+ Post New Thread
Page 33 of 33 FirstFirst ... 23 31 32 33
Threads 961 to 978 of 978
Forum: Pool Chemicals & Pool Water Problems
Chemical or water problems that don't fit elsewhere?
  1. Sticky Thread Sticky: FAQs & Guides: Pool Chemicals & Pool Water Problems
    ___________________________________ FAQs & Guides: Pool Chemicals & Pool Water Problems ___________________________________ Which Pool...
    Started by PoolDoc‎, 06-19-2018 05:52 PM
    06-19-2018 05:52 PM Go to last post
  2. Sticky Thread Sticky: Pool Chemicals to Prefer, Pool Chemicals to Avoid
    ____________________________________ Pool Chemicals to Prefer, & Ones to Avoid ____________________________________ Blended chemicals are a...
    Started by PoolDoc‎, 05-19-2018 03:37 AM
    05-19-2018 11:17 PM Go to last post
  1. Unhappy Big problem
    I dont know if anyone can help or if this is even the place to ask, I went to the pool store and bought some liquid shock and put it in the back of...
    Started by chili‎, 04-30-2006 09:34 AM
    04-30-2006 01:05 PM Go to last post
  2. Smile Help to clean your water
    Last year I saw on this site someone who suggested using a Scum Sock to help control the "fine" particles in your water that your filter might miss....
    Started by IMherDad‎, 04-16-2006 11:24 PM
    2 Pages
    1 2
    04-28-2006 08:33 PM Go to last post
  3. Test chlorin strength?
    Im curious to find out if there is a way to test the strength of bleach, my local pool store sells 10.5% bleach for $3.77/jug 2.5gallon. one of the...
    Started by xoroniox‎, 04-27-2006 11:45 PM
    04-28-2006 02:18 PM Go to last post
  4. Overwhelmed with pool chemistry
    I recently found this site and would like to switch to the 3 B's. I don't know how to start. I have the last 3 sticks of chlorine in our...
    Started by muundance‎, 04-27-2006 01:15 PM
    04-28-2006 11:19 AM Go to last post
  5. Moved: Pump-how long to run?
    Started by howbout‎, 09-08-2006 10:09 AM
    04-27-2006 01:57 PM Go to last post
  6. Evaporation
    I would like to find out how much water i am losing due to evaporation. I know there are alot of factors like surface area,humidity,temp ect. i did...
    Started by xoroniox‎, 04-26-2006 07:42 PM
    04-27-2006 11:46 AM Go to last post
  7. Water cycle
    How can I tell how long it takes to cycle the water through the pump in my pool? 18 x 36 rectangle, vinyl diving pool, 3.5' - 8', 8' wide steps that...
    Started by crosso‎, 04-26-2006 02:35 PM
    04-26-2006 02:53 PM Go to last post
  8. clorox
    i have a 27x48 AG pool . my ? is how much bleach do i add to start up for the season.. it is not really green but very cloudy...
    Started by rainhill‎, 04-20-2006 03:45 PM
    04-26-2006 01:48 PM Go to last post
  9. Phos-Away and Pool Pizazz newby questions
    I am new to this forum and have been "pooled" for the last several years. Going to make the jump to treating the pool on my own this year. We have...
    Started by docshane‎, 04-25-2006 12:43 PM
    04-25-2006 01:33 PM Go to last post
  10. Petrolium Product Floating on Water
    I have an 11,000 gal Kidney shaped inground pool. Last fall during a very heavy rain and flood, my pool was blessed with a petrolium product floating...
    Started by gmdealer‎, 04-24-2006 11:20 AM
    04-25-2006 06:36 AM Go to last post
  11. e-z pool???
    Has anyone herd or used this new chemical called ...E-Zpool from api water???
    Started by angelo123‎, 04-22-2006 08:43 AM
    04-24-2006 08:30 AM Go to last post
  12. Question Quick Question About pH DROPPING???
    At first I thought it was just a mistake on my part, but I have triple checked it and my pH is definitely coming down. Two days ago it was 7.5,...
    Started by PopcornGirl‎, 04-20-2006 07:38 PM
    04-21-2006 11:18 PM Go to last post
  13. Free Chlorine problem
    Hello, I have had no real problems with my pool til this year. just opened it up 6 days ago and now the water is very clear (normal) and all the...
    Started by Seadog‎, 04-16-2006 08:39 PM
    2 Pages
    1 2
    04-20-2006 04:55 PM Go to last post
  14. Tds
    Hello, I use Ben's kit to test for everything but I go to the pool store to test for Total Dissolved Solids. I use HTH Shock n Swim periodically...
    Started by dhale1‎, 04-17-2006 10:44 AM
    04-17-2006 05:30 PM Go to last post
  15. New Pool Owner
    What is the difference between free chlorine and total chlorine?
    Started by crosso‎, 04-17-2006 09:52 AM
    04-17-2006 11:11 AM Go to last post
  16. Pool Questions
    I was wondering what the bromine equivalent of a chlorine shock is and where can I get it. Also will bromine breakdown chlorine in a pool? What is...
    Started by splasher84‎, 04-10-2006 11:44 AM
    04-11-2006 10:54 AM Go to last post
  17. Cloudy... but clean
    This may be nothing... and I am not too concerned yet.. since temps are still in the 30 - 50 range here in East Tennessee.. However... A few...
    Started by chuck9997‎, 03-25-2006 02:26 PM
    04-05-2006 01:06 AM Go to last post
  18. Water/Chemicals (Newbie)
    We just purchased our first pool, its an AG. We presently own a hot tub and have for the last 2 years. I have pretty much got my head around the...
    Started by nicker‎, 03-30-2006 07:22 PM
    04-01-2006 07:12 PM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
