+ Post New Thread
Page 15 of 33 FirstFirst ... 5 13 14 15 16 17 25 ... LastLast
Threads 421 to 450 of 978
Forum: Pool Chemicals & Pool Water Problems
Chemical or water problems that don't fit elsewhere?
  1. Sticky Thread Sticky: FAQs & Guides: Pool Chemicals & Pool Water Problems
    ___________________________________ FAQs & Guides: Pool Chemicals & Pool Water Problems ___________________________________ Which Pool...
    Started by PoolDoc‎, 06-19-2018 05:52 PM
    06-19-2018 05:52 PM Go to last post
  2. Sticky Thread Sticky: Pool Chemicals to Prefer, Pool Chemicals to Avoid
    ____________________________________ Pool Chemicals to Prefer, & Ones to Avoid ____________________________________ Blended chemicals are a...
    Started by PoolDoc‎, 05-19-2018 03:37 AM
    05-19-2018 11:17 PM Go to last post
  1. Pool phosphates high
    Hello! I just came from the pool store and they told me my phosphates was high is there a cheap way to lower it? Free Available Chlorine 8 Total...
    Started by spawn1980‎, 05-21-2012 04:54 PM
    05-21-2012 06:24 PM Go to last post
  2. Heavy rain advice
    Hi, first post! I have a 12,500 gal fiberglass pool and use chlorine tabs/shock/algaecide system. A rainstorm in North Carolina caused clay soil and...
    Started by remania‎, 05-15-2012 12:46 PM
    bucket test, floc, jar test
    05-21-2012 03:32 PM Go to last post
  3. Organic stains on liner
    Hello, i have been opening my in-gound pool for many years without significant issues - however this year, i have a few stains on the liner at the...
    Started by joelg2k‎, 05-19-2012 07:58 AM
    05-20-2012 10:35 PM Go to last post
  4. Cloudy pool
    I have visited this site for several weeks and have been learning a little each week. I have tried to follow the pool school advice and have had some...
    Started by coreylowe‎, 05-19-2012 04:00 PM
    05-19-2012 04:20 PM Go to last post
  5. Question Chemical interaction- is this a known problem?
    I usually shock my in ground 18000 gal pool with a couple pounds of shock, but having some trouble getting it cleared up this year, so I decided to...
    Started by rdkelley‎, 05-19-2012 10:43 AM
    05-19-2012 02:20 PM Go to last post
  6. Exclamation URGENT...Need help.. grad party 7 days...cloudy foamy pool not holding chlorine level
    I am so glad to have this forum and hopeful you can help us get our pool straightened out. My son’s graduation party is exactly one week away and I’m...
    Started by poolprobe‎, 05-11-2012 10:46 AM
    05-17-2012 02:51 PM Go to last post
  7. Red face New Pool Owner - Chlorine not holding
    Hello - We bought a home that had a closed inground pool for 2 years. The pool is open now and is clear and clean. However, it seems like it will...
    Started by denastar‎, 05-14-2012 02:14 PM
    ammonia, sticky
    05-16-2012 04:41 PM Go to last post
  8. Should I be concerned about Sodium level
    I'm using clorox bleach in my pool and was wondering if I should be concerned with the sodium level rising over time? Does the sodium cause any...
    Started by Bassinbob‎, 05-15-2012 10:15 AM
    05-15-2012 12:46 PM Go to last post
  9. Lowering phosphates with hydrogenated lime
    I have in ground 13000 gallons pebble pool in Tucson AZ. My phosphates were high (2500 ppb), my TA was 120 and pH was 7.6 and I decided to lower...
    Started by czechtranslation‎, 05-13-2012 03:14 PM
    05-14-2012 04:18 PM Go to last post
  10. First Post and low stabilizer..
    I have a 27 ft above ground pool and I have drained it to clean in and refilled recently. I want to make sure I get started out right. I have had my...
    Started by cooper5051‎, 05-10-2012 02:57 AM
    05-13-2012 11:53 PM Go to last post
  11. Where'd the CYA go?
    I've moved to a house with a marginally well taken care of pool, and it's my first pool so I've been getting it and myself up to speed over the past...
    Started by usmarinemike‎, 05-08-2012 10:27 AM
    2 Pages
    1 2
    05-13-2012 09:00 AM Go to last post
  12. cloudy water
    In the process of of trying to get my water cleared up now. This is my first inground pool...and I'm pretty much lost. I adjusted the PH and...
    Started by Zac851‎, 04-30-2012 08:51 PM
    4 Pages
    1 2 3 ... 4
    algae clean up, algae dust, de powder
    05-13-2012 07:53 AM Go to last post
  13. Cloudy water
    Need advice what chemicals to add!!! Have a salt water pool which haD perfect pool chem when opened 9 days ago. Now it is cloudy, ph is 6.8, cya...
    Started by wardenann‎, 05-09-2012 02:18 PM
    2 Pages
    1 2
    05-12-2012 02:57 PM Go to last post
  14. Struggling to get water clear
    We are new pool owners of an old pool (bought an old house with an old pool). We opened the pool about 3 weeks ago. Had a local shop open and turn...
    Started by Mm_putnam‎, 05-06-2012 10:26 PM
    05-11-2012 12:47 PM Go to last post
  15. No CYA in pool, redux
    I have the same problem: my CYA went to zero (using your test kit and the melamine precipitation test) and I have a high combined chlorine level....
    Started by StevenHB‎, 05-08-2012 06:00 PM
    2 Pages
    1 2
    05-10-2012 10:02 PM Go to last post
  16. Need help getting rid of 7 ppm combined chlorine
    1st time owning a pool and didn't do it right the 1st winter: no chlorine at all since end of summmer (only ran pump). Need your help to get rid...
    Started by mtroyalm2‎, 05-10-2012 03:37 PM
    05-10-2012 09:04 PM Go to last post
  17. Sand Helper - Zeo Sand
    Just activated my account, so haven't searched really good yet, but was wondering if there were any comments about "Sand Helper" and what it is. ...
    Started by rmiller111‎, 05-07-2012 06:33 PM
    05-10-2012 04:59 PM Go to last post
  18. PoolBrand product reviews
    I was curious if anyone has used the Sams club 3" chlorine tabs? They are labeled "PoolBrand". I have read about the fact that there are only a few...
    Started by agripnt‎, 05-07-2012 10:42 PM
    05-09-2012 03:15 PM Go to last post
  19. Green hue in clear water...
    Our fiberglass pool with an Aqua Rite salt cell system has a minor start up issue. We had some trouble with the cover at the end of last season. ...
    Started by Sparkle‎, 04-25-2012 03:46 PM
    4 Pages
    1 2 3 ... 4
    05-09-2012 12:29 PM Go to last post
  20. Exclamation Stinky Water - My Pool Smells Like Poop
    Help! My water is clear as can be but very stinky - smells like dog pooh. I have an inground vinyl pool. 18x36 approx 27000gallons. We have a...
    Started by AngelaGarciaG‎, 05-06-2012 11:22 AM
    2 Pages
    1 2
    hydrogen sulfide, poop pool, sticky
    05-08-2012 11:52 PM Go to last post
  21. Fixing Cloudy Swimming Pool Water
    Again, this is a placeholder, right now.
    Started by PoolDoc‎, 05-07-2012 10:13 AM
    05-07-2012 10:13 AM Go to last post
  22. Getting rid of that sandpaper junk on my vinyl liner
    Help!!! What is that sandpaper junk stuck to the bottom of my pool? Please can someone tell me how to get rid of it? We have lowered the ph and...
    Started by Labmomx7‎, 05-06-2012 02:55 PM
    sand-algae
    05-06-2012 06:06 PM Go to last post
  23. Chemical substitutes?
    Hi, I was wondering if other chemicals can be used in place of the expensive ones?
    Started by Tinamac‎, 05-05-2012 09:21 AM
    05-05-2012 07:44 PM Go to last post
  24. Blue cloudy water
    We have a small inground patio pool, no more than 6000 gallons. The pool was very green. we have got it now that its blue and very cloudy. we keep...
    Started by Bama1992‎, 05-01-2012 09:24 PM
    05-01-2012 09:43 PM Go to last post
  25. New member questions
    Looking for information on water testing methods preferred by most and information on Natural Chemistry's Pool Foundation the pool store was trying...
    Started by eep30‎, 05-01-2012 11:18 AM
    05-01-2012 08:37 PM Go to last post
  26. Question Water cloudy, have test results
    We opened the pool last week. It was a green nasty mess. Added lots of bleach (about 12-15 gallons) and got it to a blue cloudy mess. I thought it...
    Started by sbillingsley‎, 04-09-2012 06:10 PM
    2 Pages
    1 2
    pool-stored
    05-01-2012 02:07 PM Go to last post
  27. Lots of borax and baking soda - No results
    I am treating a 500 gal hot tub and have a yellow result on ph level so I added several cups of baking soda and retested- No change added a box of...
    Started by Gibgrl‎, 04-29-2012 08:14 PM
    04-30-2012 07:26 AM Go to last post
  28. No Cyanuric Acid?
    Test results: FAC 1 TAC 1 Salt 2900 CYA 0 TAC 80 pH 7.4 My question is this, can I really have NO Cyanuric Acid? I was under the...
    Started by Strongmad‎, 04-27-2012 05:18 PM
    04-28-2012 11:21 AM Go to last post
  29. How often should water be changed?
    Still new to the forum. What is current thinking on how often to drain and fill the the pool? I have an in-ground plaster pool. I've been dealing...
    Started by Hornman120‎, 04-27-2012 06:18 PM
    04-27-2012 08:53 PM Go to last post
  30. UV Pool Water Filtration
    I bought an 18' round above ground pool from my neighbor and I am getting ready to move it. I would like to get away from using a lot of chemicals so...
    Started by Pibster‎, 04-25-2012 10:12 AM
    04-25-2012 12:18 PM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
