+ Post New Thread
Page 4 of 32 FirstFirst ... 2 3 4 5 6 14 ... LastLast
Threads 91 to 120 of 944
Forum: Dealing with Algae & Slime
Green & slimey, mustard lined, pink in the pipes, black algae mats; Green Treat, Yellow OUT, Yellow Treat, copper algaecides, & more.
  1. Sticky Thread Sticky: Dealing with mustard algae
    Mustard algae tends to be very chlorine resistant, and tends to reoccur. Most algaecides are ineffective against it. There are several options, but...
    Started by PoolDoc‎, 06-18-2014 09:29 AM
    04-22-2020 03:57 PM Go to last post
  2. Sticky Thread Sticky: Algae . . . or something else? Recognizing & treating pool algae successfully.
    _____________________________________ Algae . . . or something else? Recognizing & treating pool algae successfully. this post . ] ...
    Started by PoolDoc‎, 06-24-2018 07:18 PM
    06-25-2018 11:19 AM Go to last post
  3. Sticky Thread Sticky: FAQs & Guides: Dealing with Algae
    ____________________________________ FAQs & Guides: Dealing with Algae Algae . . . or something else? Recognizing & treating pool algae...
    Started by PoolDoc‎, 06-24-2018 05:18 PM
    06-24-2018 05:18 PM Go to last post
  1. First timer with AG pool that won't clear up
    First time homeowner with new pool and struggling to get the water looking correct. I have a Hayward sand filter. Pool is an above ground and I can...
    Started by Cflynn22‎, 06-12-2014 06:38 AM
    06-14-2014 05:05 PM Go to last post
  2. PLEASE HELP--Chemicals balanced but have algae
    Hi. In April of this year we had our liner replaced in our in-ground pool. Water has been great up until last 2 weeks. Chemicals are balanced and...
    Started by aesweeps‎, 06-10-2014 10:21 PM
    06-13-2014 09:56 PM Go to last post
  3. Black Algae
    I started a post under Dealing with Stains and Metals back on May 19th . -- Help unsure if Black Algae ?After determining it is a organic stain...
    Started by gfritz1‎, 06-03-2014 03:12 PM
    06-13-2014 08:40 PM Go to last post
  4. Angry Persistent Cloudy Water in AG pool
    We opened the pool a month ago and it was green. We shocked and turned light blue and cloudy and now the water ph is 7.6 and cl 1.5. Still cloudy...
    Started by sukitag16‎, 06-10-2014 07:30 PM
    06-13-2014 08:04 PM Go to last post
  5. Can't get rid of dead algae
    Hello! We have a 28ft above ground pool not a year old yet and we are having a bout with dead algae. We didn't cover it over the winter and got some...
    Started by Cleggette‎, 06-09-2014 08:19 PM
    2 Pages
    1 2
    sticky, sticky-ag-pumpfilter
    06-12-2014 09:53 PM Go to last post
  6. Unhappy Pool Owner Woes – FNSP60 Pressure & Algae
    Problem: Recurring algae – Pressure in filter jumping from 17 PSI to 35 in 1-2 hours Background: I purchased a home with a pool about a year ago...
    Started by Mattmig‎, 06-09-2014 06:54 PM
    06-11-2014 11:51 AM Go to last post
  7. Unhappy Pool very dirty day after use.
    Used the pool for the first time yesterday. Put in my cholrine (dichlor) last night and left the filter run. Came out today and there was dirt or...
    Started by Scrapple‎, 06-08-2014 05:02 PM
    06-11-2014 10:50 AM Go to last post
  8. Pool Startup -- Algae + DE filter
    Hi. I am trying to get things up and running for the summer (like so many others). I have a 17,000 gal inground vinyl lined pool, Jandy60 DE...
    Started by bjb1966‎, 05-22-2014 01:51 PM
    06-10-2014 02:50 PM Go to last post
  9. Reoccurring algae problem
    I too am a newbie to this forum, thank you. I've been having an issue with green algae, it seems like every other day after I vacuum and brush the...
    Started by 100%lemonhead‎, 06-09-2014 06:15 PM
    06-10-2014 02:48 PM Go to last post
  10. White gritty scale
    Hello, I am new here and have a problem with a white gritty substance on my pool walls no one can seem to figure out. Hoping to get some answer to...
    Started by Wapak‎, 06-05-2012 03:12 PM
    5 Pages
    1 2 3 ... 5
    gritty, sand algae, sand-algae, scale
    06-10-2014 09:48 AM Go to last post
  11. having trouble with a cloudy pool
    Hello, Ive been struggling opening up my pool this summer. I neglected the pool over the winter and it got dark green, almost black. I just...
    Started by adambeazley‎, 05-14-2014 11:25 PM
    3 Pages
    1 2 3
    attaboy
    06-10-2014 12:40 AM Go to last post
  12. Post adding algaecide
    does adding an algaecide to your pool help keep alge down or does is truly help kill your chlorine?
    Started by sobrien2‎, 06-06-2014 05:43 PM
    06-08-2014 06:04 PM Go to last post
  13. 18 x 36 filled with algae
    salt water pool 18x36 - cover all winter - after opening it pump died and pool sat open for a week with out water moving - had major green algea. ...
    Started by shannon2014‎, 05-27-2014 08:29 AM
    06-08-2014 05:04 PM Go to last post
  14. Question White slimy stuff foating on top of my pool water.
    Thread title says it all. Normally I would just search for an answer to this question, as I'm sure its been asked before. But the registration...
    Started by Scrapple‎, 06-01-2014 04:47 PM
    2 Pages
    1 2
    06-07-2014 10:50 PM Go to last post
  15. green water
    my pool is 16x32. how many gallons is that. Also open to green water , no chlorine reading and ph test says to add soda ash. Water is clearing up...
    Started by Jim Etters‎, 06-04-2014 01:23 PM
    sticky, sticky-swamp-clean
    06-07-2014 10:29 PM Go to last post
  16. cloudy pool
    I have a 42,000 gallon pool, we are having problems with the pool being cloudy. We got it mostly clear and went on vacation for 6 days and came back...
    Started by janelleeve‎, 06-05-2014 11:51 AM
    06-07-2014 07:07 PM Go to last post
  17. Light Teal Pool
    Our pool is light teal and we have put every chemical known to man in it and it will not clear up. All the levels in the pool are where they should...
    Started by Tmali‎, 06-05-2014 10:38 AM
    06-07-2014 04:16 PM Go to last post
  18. My cleanup was much easier this year!
    Since I made the mistake of getting a mesh loop-loc cover 3 or 4 years ago I've opened up to so much algae that my water has been almost black. It...
    Started by TomC‎, 06-07-2014 07:30 AM
    06-07-2014 09:38 AM Go to last post
  19. Wink Beginning of Converting
    As stated earlier, we have used Baquacil and currently converting to BBB. Added the chlorine last yesterday evening. Pool is very green and my hubb...
    Started by bamagirl‎, 05-20-2014 08:46 AM
    2 Pages
    1 2
    attaboy
    06-06-2014 04:01 PM Go to last post
  20. New user with algae
    Hi, I am a new user to this site. I wish I would have found it 30 days ago. I am struggling to get my pool in good working order this season. ...
    Started by DMAC8160‎, 06-03-2014 12:21 PM
    06-06-2014 12:51 PM Go to last post
  21. Very Green Pool
    We have a 25K , vinyl pool, sand filter. I years past we have almost totally used bleach for chlorination. We had a problem this year. It was losing...
    Started by marciastz‎, 05-17-2014 09:23 AM
    2 Pages
    1 2
    06-04-2014 01:25 AM Go to last post
  22. My pool is out of control and swampy
    I had never had a pool before and I bought a house with a pool 8(!) years ago. You would think that I would be better at this by now. I have an...
    Started by QuidStuprum‎, 05-28-2014 03:19 PM
    2 Pages
    1 2
    06-02-2014 10:29 PM Go to last post
  23. *SIGH* Looks Like I Have da' Mustard
    "Cowardly, cowardly Custard... Can't cut the mustard!" Well, it's time to divert my previous thread:...
    Started by Tom.B‎, 05-20-2014 07:55 PM
    4 Pages
    1 2 3 ... 4
    attaboy, sticky, sticky-history, sticky-mustard, sticky-phosphate
    05-31-2014 02:00 PM Go to last post
  24. Cloudy water, but blue
    My pump quit on me and I ordered a new one online. However, when it got here didn't get around to replacing it (winter in Florida so I wasn't in a...
    Started by dougfoot‎, 05-22-2014 08:19 PM
    sticky, sticky-floc
    05-29-2014 02:22 PM Go to last post
  25. battling green algae while cya = 0
    opened up our pool this year and it was much greener than ever before. In fact, we couldn't see the pool bottom. I have a good testkit, initial test...
    Started by vinouspleasure‎, 05-28-2014 08:31 PM
    05-28-2014 10:48 PM Go to last post
  26. bleach doses and algae
    My stabilizer got to high, don't know the number sorry. I stumbled on this forum and some answers read lots of stuff. I use 3" puks. What I did...
    Started by karen936‎, 05-25-2014 01:02 PM
    05-28-2014 02:50 PM Go to last post
  27. Unhappy Pool water is green
    We have shocked- adjusted ph and brushed until our muscles ache but still can not get a blue clear pool. any suggestions?
    Started by PamCal‎, 05-22-2014 06:24 PM
    3 Pages
    1 2 3
    05-27-2014 06:58 PM Go to last post
  28. Having issues with Algae
    I'd read a forum before I registered that gave advice for a 17,000 gallon pool. The problem the original poster was having was that live algae was...
    Started by pamandring‎, 05-24-2014 01:13 PM
    05-27-2014 03:47 PM Go to last post
  29. Vinyl liner feels like and looks like sandpaper
    20x40 inground diving pool. Liner is 3 years old. I've been a pool owner for 14 years and this is the first time I have experienced this. Took...
    Started by brianp‎, 05-23-2014 10:40 AM
    05-25-2014 05:30 PM Go to last post
  30. Using well water and historic problems with mustard algea
    New forum user. Doughboy above ground 28 round 18000 gallons 225# sand filter with 1 hp pump. Just south of Atlanta. Believe my historic issues...
    Started by karl_ga‎, 05-13-2014 02:57 PM
    05-20-2014 04:28 PM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
