+ Post New Thread
Page 4 of 12 FirstFirst ... 2 3 4 5 6 ... LastLast
Threads 91 to 120 of 332
Forum: Dealing with Alkalinity and Calcium
High alkalinity and calcium levels are much trickier to resolve than the pool books indicate
  1. Exclamation Sticky Thread Sticky: FAQs & HOWTOs: Swimming Pool Alkalinity
    HOWTO: Step-by-Step Guide to lowering your alkalinity The HOW-TO has moved here: lowering-swimming-pool-alkalinity-step-by-step.html You should...
    Started by PoolDoc‎, 03-29-2006 10:50 AM
    06-05-2006 01:53 PM Go to last post
  1. Calcium and hard water
    I have very hard water and when I add water to the pool it raises the Calcium hardness significant (greater than 800ppm). The water gets cloudy. ...
    Started by ColinGallagher‎, 06-17-2012 07:10 PM
    06-19-2012 10:22 PM Go to last post
  2. Lime Softening to Reduce Excess Hardness - Bucket Test & Treatment Process
    ------- 2018 - Do NOT use this process without talking to me (PoolDoc) first -------- ---------- If you are unable to reach me, try an...
    Started by PoolDoc‎, 06-19-2012 04:26 PM
    #faq
    06-19-2012 04:26 PM Go to last post
  3. sandpaper sides in newly opened pool
    OK you experts, should have come here first but..... Now that Im broke after spending over $200.00 to get this hole in the ground open let me tell...
    Started by chich‎, 06-04-2012 04:25 PM
    06-17-2012 07:36 PM Go to last post
  4. Why Borax in The Skimmer?
    ive read here that borax should be added to the skimmer, but broadcasting seems to never be mentioned. im curious as to why it gets added through the...
    Started by Darkside‎, 06-13-2012 04:43 PM
    06-14-2012 09:07 PM Go to last post
  5. High PH and Correct Alk
    Hi, I have a concrete indoor pool with a coverstar electric cover. I have been battling with pool water chem for several months now. My PH is...
    Started by blentz‎, 06-13-2012 08:04 PM
    06-14-2012 01:34 AM Go to last post
  6. Calcium deposits or sand algae
    First time in over 20 years and I have white gritty deposits all over the bottom of my vinyl liner. 16x32 above ground with a 7 foot deepend. ...
    Started by malfar‎, 06-12-2012 11:18 PM
    sand-algae
    06-13-2012 11:09 PM Go to last post
  7. stain/scale on bottom of pool
    Hello. Been a reader here for years but this is my first post. I have a tan colored stain/scale on the bottom of my in ground 25,000 gal. vinyl pool....
    Started by bjseeberg‎, 06-11-2012 01:56 PM
    06-13-2012 10:07 PM Go to last post
  8. high calcium
    I finally have my new testing kit (K-2006C), and I am enjoying revisiting basic high school chemistry labs. Most of my numbers are good (see below)...
    Started by alisonquilts‎, 06-10-2012 04:04 PM
    06-10-2012 07:03 PM Go to last post
  9. Pool liner feels like sandpaper
    I noticed a previous post about this, but it was an igp, mine is an agp. I have no idea how to deal with it. The pool store gave me some scale...
    Started by pleasehelp‎, 05-29-2012 05:02 PM
    2 Pages
    1 2
    06-03-2012 08:26 PM Go to last post
  10. Total Alkalinity=0, yes zero!
    Need a little help with this one because I've never seen this before. My neighbor opened his pool yesterday (24K gal vinyl IG pool, Chlorine)....
    Started by myLABSpool‎, 05-20-2012 09:53 AM
    06-03-2012 12:51 PM Go to last post
  11. Dropped alkalinity today
    After I got my pool up and running, it was time to drop the Alkalinity numbers. I read the instructions here on how to do that with acid and...
    Started by sabres07‎, 05-30-2012 04:32 PM
    05-30-2012 05:13 PM Go to last post
  12. Scale?
    Hi All! I really hope this is an easily answered question...My hubby took off our cover this past Wed. night, we planned on doing this on the...
    Started by Andrea B‎, 05-28-2012 01:29 AM
    05-29-2012 07:33 PM Go to last post
  13. mineral deposits on my pool liner??
    I have a 20,000 gallon inground liner pool with a SWG, we opened it this year to find hard deposits on the bottom of the liner in the corners, which...
    Started by Eejwac‎, 05-28-2012 09:53 AM
    05-28-2012 03:58 PM Go to last post
  14. Ph and alkalinity low, should I wait to adjust
    Vinyl liner, ph 7.0, alkalinity 60, chlorine 8.0, I don't know what cya is or how to test for it. Anyways, every year, my alkalinity goes off the...
    Started by Cincin5000‎, 05-12-2012 02:02 PM
    2 Pages
    1 2
    05-28-2012 12:08 PM Go to last post
  15. High pH
    I have an inground pool in Florida. It has an Aqua-Rite Chlorinator, and solar heater. The pool is about 7 years old and has not be much of a...
    Started by Philsludge‎, 05-23-2012 10:52 AM
    05-25-2012 05:18 AM Go to last post
  16. Household Chemical for hardness
    Is there a household chemical I can use to increase water hardness?
    Started by arobinstk‎, 05-15-2012 08:13 PM
    05-25-2012 12:11 AM Go to last post
  17. Cool High PH and Low Alkalinity?
    Hi, I'm new to the forum! :) I have a new pool and I'm a little confused about this issue. I had my water tested today and was told I had a high PH,...
    Started by Neo Seeker‎, 09-29-2011 07:31 PM
    05-23-2012 09:38 PM Go to last post
  18. Exclamation What is hardness?
    what role does "hardness" play in the overall balancing of a pool?
    Started by jerome‎, 05-06-2012 06:36 PM
    05-08-2012 11:45 AM Go to last post
  19. Morton Action Melt Blend?
    Can anyone find the percentages of Calcuim Chloride/Sodium Chloride in this? If my plaster repairs go well I'll be refilling SW pool and might need...
    Started by txhomebrew‎, 04-28-2012 10:30 AM
    04-28-2012 03:31 PM Go to last post
  20. Low CH
    I understand by reading on the forum that calcium hardness doesnt matter on an AG vinyl pool, but can really low CH cause any damage to my heater? ...
    Started by Phenom300‎, 04-23-2012 08:46 AM
    04-24-2012 11:58 AM Go to last post
  21. Cool A cheaper alternative to Grocery Store Baking Soda....
    For all of you out there that need on the order of 50+ lbs of baking soda a year.... Try your local Farmer's Co-Op. They use sodium bicarb as a...
    Started by msumoose‎, 04-13-2012 10:07 AM
    2 Pages
    1 2
    04-20-2012 12:41 PM Go to last post
  22. Vinyl liner feels like sandpaper
    I've tried searching this one and have found very little information on it anywhere...I did see one post at Troublefreepool.com that talked about it...
    Started by Texas247‎, 03-16-2012 04:04 PM
    04-14-2012 08:30 AM Go to last post
  23. High Calcium
    Hi everyone, My calcium number now has hit 500, and I've noticed that I had to clean my cell more often on my SWG. When the value was around...
    Started by Charlie‎, 10-03-2011 12:02 AM
    10-03-2011 08:40 AM Go to last post
  24. Alkalinity
    I bought a house three years ago with an older in-ground pool so I am a relative newcomer. I consistantly have a problem keeping the ALK in the...
    Started by bobgard‎, 08-01-2011 08:13 PM
    08-09-2011 01:28 PM Go to last post
  25. Pool Ladder Scaling?
    I hope this is the correct place for this inquiry! I have a 3 year old used AG pool we just erected. It came with a white plastic ladder that lifts...
    Started by Labpool‎, 08-07-2011 06:17 PM
    08-08-2011 10:11 PM Go to last post
  26. Angry Calcium Bicarbonate Cloud
    I added Calcium + and Alkalinity + to my pool too close together and now my pool is very cloudy. How do I disolve the cloud?
    Started by cypherth‎, 08-03-2011 04:08 PM
    08-03-2011 04:42 PM Go to last post
  27. Battling high alkalinity in new pool
    Hello! I've been reading these forums for quite some time now and I'd like to say they have been extremely helpful! I am a new pool owner; my...
    Started by MadCrammer‎, 06-22-2011 11:08 PM
    2 Pages
    1 2
    lower alkalinity, lower ph, sticky
    07-19-2011 12:58 AM Go to last post
  28. Filtering out calcium
    Anyone know if it's possible to filter out high calcium with a whole house filter ?
    Started by poolEd‎, 07-05-2011 10:48 PM
    07-17-2011 05:53 PM Go to last post
  29. no calcium?
    newbie here. I have a 0 reading for calcium. I have a 16,500 inground vinyl. I read that it can cause pitting on the concrete deck. My deck as pitted...
    Started by shub_31‎, 07-14-2011 09:17 PM
    07-16-2011 11:14 AM Go to last post
  30. Question Total alkalinity
    My total alkalinity is about 22o ppm PH is 7.4 cyanuric acid is about 10-15 ppm total hardness is 100 ppm free chlorine is 3 ppm . should I lower...
    Started by jksmart‎, 07-09-2011 01:34 PM
    07-12-2011 09:09 PM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
