only thing I overlooked ( having never owned a pool ) is that one of...
    Started by Fullback40‎, 04-02-2006 04:46 PM
    04-03-2006 01:03 PM Go to last post
  2. Question Pool bottom
    I am having an 18x36 inground vinyl diving pool installed. Three days ago the contractor poured the pool crete, hung and began filling the pool with...
    Started by crosso‎, 04-03-2006 10:00 AM
    04-03-2006 11:40 AM Go to last post
  3. New Pool with a leak.
    Hi All, I filled my new 32X14 IGP last fall and the pool started straight leaking around one inch a day. The builder ignored me more or less for...
    Started by Guido‎, 03-28-2006 11:02 AM
    04-03-2006 09:52 AM Go to last post
  4. Stone Coping - Set in at water level
    I am interested in building a pool with a rear wall of stone. Contractor 1: Tells me that he will build it of stone down into the water level....
    Started by jabre‎, 04-02-2006 03:30 PM
    04-02-2006 07:31 PM Go to last post
  5. Inground Filter on Above Ground Pool?
    Hello, I should have done my research but I didn't think that there was a difference between above and inground pumps and filters. So...
    Started by ikonron‎, 04-01-2006 07:55 PM
    04-02-2006 02:49 PM Go to last post
  6. Question IG vinyl liner pulling away from wall
    Yikes...my IG vinyl liner is coming away from the wall in the corner...any ideas on how I can fix this? Thanks, Janice
    Started by spooky2feet‎, 03-30-2006 09:39 AM
    04-02-2006 08:59 AM Go to last post
  7. Should a new spa share water with pool?
    Greetings experts, I would like to build a gunite hot tub near the pool. (My wife thinks we should get a pre-built fiberglass jacuzzi, which is...
    Started by semenzato‎, 03-27-2006 12:29 AM
    04-02-2006 03:23 AM Go to last post
  8. IG Liner Thickness
    I am about to order a replacement IG liner. Any advice on liner thickness would be appreciated. I believe 20 mil and 30 mil are available. Pool is...
    Started by pmdelage‎, 04-01-2006 07:03 AM
    04-02-2006 12:24 AM Go to last post
  9. Question Marquis Resurface Stain
    I posted this in the "Stains" section, but no responses. I'm hoping that some of you guys do resurfacing & might be able to help out. Anyway, we...
    Started by rlp‎, 03-29-2006 01:23 PM
    04-01-2006 07:05 PM Go to last post
  10. Coping Renovation Question
    I have a vinyl liner pool with the metal bullnose coping poured into a concrete deck. I want to install some sort of concrete edging and pavers to...
    Started by mrduffin‎, 03-28-2006 10:22 PM
    03-31-2006 08:54 AM Go to last post
  11. Gray Plaster - Gray Portland or Dye?
    I want a darker finish to my IG. As I'm in Texas I've been told to go with light gray to keep the pool from getting too hot. For a 34x17 pool I've...
    Started by jabre‎, 03-30-2006 04:56 PM
    03-31-2006 07:40 AM Go to last post
  12. Going it alone???
    I am so glad the site is back up! I have been reading like crazy during the planning and construction of our pool, but recently, our relationship...
    Started by captainx‎, 03-29-2006 09:20 PM
    03-31-2006 07:10 AM Go to last post
  13. Water features
    Wondering if anyone can direct me to web sites or sources for simple spray jets or nozzles. We will have a raised wall on our pool with 5 water...
    Started by LBD‎, 03-29-2006 11:14 AM
    03-29-2006 11:57 AM Go to last post
  14. SunStone Colors? Help?!
    We have been having an extremely difficult time from the manufacturers, distributors, and our pool company trying to figure out what a water-filled...
    Started by msistrunk‎, 03-29-2006 10:56 AM
    03-29-2006 10:56 AM Go to last post
  15. Question about rough plaster
    Hi All, I've been waiting patiently for the forum to come back up so I could get some advice about this. I had a new 21K gallon gunite pool...
    Started by Lenny‎, 03-26-2006 05:30 PM
    03-28-2006 08:36 AM Go to last post
  16. Wow the first one to post
    Still early in the year to think about construction in Ohio, but this Dayton boy is about ready to order some fencing... any suggestions Aluminum...
    Started by jjones‎, 03-25-2006 05:23 PM
    03-27-2006 11:24 AM Go to last post
  17. Question Question about grout between brick coping
    I am staying at my best friends home in Florida for 3 months. They had to go to Germany on business and the gunite pool wasn't quite completed so I...
    Started by putter‎, 03-25-2006 06:20 PM
    03-27-2006 08:13 AM Go to last post
  18. Question-Sandstone Coping Sealer
    I have 10 month old pool with sandstone coping. Problem is that 1) sandstone is bleaching lighter in sun (cosmetic) and 2) is soft and as weathers...
    Started by Katy-Texas‎, 03-26-2006 08:49 AM
    03-26-2006 12:15 PM Go to last post
  19. Question Replacing old DE filter valve
    Hello - I have an old Purex SMBW 2000 filter. When I had an air leak in the system, I found that the filter was leaking water into the drain (I was...
    Started by jneil‎, 03-26-2006 09:42 AM
    03-26-2006 09:42 AM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
