+ Post New Thread
Page 5 of 33 FirstFirst ... 3 4 5 6 7 15 ... LastLast
Threads 121 to 150 of 978
Forum: Pool Chemicals & Pool Water Problems
Chemical or water problems that don't fit elsewhere?
  1. Sticky Thread Sticky: FAQs & Guides: Pool Chemicals & Pool Water Problems
    ___________________________________ FAQs & Guides: Pool Chemicals & Pool Water Problems ___________________________________ Which Pool...
    Started by PoolDoc‎, 06-19-2018 05:52 PM
    06-19-2018 05:52 PM Go to last post
  2. Sticky Thread Sticky: Pool Chemicals to Prefer, Pool Chemicals to Avoid
    ____________________________________ Pool Chemicals to Prefer, & Ones to Avoid ____________________________________ Blended chemicals are a...
    Started by PoolDoc‎, 05-19-2018 03:37 AM
    05-19-2018 11:17 PM Go to last post
  1. Cloudy water rough vinyl pool wall
    Can't seem to get our pool water clear. Pinch a penny reading today combined chlorine 0 Ph 7.6 TA 80ppm calcium hardness 250 stabilizer 80 ppm...
    Started by nmr1962‎, 06-13-2014 02:17 PM
    06-15-2014 09:47 AM Go to last post
  2. Howdy PoolDoc and Watermom!
    Hello all, Just got a lake house that came with a chlorine sanitized pool. I know almost nothing, but am learning - have ordered a Taylor test...
    Started by ScubaSteve‎, 06-09-2014 12:24 PM
    06-14-2014 08:56 PM Go to last post
  3. no chlorine after repeated doses
    My water is balanced but my chlorine is locked up. I have added 8 bags of shock within 6 hours. The pool store told me to keep checking it every 4...
    Started by tanyat‎, 06-11-2014 08:01 PM
    06-14-2014 03:20 PM Go to last post
  4. New user with old vinyl pool
    First post
    Started by markwg‎, 06-03-2014 03:42 PM
    archive
    06-13-2014 03:36 PM Go to last post
  5. What can I do with old pool chlorine and chemicals?
    What can I do with old pool chlorine and chemicals? This topic comes up frequently, most often with respect to pool owners who discover, just...
    Started by PoolDoc‎, 06-12-2014 10:38 PM
    06-12-2014 10:38 PM Go to last post
  6. Filter Cartridge is green but pool water sparkles, should I worry?
    Hi Everyone, I'm a newbie here. Although I've owned an 18 foot above ground pool for 7 years, I'm seeing something for the first time. I have...
    Started by MichaelC22‎, 06-09-2014 05:13 PM
    06-10-2014 11:16 PM Go to last post
  7. Angry Cloudy Water
    I have pH a little low. chlorine is above 10ppm. cya was ok before pouring in bleach. water has been light bluish and cloudy for 2 or 3 weeks. I...
    Started by gtwarner‎, 06-07-2014 01:19 PM
    06-10-2014 05:58 PM Go to last post
  8. Red face Help !!!! House came with pool....now what??
    We are newbie to pool ownership. Pool had sat untouched for two years while the house sat empty. Concrete pool built in 1969. It holds 28500 gallons....
    Started by homeschoolmom‎, 06-08-2014 11:02 PM
    06-10-2014 05:50 PM Go to last post
  9. Beautiful Aqua blue pool!
    Cannot clear up cloudyness. PH and Alkalinity ok. Supply is from well water with a new water softner system installed last winter. I have not...
    Started by Hogbear‎, 06-09-2014 06:34 PM
    06-10-2014 05:34 PM Go to last post
  10. Question Newly Registered-Lots of Problems
    32,000 gal plaster chlorine pool sand filter. I believe I have way too much HTH algecide in my pool in trying to remove the algea from the plaster...
    Started by crandies‎, 06-07-2014 10:00 AM
    3 Pages
    1 2 3
    06-10-2014 02:55 PM Go to last post
  11. Question Pool Frog seems to have caused rash
    We've had the Pool Frog system for about 4 days. My 6 year-old started developing what looks like wide-spread heat rash on her torso within the first...
    Started by jaimedole‎, 06-08-2014 05:52 PM
    06-10-2014 02:34 PM Go to last post
  12. Angry Cloudy Pool after tons of chemicals.
    Started with pea soup, LMAO now we are at an aqua color with very cloudy water!! I have spent 500$ in pool store chemicals and numerous of there so...
    Started by bikerdude‎, 06-05-2014 03:26 PM
    06-08-2014 05:56 PM Go to last post
  13. Question bleach strength
    Hello... how do I determine what strength (percentage) household bleach is? Checked the label and found no information as to the percentage.
    Started by Tingaling‎, 06-06-2014 05:57 AM
    06-08-2014 11:19 AM Go to last post
  14. phosphates
    I had algae and used everything and my water is clear but something is eating my chlorine fast and I was told it was high phosphates what can I do. ...
    Started by marymil‎, 06-05-2014 11:21 PM
    06-07-2014 04:14 PM Go to last post
  15. New user. Having trouble clearing up cloudy water
    Hi everybody. New user here. I've had my in-ground pool for 12 years now and this is the first time I haven't been able to clear up my water. I...
    Started by c5msg‎, 06-03-2014 09:52 PM
    06-06-2014 12:03 PM Go to last post
  16. White Cloudy Water
    Hi I stupidly added calcium increaser shortly after I had added baking soda (to increase alkalinity) and also PH minus to lower my PH. I believe...
    Started by ScosheOwn‎, 05-22-2014 12:45 PM
    06-04-2014 06:28 PM Go to last post
  17. Cloudy Water out of nowhere
    I got the pool running about 3 weeks ago. The only chemicals I had to add (starting with fresh, brand new tap water due to a new liner) were bleach...
    Started by columbusdan‎, 05-30-2014 08:01 AM
    2 Pages
    1 2
    06-04-2014 01:01 PM Go to last post
  18. Turning my algae farm back into a swimming pool
    Hello. Late last summer I was hospitalized and ended up leaving my newly installed pool unfiltered and unchlorinated from August until now. Needless...
    Started by mobilemike73‎, 05-30-2014 03:12 PM
    06-03-2014 02:27 PM Go to last post
  19. Cloudy Water
    Little bit of algae when I opened. 0 CYA. Shocked, vacuumed, brushed. Ran filter 24 hours for several days while vacuuming and brushing. Put in 9...
    Started by bmlocal175‎, 05-30-2014 05:26 PM
    2 Pages
    1 2
    06-02-2014 07:03 PM Go to last post
  20. Can I add some DE to a sand filter
    Love these forums! Have not really been happy with the pool store advise and prices and when they messed me up once again I started seeking solutions...
    Started by schutt982‎, 05-29-2014 11:49 AM
    06-02-2014 02:22 PM Go to last post
  21. Help with foggy pool
    Your other thread is here: http://www.poolforum.com/pf2/showthread.php/23923-Pool-cloudiness-problem.-HELP Instead of beginning again in this...
    Started by Watermom‎, 06-01-2014 09:46 AM
    06-01-2014 01:08 PM Go to last post
  22. Pool cloudiness problem. HELP
    I have a 30 ft AG pool, 20k gal. hayward 1.5 hp pump with a 250 lb 18 inch sand filter I have owned the pool for 4 summers and the past 2 have...
    Started by Froggypool‎, 05-28-2014 07:10 PM
    06-01-2014 10:06 AM Go to last post
  23. Question - Setting up your pool while you are away on vacation
    First off.....thanks to this forum I have learned more about pool chemistry and care in 2 weeks than the pool store and friends taught me in 3 years....
    Started by vsims2001‎, 05-28-2014 09:23 AM
    05-30-2014 10:22 PM Go to last post
  24. Unhappy Green suspended in Water
    I have been having a problem over the past few years where the water in my pool has a green powder like substance. I have shut the filter off and it...
    Started by Mytime260‎, 05-29-2014 06:50 PM
    05-29-2014 07:39 PM Go to last post
  25. Pool Stains - unsure what kind and best way to proceed
    About 5 years ago I purchased a foreclosure home that had a pool. I knew (still don't know much) about pools and have been battling with this thing...
    Started by tmcdonald‎, 04-19-2014 08:28 PM
    3 Pages
    1 2 3
    05-29-2014 12:20 AM Go to last post
  26. Foamy Water
    Hi, I have a large in ground pool. At opening last year I noticed that any time the water was agitated it tended to foam and bubble. My pool guy...
    Started by copperlode‎, 05-22-2014 04:56 PM
    05-25-2014 07:38 AM Go to last post
  27. Top Job Bleach
    I have read a thread in here about % chlorine in different brands of bleach. Top Job is the cheapest I could find but the thread was not specific in...
    Started by Flipsonic‎, 05-21-2014 04:33 PM
    05-22-2014 01:32 PM Go to last post
  28. Bromine to Chlorine change over
    I am just opening my 67K litre which in the past has used Bromine. I want to switch it over to Chlorine and need some guidance.
    Started by LocksmithLouie‎, 05-19-2014 07:36 PM
    05-21-2014 10:23 PM Go to last post
  29. Milky water
    Hi, I opened the pool about a week ago and have been filtering but the water will not clear up. It is cloudy/milky color and I can barely see the...
    Started by Spideracohen‎, 05-19-2014 08:33 PM
    05-21-2014 02:23 PM Go to last post
  30. Could use a little help!
    I started reading this website last year and implemented the method last year. This is the first time I have posted though. We have had a time with...
    Started by Aprilmaew‎, 05-18-2014 11:27 AM
    2 Pages
    1 2
    05-21-2014 12:11 PM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
