+ Post New Thread
Page 6 of 33 FirstFirst ... 4 5 6 7 8 16 ... LastLast
Threads 151 to 180 of 978
Forum: Pool Chemicals & Pool Water Problems
Chemical or water problems that don't fit elsewhere?
  1. Sticky Thread Sticky: FAQs & Guides: Pool Chemicals & Pool Water Problems
    ___________________________________ FAQs & Guides: Pool Chemicals & Pool Water Problems ___________________________________ Which Pool...
    Started by PoolDoc‎, 06-19-2018 05:52 PM
    06-19-2018 05:52 PM Go to last post
  2. Sticky Thread Sticky: Pool Chemicals to Prefer, Pool Chemicals to Avoid
    ____________________________________ Pool Chemicals to Prefer, & Ones to Avoid ____________________________________ Blended chemicals are a...
    Started by PoolDoc‎, 05-19-2018 03:37 AM
    05-19-2018 11:17 PM Go to last post
  1. Question Help pool gurus
    New on here. I absolutely need the definition of help.I am completely new to pool maintenance I just moved into my girlfriends moms house to fix up...
    Started by cchambers78‎, 05-16-2014 07:53 PM
    05-20-2014 05:22 PM Go to last post
  2. Old pool chemicals proper disposal?
    Not gonna just take these to the dump. I have a tub of pool/spa chemicals/baquisl stuff that came with the house 4 years ago. Since I found this site...
    Started by Steve V‎, 05-19-2014 09:03 PM
    05-19-2014 10:36 PM Go to last post
  3. Smile New pool start with what first??
    Just finished filling 24 ag sharkline heritage pool. Pump is running and I am ready to add the chemicals. Using the BBB method I have liquid...
    Started by Steve V‎, 05-13-2014 09:33 PM
    05-19-2014 08:49 PM Go to last post
  4. Semi-transparent patches floating on water
    We recently purchased a home with a 23,000 gallon in-ground vinyl pool (Hayward) with a sand filter. All-in-all the pool appears to be fine with...
    Started by Jjnol‎, 05-17-2014 10:33 AM
    3 Pages
    1 2 3
    sticky, sticky-digital-test
    05-18-2014 10:43 PM Go to last post
  5. Cloudy pool
    What do y'all use for a cloudy pool? I have a 18x36 saltwater in ground pool. I don't have any staining....it's just cloudy...I can see the bottom,...
    Started by Bamafans‎, 05-17-2014 10:53 AM
    05-17-2014 09:50 PM Go to last post
  6. New poster, taking care of new vinyl liner
    South Florida, in-ground vinyl pool, 7000 gallons. We'd managed to bleach the liner pretty good and solid thanks to following pool store advice...
    Started by jollyreaper‎, 05-10-2014 03:07 PM
    05-16-2014 07:01 AM Go to last post
  7. New pool cover punctured during new patio construction - big problems
    So first of all the pool cover is 1 year old so I am not happy that it was punctured during construction of a new patio. I found pieces of jagged...
    Started by Mdpools‎, 05-14-2014 04:24 PM
    05-15-2014 01:36 PM Go to last post
  8. How to convert from bromine to clorine
    Can you switch a bromine pool to clorine??
    Started by Waselich‎, 05-11-2014 03:15 PM
    05-14-2014 11:30 PM Go to last post
  9. Added Clorox Outdoor Professional cleaner to pool
    Thought I was buying super concentrated bleach but after reading a post here I'm concerned. No obvious ill effects yet- I added two gallons after...
    Started by Kayakersmith‎, 05-12-2014 12:09 PM
    05-13-2014 08:33 AM Go to last post
  10. Opening pool (or soon) need thoughts please
    I checked my levels to help me get started .2 cl.. 8.2 ph alky 30, absolutely no cya. I bought a gallon of instant conditioner which I haven't used...
    Started by dansdad‎, 05-07-2014 11:47 PM
    05-08-2014 05:08 PM Go to last post
  11. Waiting on Taylor kit.Need help with test strips.
    Hello.I have a Taylor-2006-C test kit and 2 unicel cartridge filters due to arrive on 05/13/2014.In the meantime I am useing OTO/PH kit and test...
    Started by dncellis2‎, 05-05-2014 09:41 AM
    2 Pages
    1 2
    05-07-2014 11:21 AM Go to last post
  12. Facing jets?
    Which way do you guys position yours, for above ground? I have been pointing mine away from the skimmer and down a little, but seems no matter what I...
    Started by CaptainHowdy‎, 05-03-2014 09:48 PM
    05-04-2014 10:14 PM Go to last post
  13. Should I change my filter sand?
    Long story short....a little less than 2 years ago, I had algae problems with Baquacil, and drained the pool pretty much, and converted to chlorine....
    Started by CaptainHowdy‎, 05-02-2014 10:48 PM
    2 Pages
    1 2
    sticky, sticky-filter, sticky-sand
    05-03-2014 09:43 PM Go to last post
  14. New to pools. Help with Filter operations.
    Ugh.. where do I begin? We bought a home a year ago with a pool that previous owner had already opened. We just had to "maintain" it. We ended up...
    Started by summer78‎, 04-24-2014 10:02 AM
    04-26-2014 08:18 PM Go to last post
  15. 20k gal pool in Sol Cal. .....needs to be drained.
    Good old Leslies did a test on the water and dissolved solids are at 5000. Plus 2 other readings are high. Of course Mr Lesiles said I have to drain...
    Started by pmaru77‎, 04-06-2014 08:50 PM
    4 Pages
    1 2 3 ... 4
    04-25-2014 11:35 PM Go to last post
  16. Unhappy Black algae or metal stain
    Hi, I am a complete newbie to the pool. I purchased a house recently and it came with an in ground pool. The pool was filled but contained some...
    Started by Crazziee‎, 04-01-2014 06:04 PM
    3 Pages
    1 2 3
    04-08-2014 05:45 PM Go to last post
  17. Question Borate concentration ?
    I am trying to run my pool with the 50 ppm borates, which I have added by adding borax to my pool. I was wondering if anyone can tell me if indicator...
    Started by Aprilszoo‎, 04-01-2014 02:05 PM
    attaboy
    04-04-2014 07:54 PM Go to last post
  18. White Film in pool?
    My Test results: FAC - 3 TAC - 3 Salt - 4500 (High) - fixing this Calcium Hardness - 140 (low) adding the recommend amount slowly and retesting...
    Started by ketzie79‎, 04-04-2014 12:51 PM
    04-04-2014 01:51 PM Go to last post
  19. added 'chlorine enhancer' to my pool; now I have no chlorine
    Back in December when I closed the pool I treated it with a chlorine enhancer. After that none of my chlorine tests (DPD, OTO or strips) worked, not...
    Started by ggilpu‎, 04-04-2014 01:03 PM
    04-04-2014 01:17 PM Go to last post
  20. I built my pool in November have a CYA question.
    I bought a Taylor FAS-DPD test kit. I can't seem to get a CYA reading at all. I tried letting the water sample get to room temp. I let it mix for 2...
    Started by OconeeDawg‎, 03-31-2014 05:21 PM
    04-01-2014 02:32 PM Go to last post
  21. Dirt, algae, pollen?
    I am a rookie and this will be my first spring with an inground pool. My pool has been crystal clear all winter. All of the sudden, I have a brownish...
    Started by Jason0308‎, 03-28-2014 08:36 PM
    03-28-2014 10:38 PM Go to last post
  22. dry acid
    what is the advantage to using dry acid over liquid muriatic acid is the dry type acid safe on the chlorinator thanks
    Started by clayton2000‎, 03-28-2014 12:27 PM
    03-28-2014 01:01 PM Go to last post
  23. Arizona pool with High Calcium Hardness and Cyanuric Acid
    Hi, I live in Tucson AZ, and the water here is harder than the hubs of 7734. Just tested with Taylor K 2006 Kit: FC: 6ppm pH: 7.4 TA: 160 ppm...
    Started by Nedaz‎, 09-15-2013 02:07 PM
    03-27-2014 05:41 PM Go to last post
  24. Tropical Pool Care advice
    Hi everyone, I'm a newbie here and have some questions. Can anyone offer some guidelines for pool care in a tropical location? What to do daily,...
    Started by Raihnman‎, 01-29-2014 04:28 PM
    03-13-2014 03:51 PM Go to last post
  25. Question New pool owner - are these products useable?
    Hi, We just moved in a new house with a pool and had a baby 4 months ago, so we're trying to do minimal work to keep it in check while doing the...
    Started by elenae‎, 01-18-2014 04:09 PM
    03-10-2014 05:12 PM Go to last post
  26. Drain pool?
    Hi everyone am a new member, I have a few questions but ill give a brief history of the pool. I bought a house that has a 12k play pool in-ground,...
    Started by fjimmy123‎, 02-26-2014 11:04 PM
    03-04-2014 06:50 PM Go to last post
  27. What does borax do to pool water?
    What does Borax do to pool water? Is the tetra borate from Haviland better stuff?
    Started by RobLane‎, 12-28-2013 07:38 PM
    01-07-2014 11:19 PM Go to last post
  28. Delta UV systems for outdoor residential pools
    Does anyone have any experience with the Delta UV system? Thoughts or opinions?
    Started by mnbountyhunter‎, 01-03-2014 10:57 AM
    delta uv, pool uv, sticky
    01-03-2014 06:53 PM Go to last post
  29. debris settling at the bottom of pool and spa
    I just bought the house last week. It did have some debris on the side walls and I brushed them towards the pump hole thing but they haven't went...
    Started by consoleman‎, 11-01-2013 08:44 AM
    11-01-2013 08:44 AM Go to last post
  30. MSDS for Pool Solutions Products
    I need to know where to go for Pool Solutions products.
    Started by dream weaver‎, 10-23-2013 12:13 PM
    10-23-2013 02:37 PM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
