+ Post New Thread
Page 6 of 12 FirstFirst ... 4 5 6 7 8 ... LastLast
Threads 151 to 180 of 332
Forum: Dealing with Alkalinity and Calcium
High alkalinity and calcium levels are much trickier to resolve than the pool books indicate
  1. Exclamation Sticky Thread Sticky: FAQs & HOWTOs: Swimming Pool Alkalinity
    HOWTO: Step-by-Step Guide to lowering your alkalinity The HOW-TO has moved here: lowering-swimming-pool-alkalinity-step-by-step.html You should...
    Started by PoolDoc‎, 03-29-2006 10:50 AM
    06-05-2006 01:53 PM Go to last post
  1. raising alk buy paying too much!
    I went to the pool store to get my water tested. My test kit from Ben has long been out of stock, so I go just to get the numbers. This is a small...
    Started by edarling‎, 06-16-2008 10:25 PM
    06-16-2008 11:35 PM Go to last post
  2. Question Help!, I think I need help, maybe?
    Hello, I was out cleaning the pool today on a beautiful day in Huntington Beach, CA and decided to check more than the Chlorine and pH and the...
    Started by mkfmedic‎, 03-10-2008 07:59 PM
    06-15-2008 08:03 PM Go to last post
  3. Very high calcium and TA
    Good morning to all, I've been a BBB convert for 3 years. I have followed all of the posts here and solved many problems over the years by your...
    Started by smokeygrl‎, 05-24-2008 09:13 AM
    05-24-2008 10:56 PM Go to last post
  4. Is TA 140 too high?
    Opened pool last Friday and treated successfully the "swamp". Taylor kit numbers for pool condition yesterday morning: CYA 60 TA 140 pH 7.9...
    Started by Water_man‎, 05-23-2008 11:58 AM
    05-24-2008 10:11 PM Go to last post
  5. Calcium hardness and fiberglass pools
    I have a small (7000 gallon) fiberglass pool with sparkling clear water using BBB method FAC 5 PH 7.6 TA 80 CH 120 CYA 50 Went to Leslie's...
    Started by aguaguy‎, 05-12-2008 03:43 PM
    05-13-2008 03:17 AM Go to last post
  6. Glass Tiled Pool - Calcium Requirement
    Assuming normal chemical levels and a salt water chlorinator, and the fact that an epoxy grout is used in a completely glass tiled pool what would be...
    Started by smallpooldad‎, 04-04-2008 08:40 PM
    04-04-2008 08:40 PM Go to last post
  7. Late winter tweak?
    Last fall I closed the pool the way I normally do with my chemistry the way I wanted it. Unfortunately, my wife decided to pump the water off the...
    Started by zelmo‎, 03-22-2008 09:53 AM
    03-22-2008 08:21 PM Go to last post
  8. How much is reasonable
    Reviewing past bills from my pool service company, some of the chemical amounts used don't look right. What would be typical amounts of alkanity and...
    Started by DanS‎, 11-14-2007 03:42 PM
    11-16-2007 03:06 PM Go to last post
  9. Baking soda turned my pool green
    My ph was low (a constant problem), reading below the minimum 7.0 on my Taylor test kit, so I added a box of Borax. This created a little cloudiness...
    Started by BigStein‎, 08-10-2007 07:06 PM
    2 Pages
    1 2
    08-12-2007 12:10 PM Go to last post
  10. Question TA "appears" WAY TOO HIGH????
    All other parameters are within normal limits. pH is low at 6.8 - has been running 7.2 for 6 weeks. When I do the Alk test - 2drops #1 - swirl -...
    Started by rferrel1‎, 07-03-2007 08:31 PM
    07-05-2007 02:09 PM Go to last post
  11. Lowering TA with Dry Acid Or Muriatic Acid
    My TA is currently 230. It was recommended on another forum that I lower it according to the "HOWTO: Step-by-Step Guide to lowering your alkalinity"...
    Started by CelticDaddio‎, 06-13-2007 12:55 AM
    4 Pages
    1 2 3 ... 4
    07-05-2007 12:54 AM Go to last post
  12. need a quick reply???
    17000 av ground 1-month after conversion water is very clear:::: added 2 inches of water the other day, i have to shock the pool now but my numbers...
    Started by larry b‎, 06-26-2007 04:21 PM
    06-29-2007 06:07 PM Go to last post
  13. Is My TA ok?
    I have an 18.5k gallon fiberglass pool. I have a de filter pump. My readings are: (I use a HTC test kit, I have a Taylor K-2006 on order) FC =...
    Started by sam98177‎, 06-24-2007 05:20 PM
    06-24-2007 06:56 PM Go to last post
  14. Make sure I have this right - TA and CH
    Just a recap of the knowledge I picked up from many a posts: My pool: 20300 gal AG w/ SWG water is clean and clear CYA - 80 pH - 7.8 FC -...
    Started by Trimom‎, 06-19-2007 03:37 PM
    06-19-2007 03:37 PM Go to last post
  15. Beginning chemicals?
    Well we finally have the pool up and filled. 24' AGP- approx 11,900 gallons. The water man came yesterday with 11,000 gallons of spring water. It...
    Started by Pollysunshine‎, 06-19-2007 11:56 AM
    06-19-2007 02:49 PM Go to last post
  16. Adding baking soda when pH is high??
    I posted below about adding some calcium/alkalinity before going away this weekend. Another issue has arisen. I checked my pH this morning quickly,...
    Started by Henrys514‎, 06-13-2007 03:29 PM
    2 Pages
    1 2
    06-17-2007 03:33 AM Go to last post
  17. How much baking soda can I add in a day?
    I am having a hard time getting my alkalinity up and for it to stay up. I got it test yesterday and it was 24. How much baking soda can I add in...
    Started by mwsigler‎, 06-13-2007 05:22 PM
    06-16-2007 07:45 AM Go to last post
  18. Should I lower TA?
    27000 gallons Inground vinyl FAC 3 TAC 3 PH 7.8 TA 150 CYA 30 Should I worry about lowering my alkalinity down to the 120 range?...
    Started by shutitdown‎, 06-13-2007 12:52 PM
    06-14-2007 06:51 AM Go to last post
  19. Order of chemical additions...
    After some much needed rain this weekend, I need to raise both my TA and Calcium. I'm going away this weekend, so I need to shock the pool Thursday...
    Started by Henrys514‎, 06-11-2007 03:42 PM
    06-12-2007 11:16 AM Go to last post
  20. Reduction of CH
    If I were to reduce my CH, currently at ~250 ppm, how would I go about doing this, add TSP? If I were to reduce it, say to 150 ppm, would I be able...
    Started by iwannapool‎, 05-31-2007 03:54 PM
    06-12-2007 10:59 AM Go to last post
  21. TA always high
    If the TA in the tap water from my house is like 200, then I'm pretty much going to always battle TA and lowering it right? When I fill my hot tub...
    Started by Jeffski‎, 06-11-2007 03:18 PM
    06-12-2007 10:18 AM Go to last post
  22. Calsaway
    They are coming this afternoon. I'll let you know how it turns out. Reggie http://www.calsaway.com/
    Started by Reggie‎, 05-23-2007 01:14 PM
    06-09-2007 09:05 AM Go to last post
  23. In a nutshell: Why the alk lowering process works
    Carl posted a very good explanation of why the process recommended here on the forum works to lower alkalinity. It is a very good post --...
    Started by Watermom‎, 04-07-2007 12:01 PM
    2 Pages
    1 2
    06-06-2007 10:33 AM Go to last post
  24. CH Test Question
    When using the Taylor 2006 test kit for CH I get a wierd reading/response. When you add the drops that are suppose to turn it red I get a very light...
    Started by iwannapool‎, 05-31-2007 08:56 AM
    05-31-2007 02:48 PM Go to last post
  25. Another calcium question
    My friend has a 19000gal IG vinyl pool with a Zodiac DuoClear SWG, which uses the Nature2 cartridges. The owner's manual recommends CH of 200-400ppm...
    Started by Sumo1‎, 05-31-2007 12:45 AM
    05-31-2007 12:45 AM Go to last post
  26. What should Calcium Hardness be?
    I have a gunite 28,000 gallon pool which is completely cloudy after being shocked and I cannot see the bottom of the shallow end. All of the algae is...
    Started by troykristoffer‎, 05-30-2007 10:45 PM
    05-30-2007 11:49 PM Go to last post
  27. CH and TA, are they related?
    How do CH and TA relate to one another, or do they?
    Started by iwannapool‎, 05-30-2007 04:23 PM
    05-30-2007 05:54 PM Go to last post
  28. Vinyl Pool and Calcium
    I've seen it said that a vinyl liner pool doesn't need calcium, makes sense. But I have also read if you have a heater and a vinyl liner then you...
    Started by iwannapool‎, 03-08-2007 04:19 PM
    05-30-2007 08:49 AM Go to last post
  29. Calcium Hardness
    Hello, I have a 3 year old in ground plaster pool. It is 30000 gallons. I am running a Autopilot dig-220 SWG. My problem is a constantly rising...
    Started by Ciscokid‎, 05-21-2007 03:17 PM
    3 Pages
    1 2 3
    05-30-2007 02:29 AM Go to last post
  30. Lowering alkalinity: PS234 & PH readings
    I opened my pool two weeks ago. I never bothered checking PH until after I added about a foot of well water. Then, my alkalinity was 260. At the...
    Started by LearningCurve‎, 05-27-2007 06:32 PM
    05-27-2007 10:19 PM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
