+ Post New Thread
Page 4 of 36 FirstFirst ... 2 3 4 5 6 14 ... LastLast
Threads 91 to 120 of 1057
Forum: Salt Generators (SWCG) & other Chlorine Feeders
Trichlor feeders, salt-based generators and systems, feed pumps, and more.
  1. Sticky Thread Sticky: SWCG (Salt Water Chlorine Generators) - Pro & Con
    ______________________________________ SWCG (Salt Water Chlorine Generators) - Pro & Con Even though 30+ years in the pool business has taught...
    Started by PoolDoc‎, 06-15-2018 06:21 PM
    06-17-2018 12:35 PM Go to last post
  2. Sticky Thread Sticky: FAQs & Guides: Salt Water Pool Systems (SWCG) & other Cl feeders
    ________________________________ FAQs & Guides: Salt Water Pool Systems (SWCG) & other Cl feeders ________________________________ Salt...
    Started by PoolDoc‎, 06-03-2018 07:55 AM
    06-03-2018 07:55 AM Go to last post
  1. Autoclear Plus SWCG question
    Hi everyone, I'm kind of a noob with pools, I bought this house with a 3yr old pool it came with an Autoclear Plus Saltwater Cl2 generator. It...
    Started by ngc1068‎, 05-25-2014 09:32 PM
    05-27-2014 04:28 PM Go to last post
  2. Digital Pool Pilot Low Amps Reading Solved (Hint - No New Cell Needed)
    I've had Digital Pool Pilot SC-48 cell system on my pool since about 2006 when the pool was built. In 2008, I got a low amp reading and figured it...
    Started by ghanner‎, 05-25-2014 10:41 AM
    05-25-2014 12:59 PM Go to last post
  3. SWG for use with liquid bleach?
    If I am using liquid bleach which adds salt, the TDS increases in the pool. Can I use a cheap SWG to use the salt in the pool to help with the TDS...
    Started by bearsprague‎, 05-23-2014 03:08 PM
    05-25-2014 07:27 AM Go to last post
  4. Jandy Aquapure error 188 and 170
    I have an error code 170 that indicates I have a low voltage. I can unplug the sensor and the error goes away but comes back once I reconnect. ...
    Started by telston‎, 05-20-2014 08:56 AM
    aqualink, aquapure, purelink
    05-21-2014 06:33 PM Go to last post
  5. Pentair intellichlor upgrade
    I currently have a pentair CL20 that has gone bad and am going to replace it. My question is would I benefit from moving up to a CL40 & can I...
    Started by Smonahan0129‎, 05-16-2014 08:32 AM
    05-20-2014 04:17 PM Go to last post
  6. SGS opinion
    I'm going to be getting a SWCG installed this week. I haven't decided on a brand yet but friend of mine that does pool construction is recommending...
    Started by l1tech‎, 05-12-2014 10:59 PM
    05-19-2014 06:20 PM Go to last post
  7. Need new salt opinion
    I am thinking of a salt system for my pool. piping will be no problem as I have plenty of room for the salt cell. I'm wondering if it's worth the...
    Started by dansdad‎, 05-18-2014 03:04 PM
    05-19-2014 04:50 PM Go to last post
  8. Mineral Springs Aqua Rite
    Hi, Can anyone tell me where I can get the metal lever bracket which seals the door on the Unit closed? This season its mia and I have looked all...
    Started by bethsg‎, 05-18-2014 10:39 AM
    05-18-2014 10:39 AM Go to last post
  9. newbie, salt pool, cyanuric acid (stabilizer) levels?
    I'm new to this forum but have been successfully looking after my salt pool for about 5 years. My salt cell (jandy aquapure) requires 50-75ppm for...
    Started by Cats59‎, 05-13-2014 07:16 PM
    sticky, sticky-swcg
    05-17-2014 04:03 PM Go to last post
  10. Solaxx SALRET20A SWCG for Intex Pool?
    I have an Intex 24' X 52" Above Ground Pool. I have gone through (3) Intex Krystal Klear Saltwater Systems in 3 years. I want to stay with a Salt...
    Started by swjwjw‎, 05-12-2014 11:36 AM
    05-14-2014 05:08 PM Go to last post
  11. Upgrading "Poolthing" SWCG
    Looking to up grade my Poolthing SWCG as I need a new cell. The cost of a T-15 cell replacement in a aftermarket cell like compupool is Making a...
    Started by larfulker‎, 05-08-2014 04:25 PM
    05-13-2014 11:27 AM Go to last post
  12. AquaPure 1400 error message
    I have an AquaPure Apure 1400 that is giving a 170 error message. Does anyone know how to trouble shoot the circuit board?
    Started by miketybee‎, 05-08-2014 07:29 AM
    05-12-2014 04:13 PM Go to last post
  13. Salt-Chlorine Generator
    I have a 13x36 ingound pool for 25yrs and have always used chlorine 3" tabs. I am having the liner replaced and am interested in installing a...
    Started by bbeau62‎, 05-05-2014 11:10 AM
    05-10-2014 01:45 PM Go to last post
  14. AquaPilot - no power to cell
    Noticed some green algae on my pool walls last week - checked my control panel which said check cell, and the reading said 0 amps and 0 volts. Cell...
    Started by rcenturion‎, 05-01-2014 12:44 PM
    05-08-2014 11:46 AM Go to last post
  15. Pool Pilot Digital. Low Amps check cell?
    Help!? Pool Pilot Digital. Low Amps check cell? (Brand new cell) Test Pool Pilot: 16V 1.5 Looks like all the fuses are ok. salt : 3100...
    Started by Bobdog‎, 05-04-2014 02:28 PM
    05-08-2014 11:44 AM Go to last post
  16. Smile Combined Chlorine in Pool
    Can you overcome a combined chlorine problem with a salt water generator running on superchlorinate. I am not getting a free chlorine reading when I...
    Started by PKing‎, 05-08-2014 09:03 AM
    05-08-2014 09:27 AM Go to last post
  17. Pentair 320 trichlor feeder has stopped working
    My chlorine tab feeder was easily eroding 4 pucks per week. Now it doesn't seem to erode one. It fills properly with the top off and drains within...
    Started by Arlington88‎, 05-05-2014 03:50 AM
    05-08-2014 12:05 AM Go to last post
  18. In-line Chlorine Feeders VS Chlorine Floaters
    I need to replace my Hayward CL200 inline chlorine feeder. Looking online to get a replacement I have just found that these are inefficeint and...
    Started by wgbixler‎, 05-01-2014 11:34 AM
    05-01-2014 12:43 PM Go to last post
  19. Hayward Pro Logic PS-4 or Aqua Rite - new pool install
    Hi all, Installing a new salt water inground pool. Going with Hayward products per our installer. Trying to decide on the SWG system. Any...
    Started by Chriscanada‎, 04-29-2014 10:35 AM
    04-29-2014 10:35 AM Go to last post
  20. TCO for salt vs. Traditional chlorine system
    Does anybody know what the typical total cost of ownership (TCO) for a salt vs. traditional chlorination system for the first year vs. each...
    Started by jasondoiron‎, 04-20-2014 01:02 PM
    04-25-2014 08:38 PM Go to last post
  21. SWCG or Power Ionizer?
    I have a 30" AG pool and I have been using the pool frog chemical system for the past 7 years. Living in northeast Ohio, I get 3 to 4 months out...
    Started by Gavrick‎, 04-19-2014 04:56 PM
    sticky
    04-23-2014 03:31 PM Go to last post
  22. autopilot
    I have a new auto pilot dig 220 control panel with swg installed. I paid pool company to install. After about 2weeks it blew fuse to display panel....
    Started by cripwick‎, 04-18-2014 09:34 AM
    04-19-2014 01:53 PM Go to last post
  23. Advice on selection of SWGC
    Hi All! We have a 11 year old, white plaster, in-ground pool. Anthony and Sylvan did not offer Salt Water Generation in our area when we built...
    Started by u69911?!‎, 04-13-2014 07:14 PM
    04-16-2014 10:34 AM Go to last post
  24. Accidentally added salt while in boost mode
    Just got back from pool dealer and needed to add one bag of salt and stabilizer. We had turned the pool up to65% and kicked in boost about 5...
    Started by Mdl28‎, 04-12-2014 11:07 AM
    04-13-2014 10:42 AM Go to last post
  25. Aquapure/Aqualink salt system
    My pool company (which I no longer have) let the salt get to low. I noticed the service light on the aquapure and added salt, cleaned both cells...
    Started by clowman150‎, 04-06-2014 06:49 AM
    04-09-2014 02:12 PM Go to last post
  26. Baquacil to Chlorine...How to make chlorination more automated.
    When I open my pool this season, I will be switching over to Chlorine from Baquacil. I have seen several different kinds of feeders for the chlorine,...
    Started by js8390‎, 04-02-2014 07:27 PM
    feeders, sticky
    04-03-2014 08:35 AM Go to last post
  27. What is the difference between a unit for IG vs AG
    In other words can you use a AG unit in an IG pool? Why or why not?
    Started by cinnamon01‎, 03-23-2014 08:10 PM
    2 Pages
    1 2
    03-26-2014 07:31 PM Go to last post
  28. Mineral sterilization vs salt water pool
    I met with a pool contractor who says he used to do saltwater pools but people were having rusting out of lights, pool furniture etc. He says he has...
    Started by tropicdoc‎, 03-21-2014 02:11 PM
    03-22-2014 12:55 PM Go to last post
  29. Problems with SWCG (salt water chlorine generator) on inground pool
    I have an inground pool 18x36 vinyl liner with salt chlorinator. I'm having fits with the salt cell. It's jandy aquapure 1400. Even after the triple...
    Started by jdubose‎, 03-21-2014 07:36 PM
    03-22-2014 09:16 AM Go to last post
  30. Salt Water Conversion
    I have only been through one season with my 22k/gallon in-ground pool and it was not a pleasant experience trying to keep it clean. I was doing okay...
    Started by Groovgal‎, 01-12-2014 02:26 PM
    03-19-2014 07:40 PM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
