+ Post New Thread
Page 1 of 77 1 2 3 11 51 ... LastLast
Threads 1 to 30 of 2299
Forum: In-Ground Pool Construction and Repair
Questions and comments about problems with building or fixing your pool -- whether you DIY, or hire a contractor -- go here.
  1. Sticky Thread Sticky: Recommended Equipment for In-ground Pools
    _________________________________________ Recommended Equipment for In-ground Pools --- being edited -- June 2018 ---...
    Started by PoolDoc‎, 06-23-2018 12:15 PM
    06-23-2018 12:15 PM Go to last post
  2. Sticky Thread Sticky: Matched Pool Equipment Sets: Pump / Filter / Valves / Feeder / [Heater] / [etc]
    ___________________________________ Matched Pool Equipment Sets ___________________________________ Matching pipe size to pool volume
    Started by PoolDoc‎, 06-20-2018 07:51 AM
    06-20-2018 07:51 AM Go to last post
  3. Sticky Thread Sticky: FAQs & Guides: In-ground Pool Construction & Repair
    S-)___________________________________ FAQs & Guides: In-ground Pool Construction & Repair ___________________________________ ...
    Started by PoolDoc‎, 06-14-2018 05:59 PM
    06-14-2018 05:59 PM Go to last post
  4. Sticky Thread Sticky: Cartridge Filters, Pro & Con
    I must admit that this advice is quite shocking to me. I've owned 5 homes with in ground pools and would take a cartridge filter 100 out of 100...
    Started by Enigma869‎, 06-13-2014 09:45 PM
    05-26-2015 11:20 AM Go to last post
  1. Replacing Liner Track
    Twenty years ago, my pool contractor used Stegmeier Clip-Loc 8CF2000, which required the use of what Stegmeier calls a Liner Track Insert (8CF900). ...
    Started by vgg659‎, 06-04-2021 11:27 AM
    06-04-2021 11:27 AM Go to last post
  2. EcoFinish Aqua Brite pool coating
    Does anyone have experience with EcoFinish Aqua Brite? It is a thermalplastic pool coating that is supposed to be fade resistant, scratch resistant,...
    Started by confusedpoolowner‎, 04-11-2014 04:32 PM
    05-05-2021 06:20 PM Go to last post
  3. Ecofinish / Aquabright coating
    Has anyone used Ecofinish / Aquabright coating on their pool? It's a sprayed in coating similar to powder coating, but done in one step with a...
    Started by PJM361‎, 05-05-2021 06:01 PM
    05-05-2021 06:01 PM Go to last post
  4. General advice on replacing 15 year old equipment
    Folks, We are at a point now where we need to replace, either completely, or pretty much completely, all our in-ground 30K pool equipment. Much...
    Started by mkelley‎, 04-08-2021 07:26 AM
    04-08-2021 07:26 AM Go to last post
  5. Florida Heat Pumps
    So - anyone have any experience using a heat pump in Florida? And/or any recommendations? I have solar panels, which MAYBE give us another month...
    Started by mkelley‎, 04-08-2021 07:01 AM
    04-08-2021 07:01 AM Go to last post
  6. Pool dropped 2" overnight - Can hairline cracks in skimmer cause it
    So we opened Saturday. Filled it, then overnight it dropped about 2-3 inches. I thought it may be the skimmer lines so I ran off the sump (bottom...
    Started by MarkyMackSTL‎, 05-26-2020 07:16 PM
    05-26-2020 09:59 PM Go to last post
  7. Anchoring Pool Liner Extrusion - Wood vs Concrete ?
    Hello Everyone, I'm having some masonry repair work done on my IGP walls to support a new liner extrusion. The mason is recommending that he build...
    Started by zooba72‎, 05-24-2020 09:06 AM
    concrete, extrusion, pool walls, vinyl, wood
    05-24-2020 09:06 AM Go to last post
  8. Need help with pool draining
    I live in NW FL and have an unground pool, that is 5' in deep end, small, approx 7k gallon pool. I live about 1/2 mile from bay water, and am at...
    Started by Wraypau‎, 05-03-2020 03:20 PM
    05-03-2020 03:20 PM Go to last post
  9. DIY Tiling a pool - advice sought
    I've coated my pool twice with epoxy paint. Each time, it lasts 3 good years +2 getting progressively more ugly. I am considering tiling it;...
    Started by windfix‎, 08-24-2019 12:30 AM
    diy, tile
    08-24-2019 12:30 AM Go to last post
  10. Replacing pump with 2" fittings with one with 1-1/2" fittings and Pentair Rainbow 320
    Hello. I am about to replumb my equipment pad and have two questions: 1) I have a 35K gallon inground pool with three 1-1/2" intake lines combined...
    Started by zak_michaels‎, 07-03-2019 02:43 PM
    07-03-2019 04:51 PM Go to last post
  11. Air and leake with Photo.
    Im getting some air in my lines and have a small leak under my Pump and Strainer Housing as shown. 2 years ago i did have a new pump installed. are...
    Started by freddyttt‎, 06-23-2019 06:28 AM
    06-23-2019 06:28 AM Go to last post
  12. What is the glue used in repair kits
    I have seen profesional pool companies using the same glue that comes in vinyl repair kits but in a can like PVC cement comes in. What is that glue...
    Started by wgregww‎, 06-10-2019 08:12 PM
    vinyl repair glue
    06-10-2019 08:12 PM Go to last post
  13. Cracked Standpipe / Replace 48 Sq Ft DE Filter?
    The standpipe assembly on my American Products 48 ft^2 DE filter cracked. I don't know how but it's over 20 years old and the deck over it fell down...
    Started by StevenHB‎, 05-27-2019 12:05 PM
    replacefilter
    05-27-2019 12:05 PM Go to last post
  14. Rough Concrete
    After 16 years, I have rough spots in my in ground concrete pool. What would work as a quick fix for the worst spots to get me through the summer...
    Started by DanS‎, 04-28-2019 09:00 PM
    05-03-2019 10:57 PM Go to last post
  15. Suggestions on plumbing size
    Looking for some suggestions on pipe size for my new pool (20x40, 25,000gal, 2 skimmers, 4 returns, jr slide, 4 deck jets)(ecostar pump, c4030...
    Started by Jayruh‎, 03-07-2019 08:43 PM
    03-12-2019 09:40 PM Go to last post
  16. pool/landscape suggestions
    Hi We are considering getting an inground pool installed (we are in MA)- have figured out size and generally what we are looking for in a pool and...
    Started by Scoot3MA‎, 12-02-2018 02:18 PM
    01-18-2019 07:46 AM Go to last post
  17. Lightbulb Want to repair a floated and cracked pool!
    I have an older built 16x32 inground pool made up of a concrete/gunite (unsure) bottom floor with a safety ledge and fiberglass wall panels. I have...
    Started by ezknes‎, 12-03-2018 06:55 PM
    12-17-2018 09:32 PM Go to last post
  18. New Pool -- Should I get Aqua Genie skimmers?
    I am installing a new pool in Feb. would Like some tip Aqua Genie skimmer. 18x32 should i have 2?
    Started by Booney440‎, 12-17-2018 05:14 PM
    12-17-2018 09:15 PM Go to last post
  19. Question Newly resurfaced pool leaking
    Hi...I am new to this site. I just had my pool resurfaced with Pebble Tech. I did not replace the water line tiles as they are in very good...
    Started by Pix1013‎, 11-23-2018 12:36 PM
    12-11-2018 12:19 PM Go to last post
  20. First post as instructed
    New pool a long time coming. Long story short pool builder said he has "built a ton of pools" in the city where I live. Nonetheless, he has run...
    Started by bowserb46‎, 11-21-2018 10:09 PM
    11-22-2018 10:37 PM Go to last post
  21. Premature pool heater failure
    My jersey shore heaters don't last long, they rust out. I'm talking about my Pentair 200k btu. this is for a 7000 gallon pool My pool guy is...
    Started by silrik‎, 10-29-2018 05:23 PM
    10-29-2018 09:59 PM Go to last post
  22. Pvc crack repair
    Hi, Longtime lurker , this is my first post. I noticed a leak near my spillover spa, coming out from under the preexisting deck. Since we were...
    Started by jinri‎, 10-17-2018 10:38 AM
    10-21-2018 09:50 AM Go to last post
  23. POLYMERIC sand in pool
    20x40 Inground Poo, vinyl liner Just had new work done around the pool they used polymeric sand which trickled down the wall of the pool and...
    Started by nitecapt‎, 10-16-2018 08:24 PM
    10-18-2018 11:59 AM Go to last post
  24. Diamond Brite
    Just starting the pool build and am curious what is out there for plaster besides Diamond Brite. Have read some negative things on it and thought...
    Started by Homedia‎, 10-15-2018 06:06 PM
    10-16-2018 07:05 AM Go to last post
  25. Porcelain Tile for waterline
    Is it okay to use an outdoor rated porcelain tile for the pool waterline? My pool guy wants me to buy tile through him, but the pool offerings are...
    Started by psycgirl‎, 10-12-2018 08:07 PM
    10-16-2018 06:57 AM Go to last post
  26. Replacing Multiport Value Pentair 50118200 - Need Purchase Advice
    After 20+ years with my Pentair 8 multiport valve (1.5" PVC), I must replace it due to a cracked housing. Not sure how it cracked. I think this was...
    Started by vgg659‎, 09-22-2018 06:17 PM
    10-10-2018 07:06 PM Go to last post
  27. Pool plumbing question (1.5" to 2")
    Thanks in advance for any feedback. I am looking for some confirmation of my analysis. I am an engineer, so I believe I understand the physics....
    Started by VikingKnut‎, 05-10-2011 01:22 PM
    2 Pages
    1 2
    calculation, efficiency, piping, sticky
    10-02-2018 02:38 PM Go to last post
  28. Issue with liner
    My chlorine float got stuck behind the jets in the stairs and caused this: The liner here is brittle, especially at the edge of the...
    Started by ccondon23‎, 09-25-2018 11:29 AM
    09-25-2018 06:54 PM Go to last post
  29. Most Popular Pool Depth/Style
    What is the most popular pool depth/style - traditional -> sport ? 3-6?
    Started by PoolNew‎, 09-16-2018 08:32 PM
    09-24-2018 11:21 AM Go to last post
  30. Pool heater exhaust pipe insulation against wood
    I have a pool heater with a 6" vent pipe that is routed through a wood picket fence. I am concerned that the heat from the pipe will damage the wood...
    Started by Boatmanea‎, 09-13-2018 02:55 PM
    09-13-2018 08:52 PM Go to last post
+ Post New Thread
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 15 replies or 150 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
