+ Post New Thread
Page 12 of 36 FirstFirst ... 2 10 11 12 13 14 22 ... LastLast
Threads 331 to 360 of 1057
Forum: Salt Generators (SWCG) & other Chlorine Feeders
Trichlor feeders, salt-based generators and systems, feed pumps, and more.
  1. Sticky Thread Sticky: SWCG (Salt Water Chlorine Generators) - Pro & Con
    ______________________________________ SWCG (Salt Water Chlorine Generators) - Pro & Con Even though 30+ years in the pool business has taught...
    Started by PoolDoc‎, 06-15-2018 06:21 PM
    06-17-2018 12:35 PM Go to last post
  2. Sticky Thread Sticky: FAQs & Guides: Salt Water Pool Systems (SWCG) & other Cl feeders
    ________________________________ FAQs & Guides: Salt Water Pool Systems (SWCG) & other Cl feeders ________________________________ Salt...
    Started by PoolDoc‎, 06-03-2018 07:55 AM
    06-03-2018 07:55 AM Go to last post
  1. compatibility of salt systems and stainless steel gutters and bull nose?
    Does any one have info on the compatibility of salt systems for generating chlorine and their compatibility with stainless steel?
    Started by maintman‎, 12-21-2011 10:05 AM
    12-27-2011 03:13 PM Go to last post
  2. Smile Salt PPM increasing
    I have 15000 gallon pool with a Aqua Rite Salt Generator wich I replaced a circuit board in in May. When it was added the salt PPM reading on the...
    Started by kirkdbjl‎, 11-14-2011 01:25 PM
    11-15-2011 10:39 AM Go to last post
  3. Autopilot LS1000 Chlorinator, RC-15 Cell
    I just bought a house that has an old Autopilot LS1000 system with a RC-15 Cell. The red flow light was on so I pulled the tri-sensor to test it...
    Started by winston-rover‎, 11-10-2011 08:44 AM
    11-14-2011 09:15 AM Go to last post
  4. Goldline AquaRite Salt Chlorinator Circuit Board
    I am trying to find the part number from an electrical component next to the SL32 Current Limiter. My circuit board part number is 066012C-1. The...
    Started by maculver‎, 11-09-2011 10:40 PM
    11-14-2011 09:12 AM Go to last post
  5. No Power Light on Goldline Chlorine Generator
    Just noticed that there is no green power light on my control panel. The display works showing temperature and salt concentration, but there is no...
    Started by mirobbi‎, 09-05-2011 01:31 PM
    aqualogic, board failure, sticky
    10-04-2011 04:46 PM Go to last post
  6. Aqua Rite SWG Main Board bad component
    I have a Goldline SWG and the main board (part number 066012C-1 Rev C) had a bad component on it. It is the large black round resistor? marked SA...
    Started by Nevets‎, 09-26-2011 12:26 PM
    09-30-2011 05:34 PM Go to last post
  7. Pool Pilot Cell 0V, 11A - what did I do wrong?
    I've had great luck with my Pool Pilot Digital system (10+ years, 2 cells) so I convinced my neighbor to get one when his old Hayward salt unit...
    Started by RobW33‎, 09-12-2011 11:02 AM
    09-29-2011 10:23 AM Go to last post
  8. Low chlorine level with Salt Water System
    Hi I can not seem to maintain an adequate chlorine level in my salt water pool. I have a brand new in-ground liner pool with a salt water chlorine...
    Started by anders73‎, 09-15-2011 10:36 AM
    09-22-2011 08:31 PM Go to last post
  9. Aqua logic false "low temperature"
    Had a power outage that caused problems with our Aqua Logic PS8. After fixing "Chlorinator Off - No Cell Power" error (required re-soldering a relay...
    Started by desoto‎, 09-22-2011 07:49 PM
    09-22-2011 07:49 PM Go to last post
  10. Aqualink Problems HELP
    I'm brand new here so please bear with me. Our Aqualink RS6 completely died this morning. The inside control panel and the outside panel will not...
    Started by SharonG‎, 09-18-2011 01:00 PM
    09-21-2011 07:47 AM Go to last post
  11. salt conversion gave brownish stains
    Hello and thanks in advance for any help. I just installed an Prologic salt system on a vinyl liner pool I built about 6 years ago. I dumped 400...
    Started by JackandJibby‎, 09-19-2011 01:47 PM
    09-20-2011 08:10 AM Go to last post
  12. Question Pump run time for Salt Generator
    How many hours a day do you need to run your pump with a salt generator, do you need to turn the water over once or does it have to run 24/7. Thanks
    Started by hummingbird‎, 09-17-2011 09:55 PM
    09-18-2011 11:38 AM Go to last post
  13. CompuPool CPSC36 salt cell melted or burned
    I have a CompuPool CPSC36 operating with my 25,000 inground vinyl pool. It was installed about August 30 of last summer, and we closed the pool in...
    Started by Jodester‎, 09-05-2011 11:29 AM
    fixed-pix
    09-13-2011 07:31 PM Go to last post
  14. Red face Pool vac results
    I needed to change out a very old Hayward vac. My pump is a itelliflo vf pushing about 32 gal per minute. This keeps operating cost way down. I...
    Started by cyclingbro‎, 09-13-2011 07:01 PM
    09-13-2011 07:01 PM Go to last post
  15. Salt Water Pool Conversion
    New to the forum and just bought a house that came with a salt water pool. I have a a Zodiac Clearwater Lm2-24 system and it has been nothing but a...
    Started by jskins2000‎, 09-05-2011 12:17 AM
    2 Pages
    1 2
    09-08-2011 06:42 PM Go to last post
  16. AquaPure 1400 Error Codes 172 181
    My Aquapure 1400 (4th summer) has service codes 172,181. Cleaned sensors with scrubbie pad and tested board with 1 number different than what they...
    Started by Timothy R.‎, 09-06-2011 08:04 PM
    09-07-2011 12:46 PM Go to last post
  17. The Sun
    Alright, many moons ago, I was a member here -- but I've been inactive for *years*, and am just now re-joining. 'Course, my pool has *also* been...
    Started by Interloper‎, 09-01-2011 10:27 AM
    stabilizer, sticky
    09-05-2011 12:45 PM Go to last post
  18. Unusual green stuff coming from salt water chlorinator
    Hi all. We started using an Intex salt water chlorine generator this year. This model of their generator has a copper ion generator that is used...
    Started by codes4food‎, 09-04-2011 07:50 PM
    09-05-2011 11:23 AM Go to last post
  19. Aquapure 1400 maintainence
    I am using an Aquapure 1400 system in my 12,000 gallon plaster pool. I seem to have a significant amount of build-up, (calcium??) in the salt cell....
    Started by newmaac‎, 08-28-2011 03:46 PM
    08-31-2011 09:07 PM Go to last post
  20. Pool Pilot Digital: Check/Clean Cell Message
    I have a Pool Pilot Digital running at power level 2 with an SC-36 cell. I replaced the cell at the beginning of this season, as it had gone over...
    Started by howlandonline‎, 08-18-2011 10:22 AM
    08-29-2011 03:09 AM Go to last post
  21. My First post - high salt?
    Hello Everyone, My pool: 15,500 gal, Colored Plaster, Attached Spa, Flagstone (although it's more like Sandstone - more on that maybe in a later...
    Started by jonnymac‎, 08-20-2011 01:23 PM
    2 Pages
    1 2
    salt damage, sticky, stone damage, swcg problems
    08-25-2011 11:17 PM Go to last post
  22. Review-Hayward Swimpure SWCG up to 40,000 gallons
    First off- a few details. IG Gunite Pool Approx. 18,000 gallons. Pentair Whisper-Flo 1-HP single speed pump Pentair Tagelus 60D Sand Filter...
    Started by TheGoose‎, 08-06-2011 03:14 PM
    08-23-2011 09:03 PM Go to last post
  23. Salt system with small Easyset?
    I'd like some advice for setting up a SWCG with a small (10 or 12 foot) above ground pool. I found an Intex 8110 for a good price. Has anyone used...
    Started by dozerdude‎, 08-22-2011 05:57 PM
    08-23-2011 02:44 PM Go to last post
  24. Aqua Rite sizing question
    I'm looking at replacing my QuikChlor system with an Aqua Rite. My pool is apprx 12,800 gals---should I go with the 15k or 25k system? Would going...
    Started by steveinaz‎, 06-23-2010 11:54 AM
    08-22-2011 11:47 AM Go to last post
  25. Diamond Crystal 40 Lbs. Iron Reduction Salt Pellets
    Is it safe to use this salt from Lowes in a salt generator-ed pool? ...
    Started by Jasheon‎, 08-22-2011 09:27 AM
    08-22-2011 10:36 AM Go to last post
  26. AquaPure 1400 issues
    I have a four year old Jandy AquaPure 1400. This year I've been getting service lights and error codes referring to low voltage. I've swapped out...
    Started by Fhelfrich‎, 08-20-2011 03:08 PM
    08-21-2011 06:31 PM Go to last post
  27. Erratic (or intermittent?) Control Box for Pool Pilot Digital DIG-220
    Here's my problem. (I'm writing this on Sunday 8/21/11) Last Wednesday when I got home from work at about 4PM I saw that my pool pump (which is...
    Started by ronbar‎, 08-21-2011 05:58 PM
    08-21-2011 05:58 PM Go to last post
  28. Aqua Rite low salt reading when salt has been tested high
    Hi, i just had my turbo cell tested at my local pool store and it passed so the cell is in working order. Whe i turn the SWG on, the green power...
    Started by DirtRider67‎, 08-19-2011 02:51 PM
    08-19-2011 04:58 PM Go to last post
  29. Salt Cell Replacement
    How do I know when it's time to replace my salt cell Thanks
    Started by JimSentry‎, 06-24-2011 07:53 AM
    08-19-2011 04:01 PM Go to last post
  30. Recent problems with erratic readings from my 3 year old Pool Pilot Digital DIG-220
    My 15k gallon pool was completely rebuilt about 3 years ago in 2008, and we opted for a salt water generating system. The pool contractor installed a...
    Started by ronbar‎, 08-15-2011 07:28 PM
    08-16-2011 04:03 PM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
