+ Post New Thread
Page 5 of 36 FirstFirst ... 3 4 5 6 7 15 ... LastLast
Threads 121 to 150 of 1057
Forum: Salt Generators (SWCG) & other Chlorine Feeders
Trichlor feeders, salt-based generators and systems, feed pumps, and more.
  1. Sticky Thread Sticky: SWCG (Salt Water Chlorine Generators) - Pro & Con
    ______________________________________ SWCG (Salt Water Chlorine Generators) - Pro & Con Even though 30+ years in the pool business has taught...
    Started by PoolDoc‎, 06-15-2018 06:21 PM
    06-17-2018 12:35 PM Go to last post
  2. Sticky Thread Sticky: FAQs & Guides: Salt Water Pool Systems (SWCG) & other Cl feeders
    ________________________________ FAQs & Guides: Salt Water Pool Systems (SWCG) & other Cl feeders ________________________________ Salt...
    Started by PoolDoc‎, 06-03-2018 07:55 AM
    06-03-2018 07:55 AM Go to last post
  1. Bromine Pool vs salt water system (SWCG)
    My pool builder is strongly recommending bromine + uv for a pool. Is that a good setup or should I go with SWCG?
    Started by Easypare‎, 02-27-2014 09:24 PM
    03-07-2014 12:36 PM Go to last post
  2. Smile Salt chlorine system with ozonator?
    Hi All, I realize it's an age old debate….but I'm losing sleep over what to do. I am putting in a rectangular gunite, blue stone coping 13x38 with...
    Started by Meghan‎, 02-27-2014 10:08 AM
    03-06-2014 02:56 PM Go to last post
  3. Salt Water pool vs other options
    We are putting a pool in our house in Texas soon. Several of the pool contractors are adamant that we shouldn't use salt and prefer Nature 2 or...
    Started by dedebach‎, 02-28-2014 03:20 PM
    03-06-2014 12:58 PM Go to last post
  4. Unhappy Haywood Chlorinator Cap Removal
    Has anybody had issues trying to unscrew the Haywood Chlorinator cap/top? I have tried, my 300lb son has tried, I even tapped the top with a hammer...
    Started by prissy‎, 02-01-2014 07:37 AM
    02-01-2014 06:35 PM Go to last post
  5. Buy SWCG?
    First time pool owner via a new home purchase. Studying about SWCG. Should I use or not. I really like the idea of testing and managing my pool as...
    Started by cskid‎, 01-12-2014 02:31 PM
    01-25-2014 06:06 PM Go to last post
  6. Switching to salt
    How much can I expect to pay, switching over to salt? Thx
    Started by Muttley‎, 11-13-2013 07:36 AM
    12-04-2013 10:35 AM Go to last post
  7. Looking for Liner and Salt water opinions
    Im a new Pool owner. We bought a house with a '27 above ground pool. We know nothing about it though. I tried cleaning it to get it ready to close...
    Started by dball‎, 10-29-2013 04:54 PM
    11-02-2013 11:42 AM Go to last post
  8. Can I add bleach to salt water pool?
    First of all I should mention, I haven't been to this forum in a year or so. Reason is that with all the help I got from here, I didn't need to :-)...
    Started by oroepke1‎, 10-25-2013 02:24 PM
    bleach, chlorine, salt
    10-25-2013 02:50 PM Go to last post
  9. Cool Salt generation systems .........feedback please
    We are about 6 weeks from having a liner pool built ( 24 x 40 w/ auto cover). We have been researching the best type of chlorination systems. There...
    Started by sae99‎, 07-25-2011 05:10 PM
    10-23-2013 02:45 PM Go to last post
  10. Aquapure 1400 stopped linking to Aqualink RS8
    Aquapure 1400 stopped linking to Aqualink RS8 The system has been running fine for years, all of the sudden the Aquapure stops making chlorine. ...
    Started by FikseGTS‎, 10-13-2013 09:04 PM
    10-23-2013 11:14 AM Go to last post
  11. What type of flow sensor do SWCG's use?
    Just trying to understand the SWCG before I decide to invest. The flow sensor seems to be an electronic type. Is it basically a thermal mass flow...
    Started by Motoman‎, 10-16-2013 12:42 AM
    10-17-2013 10:27 AM Go to last post
  12. Using variable speed pool pump with SWG
    I am considering converting to a variable speed pump. The vendor says I will save a lot of money my electric bill. They want to program the pump...
    Started by Rockman59‎, 09-11-2013 07:18 PM
    2 Pages
    1 2
    10-14-2013 07:05 PM Go to last post
  13. autoclear plus error code 94
    I have an autoclear plus that is giving an error code of 94. Checked cell and it is clean, salt level is good although not reading correctly. Pool...
    Started by Micnic‎, 10-13-2013 10:54 PM
    10-14-2013 11:27 AM Go to last post
  14. Mineral Springs system not generating.
    My Mineral Springs system continues to show "no flow". We balanced the water & got it right, then added the salt. Still shows "no flow" & I am...
    Started by RandiBGood‎, 06-12-2012 02:30 PM
    pix2fix
    10-10-2013 03:19 PM Go to last post
  15. Cause of calcium/scale buildup on perimeter tile.
    I have a tremendous amount of white deposit on my tiles and suspect it is caused by the Salt water chlorine device as it produces enough calcium...
    Started by poolaris‎, 10-01-2013 03:53 PM
    10-09-2013 11:07 PM Go to last post
  16. Mineral Springs No Flow light not working
    We have a bioguard Mineral Springs unit and the no flow light stays off even when pump turning on (which is usually when light blinks for a few...
    Started by ezzellce‎, 10-07-2013 02:14 PM
    10-08-2013 03:37 PM Go to last post
  17. Intellichlor ic40 - no cell light, life at 60% only 1 year old help!!!
    I had a pentair intellichlor ic40 installed last summer. The cell light is off and will not come on, even with the output at 100%. The salt level...
    Started by kimspool‎, 06-29-2013 05:53 PM
    09-30-2013 10:29 PM Go to last post
  18. PoolPilot warning check/clean cell???
    My Pool Pilot is giving me the warning check/clean cell. I added 50 lbs of salt (now at 3300ppm), my power level is at 2, cell=17v 3.9a, software...
    Started by MommaMichele‎, 09-02-2013 01:16 PM
    09-30-2013 06:58 PM Go to last post
  19. swan floater
    http://www.saltpoolguys.com/autopilot-pool-pilot-ag/ When I was researching these. Any type of review was scarce. Even the salesman did not have...
    Started by bssage‎, 08-24-2013 04:33 PM
    09-18-2013 02:45 AM Go to last post
  20. Winding Up My First Season with an SWCG.
    After 2 summers where I was away for 2 or 3 weeks, and knowing I'd be away at least 6 weeks (2 in May, 4 in July), I decided that a salt-water...
    Started by CarlD‎, 09-01-2013 02:09 PM
    09-03-2013 01:16 PM Go to last post
  21. Keeping pH stable with SWCG
    I thought I post my experience with keeping pH stable when using a SWCG. I use to follow the recommedation on my Taylor test kit and kept TA at...
    Started by JimK‎, 08-31-2013 12:04 PM
    09-02-2013 02:41 PM Go to last post
  22. Question Can anyone tell how to recalibrate a Mineral Springs MS10 Salt Generator?
    I have a Mineral Springs MS 10 salt generator that is flashing high cell, i replaced the cell with a Turbo Cell a couple years back and everything...
    Started by NESPORTZDAWG‎, 08-12-2013 11:46 AM
    mineral springs, sticky, swcg
    09-01-2013 05:50 PM Go to last post
  23. Aqualink - To Flow or not to Flow? Bad Cell?
    I have a Jandy Aqualink RS (Purelink) with A Jandy 1400 Salt Cell. I was having the dreaded "no flow" (sometimes no service code lights and other...
    Started by cjpink‎, 08-11-2013 06:01 PM
    08-19-2013 10:53 PM Go to last post
  24. Intex SWCG at Walmart
    I saw this today at Walmart kit and it made me curious because people had been talking about these costing close to $1000. I wondered if anyone had...
    Started by inultus‎, 08-06-2013 01:41 PM
    08-12-2013 03:43 PM Go to last post
  25. Pentair IC40 Chlorinator Power Problem
    I noticed that the Power LED is not lit (neither red nor green) on the IC40. I acid washed the IC40 as it was very dirty and completely plugged...
    Started by JMarko‎, 08-10-2013 02:01 PM
    08-12-2013 11:30 AM Go to last post
  26. aquarite stopped working, but simple fix saved me hundreds
    Wanted to pass this on to a forum that has helped me so much. My AG aquarite SWG was working fine for 5+ years, then started blowing fuses. After...
    Started by rallan‎, 08-05-2013 09:21 PM
    08-06-2013 10:39 AM Go to last post
  27. Conversion to salt water chlorination: pro and con
    Hi Pool Doc, The salt water questions are what I'm looking for. Maybe you can help. I have read allot of saltwater systems. And like anything...
    Started by merlin‎, 08-03-2013 10:25 AM
    sticky, swcg
    08-04-2013 08:33 PM Go to last post
  28. Red face Jandy Aquapure 1400
    Getting error code 170. Any suggestions?
    Started by mldurham‎, 08-03-2013 10:54 AM
    08-03-2013 09:28 PM Go to last post
  29. New Member... SWCG operation problems
    Hello all, long time pool owner first time forum member. I have had a pool pretty much every where I have lived here in Florida, from a Intex above...
    Started by pnltybox‎, 07-31-2013 11:58 AM
    08-02-2013 10:15 PM Go to last post
  30. Cloudiness
    With goggles on underwater and your chemicals are "suppose" to be correct should the water be some what cloudy cause of the salt? Or should it be as...
    Started by Skelly607‎, 07-19-2013 10:16 PM
    08-01-2013 05:10 PM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
