+ Post New Thread
Page 13 of 33 FirstFirst ... 3 11 12 13 14 15 23 ... LastLast
Threads 361 to 390 of 978
Forum: Pool Chemicals & Pool Water Problems
Chemical or water problems that don't fit elsewhere?
  1. Sticky Thread Sticky: FAQs & Guides: Pool Chemicals & Pool Water Problems
    ___________________________________ FAQs & Guides: Pool Chemicals & Pool Water Problems ___________________________________ Which Pool...
    Started by PoolDoc‎, 06-19-2018 05:52 PM
    06-19-2018 05:52 PM Go to last post
  2. Sticky Thread Sticky: Pool Chemicals to Prefer, Pool Chemicals to Avoid
    ____________________________________ Pool Chemicals to Prefer, & Ones to Avoid ____________________________________ Blended chemicals are a...
    Started by PoolDoc‎, 05-19-2018 03:37 AM
    05-19-2018 11:17 PM Go to last post
  1. New to pool care and need help understanding
    We purchased a used 15x30 lomart abg pool complete w/pump,filter,reel, and heater. We bought a new liner and a new bubble cover for the reel. It took...
    Started by ahale30‎, 06-24-2012 04:13 PM
    06-26-2012 07:31 PM Go to last post
  2. Ready to use my pool..But I have low cya what to do ?
    The weather is nice and we will start using the pool soon.. The water is now cloudy because I was shocking to get rid of algae. I did not cover the...
    Started by ramoniqque‎, 05-14-2012 10:06 AM
    06-26-2012 03:23 PM Go to last post
  3. Unhappy New Pool ... green water
    I put up an 18' x 52" Intex pool last week. Filled it from the hose (public well water), roughly 7,600 gallons. Until it was about half-full, it...
    Started by btokash‎, 06-22-2012 01:45 PM
    06-26-2012 02:43 PM Go to last post
  4. Just filled new 15' round 52" H permanent pool
    AND water not sparkling clear..added mineral remover, vacuumed and then shocked -running DE filter. Water NOT cloudy..just tinge of green..WHAT to...
    Started by mroll‎, 06-24-2012 10:19 AM
    06-25-2012 09:35 PM Go to last post
  5. Need help with best guess - math, cya and bleach and ph????
    Had a problem with multi value and leaking which you guys were SPOT on and that had been fixed, replaced the whole top piece and it is working...
    Started by tamaran2‎, 06-24-2012 01:11 PM
    06-24-2012 09:21 PM Go to last post
  6. Old Test Kit
    How long are the test kit drops/powders good? I have been shocking my pool for 10 days with simply no improvement in the water. I am wondering if...
    Started by Pamsel‎, 06-23-2012 10:22 AM
    06-24-2012 09:09 AM Go to last post
  7. Unhappy TA high, Ph low! How can I fix this?
    Since opening our pool this year, our TA has been high, 240 on the strip test and 140 with the drop test. Our ph is 7.2 on both tests. This year we...
    Started by TheMom‎, 06-23-2012 12:15 PM
    06-23-2012 11:50 PM Go to last post
  8. New pool owner - told to drain pool - Need advice PLEASE!
    Hi Everyone, Great forum here, tons of info! I just bought a house with a nice in ground pool spa and waterfall combo. and I know zero about...
    Started by kenfromtracy‎, 06-22-2012 09:31 AM
    06-22-2012 09:54 PM Go to last post
  9. Angry Yellow stain on steps from chlorine tablets
    Pulled off my solar cover today after it being on for about five days. Found out boyfriend (who is very new to the pool thing) somehow thought he was...
    Started by Chuppet‎, 06-18-2012 07:28 PM
    06-21-2012 10:22 PM Go to last post
  10. Dirt reappearing
    I have a problem with dirt reappearing after I vacuum my pool. You can see some of the dirt coming right back thru the return nozzle. We have a...
    Started by maddie0929‎, 06-19-2012 07:32 PM
    06-21-2012 10:33 AM Go to last post
  11. Exclamation WHIPPED CREAM in pool CLOUDY problem from the DAIRY and OIL
    I had a pool party for my daughter and there was a whipped cream eatting contest that turned into a food fight (like a pie eating one but no pie)....
    Started by funkymut‎, 06-18-2012 08:34 AM
    intex set up, lessons learned
    06-20-2012 04:33 PM Go to last post
  12. Got my new K-2006 testkit...now what?
    Just received my Taylor K-2006 test kit today. The results were eye-opening. And have left me with no idea how to proceed. I live in Phoenix. ...
    Started by pmoneykitty‎, 06-14-2012 06:35 PM
    06-19-2012 06:19 PM Go to last post
  13. clarifer, recommended or not?
    20k gallon 16-32 ig vinly liner pool. opened 3 weeks ago very black/green. sand filter ive pounded it over the weeks with high fc readings and have...
    Started by pbotz2000‎, 06-18-2012 11:01 PM
    06-19-2012 08:56 AM Go to last post
  14. Moblaine's pool
    How can you test for ammonia? I am also having a problem getting a free chlorine reading on my test strips and the pool store says everything looks...
    Started by moblaine‎, 05-31-2012 09:15 AM
    06-17-2012 05:45 AM Go to last post
  15. Confused Newbie needs CYA advice
    Hello everyone – I live near Dallas TX and I have a 7 yr. old pool – I had never had one prior to this so I have been going along with whatever...
    Started by dognostrils‎, 06-01-2012 10:36 AM
    attaboy
    06-16-2012 10:07 PM Go to last post
  16. dirty water
    We have 28 ft above ground i can run the pool rover 3 or 4 times and the vacuum sweeper through the pump and pool looks super clean the minute i turn...
    Started by slack20‎, 06-07-2012 09:11 PM
    06-15-2012 02:36 PM Go to last post
  17. Walmart chlorine vs Chlorinator
    I have read lots of different things on how to use walmart generic 6% liquid chlorine but am afraid to use it yet. We have an automated chlorinator...
    Started by superburg‎, 06-07-2012 09:46 PM
    06-14-2012 11:33 PM Go to last post
  18. No Chlorine
    I have a 40K gallon vinyl liner pool. I have never had this problem before. These are my latest readings by the pool store and I have a Taylor K-1005...
    Started by 67corvette‎, 06-11-2012 03:05 PM
    06-14-2012 08:55 PM Go to last post
  19. Baking soda - too much?
    Hi folks - wish i had found this forum before being socked at the local pool store - ugh! Anyway, lesson learned. I just got our first little...
    Started by Stacyf419‎, 06-11-2012 10:49 AM
    06-14-2012 07:10 AM Go to last post
  20. Chlorine is staying in the pool. Water is muddy
    I have a 12,000 pool and I recently came accross an issue where my pool water is Blue and muddy I had algae and cleaned it using algaecide..I then...
    Started by olover49‎, 06-11-2012 09:00 PM
    06-13-2012 11:04 PM Go to last post
  21. Question Bromine and Chlorine
    My parents own a pool. My father has always taken care of it himself. But, as he gets older (close to 80) he's starting to forget the things he...
    Started by jtagscott‎, 06-09-2012 05:16 PM
    06-09-2012 09:18 PM Go to last post
  22. Natural Chemistry products aiming at reducing phosphates. Should I use it?
    Hi, Over the last coupe of years my pool dealer is always telling me that "phosphates are high" and that I need to treat it with products from...
    Started by cdysthe‎, 06-09-2012 06:22 PM
    06-09-2012 09:08 PM Go to last post
  23. Cloudy Water
    I have a 24ft above ground pool. Vinyl liner with Sand filter. I have tried the BBB method, but I can't get my pool clear. I had it tested yesterday ...
    Started by w7ill4iam‎, 05-27-2012 10:15 AM
    06-09-2012 03:27 PM Go to last post
  24. Exclamation going back to chlorine from bromine.
    Hi, I am a new pool owner. added probably 3 or 4 bromine tablets into my spool. Would it be hard to shock the pool back to chlorine without...
    Started by PoolCanada‎, 06-08-2012 09:56 PM
    06-09-2012 03:02 PM Go to last post
  25. Wink High TA and 7.2 ph
    Hello. I am in need of some help. Our pool continues to go green and gross constantly. We have had the water tested and Chlorine was at 4 ppm which...
    Started by rebekah‎, 06-07-2012 06:44 PM
    06-09-2012 01:49 PM Go to last post
  26. Question Combined Chlorine High
    Hi all, I am a new to the forum so thank you in advance for letting me post to the community. I was gone for a week and my chlorine got out...
    Started by StratDoc‎, 06-08-2012 07:33 AM
    06-09-2012 08:30 AM Go to last post
  27. cyanuric acid level is zero
    I'm opening a newly installed 22K fiberglass pool and have added 15+ lbs of cyanuric acid and still have a zero reading. Any thoughts why nothing is...
    Started by ksue44‎, 06-07-2012 07:51 PM
    06-08-2012 11:18 AM Go to last post
  28. Wink 5k gallon pool -- my water is never clear
    Hi! I have had a 5,000 gal pool wth a Hayward sand filter for several years. I used walmart's pool chemicals for a while & in the last few years, a...
    Started by Tressa‎, 06-07-2012 04:45 PM
    06-08-2012 10:02 AM Go to last post
  29. Talking White foamy residue on pools surface...
    Hello!! I have a white bubbly residue on my pools surface and so i took the water to get tested. Hopefully I can provide enough info so that the...
    Started by Beanns‎, 06-05-2012 05:16 PM
    06-05-2012 11:02 PM Go to last post
  30. Cloudy Water
    I upgraded to the intex Krystal Clear Saltwater System this year. I bought the Leslies Deluxe Poolcare DPD Test Kit to monitor my water. All of my...
    Started by jeanell‎, 06-04-2012 11:11 AM
    06-05-2012 06:43 PM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
