+ Post New Thread
Page 14 of 33 FirstFirst ... 4 12 13 14 15 16 24 ... LastLast
Threads 391 to 420 of 978
Forum: Pool Chemicals & Pool Water Problems
Chemical or water problems that don't fit elsewhere?
  1. Sticky Thread Sticky: FAQs & Guides: Pool Chemicals & Pool Water Problems
    ___________________________________ FAQs & Guides: Pool Chemicals & Pool Water Problems ___________________________________ Which Pool...
    Started by PoolDoc‎, 06-19-2018 05:52 PM
    06-19-2018 05:52 PM Go to last post
  2. Sticky Thread Sticky: Pool Chemicals to Prefer, Pool Chemicals to Avoid
    ____________________________________ Pool Chemicals to Prefer, & Ones to Avoid ____________________________________ Blended chemicals are a...
    Started by PoolDoc‎, 05-19-2018 03:37 AM
    05-19-2018 11:17 PM Go to last post
  1. Pine Pollen in the North East
    Due to weather conditions earlier this year we are having a banner year for pine pollen this spring. Bad news for pool owners I'm finding out. ...
    Started by robbym70‎, 06-01-2012 02:04 PM
    pollen
    06-05-2012 05:57 PM Go to last post
  2. Looking for chlorine alternatives . . .
    I'm new here too and trying to learn about chlorine alternatives.
    Started by ChristinaLucia‎, 05-22-2012 03:10 PM
    2 Pages
    1 2
    chlorine alternatives, chlorine dangers, toxicity
    06-05-2012 04:17 AM Go to last post
  3. Wink chlorine levels
    Hi, when starting my pool this year, I have shocked and added gallons of liquid chlorine and it still registers at 0 or 1. Is there something else I...
    Started by mrs.rainbow‎, 06-02-2012 03:33 PM
    06-04-2012 11:05 PM Go to last post
  4. Can't keep chlorine in my pool
    Here are my pool water values: FC: 0.1 ppm TC: 0.3 ppm Comb C: 0.3 ppm pH: 7.6 Hardness 370 ppm Alk: 97 ppm CA: 45 ppm Copper: 0.27 ppm
    Started by jgfranklin‎, 06-03-2012 11:51 AM
    06-04-2012 08:01 PM Go to last post
  5. a little cloudy
    i have an inground 21,000 gallon sand filter. just starting opening this week..it is still just a little cloudy and looks a little dingy. i vaccum...
    Started by poolhelp101‎, 06-03-2012 12:53 PM
    06-03-2012 05:30 PM Go to last post
  6. white-yellowish little dots on the side of the pool
    I'm not sure what it is and exactly how to attack it! Does anyone have any suggestions on what this might be? Thanks!
    Started by cheharrison‎, 06-01-2012 02:54 PM
    06-01-2012 05:53 PM Go to last post
  7. 400 cya
    Tock H2O sample to dealer and he measured over 400 PPM CYA. Said the only way to reduce is to drain pool. Any other suggestions? Thanks kevin
    Started by atkinson40‎, 04-30-2012 04:44 PM
    4 Pages
    1 2 3 ... 4
    color blind, ph meter
    06-01-2012 11:16 AM Go to last post
  8. Question Hazy water
    If my total chlorine (TC) is 8.5 and my Free Chlorine (FC) is 7.5, do I have to shock my pool until they are equal? Everything else is in the normal...
    Started by Dan Heinrikson‎, 05-26-2012 11:02 AM
    05-31-2012 09:00 PM Go to last post
  9. Questions About Chlor Free / E-Z Pool / Tropical Splash
    Has anyone here used a product called EZ Pool?
    Started by suedvs‎, 05-26-2012 07:07 PM
    e-z chlor, hodge podge, sticky
    05-31-2012 12:01 PM Go to last post
  10. ozonator
    I recently bought a pool and through a bit of research bought an ozonator. I was wondering if by using this I have to approach things a little...
    Started by clayboy‎, 05-14-2012 05:35 PM
    05-30-2012 03:54 PM Go to last post
  11. Long time forum reader
    But a new member. I've been using the BBB method for about three years, and I love it. Less work, less $$$, and better quality water. What's not to...
    Started by steve52‎, 05-28-2012 09:32 PM
    05-29-2012 02:27 PM Go to last post
  12. Chlorine not in pool!
    Hi I'm having a plethora of problems with chlorine. We opened our pool about a month ago and we continue to have an absence of chlorine even when we...
    Started by Preston‎, 05-28-2012 08:35 PM
    05-29-2012 06:23 AM Go to last post
  13. Shock and clarity. How does it work?
    Generally, how does shocking a pool clear the water? When you have small particles that are suspended in the water, what does the chlorine...
    Started by bri3180‎, 05-28-2012 01:25 PM
    05-28-2012 08:46 PM Go to last post
  14. High TA
    I just had a 30' AGP pool installed and I am having a tough time getting the TA down. My local pool supply store recommened adding a pint of Muratic...
    Started by smaloney62‎, 05-28-2012 09:16 AM
    05-28-2012 03:44 PM Go to last post
  15. Question Inground pool cloudy
    Hello this is my first time here awesome work and thank you for sharing your knowledge. I have a 24K gallon vynal pool, it had a mesh cover over...
    Started by Rvjames‎, 05-27-2012 08:09 PM
    05-28-2012 12:43 PM Go to last post
  16. Where to buy boric acid?
    I was researching the possibility of using boric acid instead of borax or tetraborate pentahydrate (what I've been using up until now). I really...
    Started by JimK‎, 05-27-2012 07:16 PM
    2 Pages
    1 2
    05-28-2012 12:25 AM Go to last post
  17. Once hardened, will borate dissolve?
    I feel silly asking this, but here goes. Today I wanted to raise my borate level a bit (I use tetraborate pentahydrate). It was a bit windy, so...
    Started by JimK‎, 05-27-2012 04:53 PM
    05-27-2012 11:28 PM Go to last post
  18. Filter and Cyanuric acid issue
    My first problem is I recently went from a cartridge filter to a Hayward pro sand filter. When I backwash is it normal to see sand in the sight...
    Started by Cannon‎, 05-27-2012 02:02 PM
    05-27-2012 10:30 PM Go to last post
  19. First pool, it's hot, want to jump in!!!!
    Hello, Names Jake. I just filled my 15x48 inch above ground pool. I have my chemicals and schedule set up by a local pool shop. Here's my...
    Started by Jake337‎, 05-27-2012 12:53 PM
    05-27-2012 09:20 PM Go to last post
  20. hello and thanks!
    Hey all, I found this website by doing the old Google search(thanks Google!) I have a 18' round above ground pool. I installed it about 6 years...
    Started by daigie‎, 05-27-2012 02:22 PM
  21. First Post
    I just registered with the forum so this is my first post. I have used the forum quite a bit and it has been a huge help, but have gotten to the...
    Started by LindaP‎, 05-26-2012 03:09 PM
    05-27-2012 08:08 AM Go to last post
  22. Question Quick question about swimming with 1.5 CC
    Is it o.k to swim in a pool that is crystal clear clean, no signs of any other problems except for a CC level that remains in the 1.0-2.0 ppm range? ...
    Started by JuJuBee‎, 05-24-2012 09:54 AM
    05-26-2012 08:14 PM Go to last post
  23. Question Caalgon, Bath salts?
    Can you add epsom or bath salts to an AG vinyl pool? Would like to create a softer water and more spa like experience.
    Started by Darwin‎, 05-26-2012 10:58 AM
    05-26-2012 01:11 PM Go to last post
  24. mustard algae, pollen, or ecoklean
    I am trying to figure out what keeps forming in the bottom of my pool. I was first told it was mustard algae. So we shocked the pool, waited 1 hr,...
    Started by shane‎, 05-23-2012 02:59 PM
    05-25-2012 11:53 PM Go to last post
  25. HELP, cloudy blue pool water
    I am a newbie. I have searched the forum but have nothing for this issue. I live in Florida. We had solar panels put on in February. Everything...
    Started by krschaefers‎, 05-25-2012 12:28 PM
    05-25-2012 04:02 PM Go to last post
  26. Dead Algae. Pool blue but cloudy won't filter
    The story...... I opened the pool this sping and it was literally black with Algae. Started Shocking heavily every day for a week. Pool cleared up...
    Started by Patty16‎, 05-22-2012 10:40 PM
    05-25-2012 09:28 AM Go to last post
  27. No CYA
    Pool store guy says my CYA measured at 30 ppm. I just got my K2006 kit today and tested on my own, because I didn't believe him. What I got was not...
    Started by mel.hoffman‎, 05-22-2012 02:44 PM
    05-23-2012 04:46 PM Go to last post
  28. Unhappy In need of advice, once again!
    I have a couple of questions and wanted to put them in one post and I didn't know exactly where to post them. We opened the pool in March,...
    Started by rannrich‎, 05-22-2012 02:36 PM
    05-22-2012 09:44 PM Go to last post
  29. greenish and cloudy
    Thanks in advance folks. I have a salt water pool that is about 5 years old. Its 36x18, 8ft deepend and 3 1/2 shallow end. Its green and cloudy. Up...
    Started by ganny76‎, 05-02-2012 07:08 PM
    5 Pages
    1 2 3 ... 5
    05-22-2012 09:36 AM Go to last post
  30. Exclamation Chlorine Won't Hold
    I need your help!! We have an 22,000 inground pool that's 9 years old that has an automatic pool cover. We opened it early on April 4th (six weeks)...
    Started by kkresse‎, 05-19-2012 10:24 PM
    pix2fix
    05-21-2012 09:17 PM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
