+ Post New Thread
Page 1 of 12 1 2 3 11 ... LastLast
Threads 1 to 30 of 332
Forum: Dealing with Alkalinity and Calcium
High alkalinity and calcium levels are much trickier to resolve than the pool books indicate
  1. Exclamation Sticky Thread Sticky: FAQs & HOWTOs: Swimming Pool Alkalinity
    HOWTO: Step-by-Step Guide to lowering your alkalinity The HOW-TO has moved here: lowering-swimming-pool-alkalinity-step-by-step.html You should...
    Started by PoolDoc‎, 03-29-2006 10:50 AM
    06-05-2006 01:53 PM Go to last post
  1. Higher CH and cloudy water
    Hi all, My calcium hardness has almost been around 150. We recently had a weeks worth of rainy weather. My pool water got cloudy shortly after....
    Started by beaverplt‎, 07-06-2021 10:25 AM
    07-06-2021 10:25 AM Go to last post
  2. Need help w alkalinity
    I have an above ground pool and my alkalinity is 179. I have about 12,000 of water in the pool. I don't have a heater. I just left my local pool...
    Started by vlapinta‎, 06-15-2020 02:13 PM
    06-15-2020 02:13 PM Go to last post
  3. Total water hardness
    Used to be on this site years ago and just re-joined. I am not able to search for an answer to my question....Do any household products lower the...
    Started by jateibel‎, 07-28-2018 09:42 PM
    07-28-2018 10:19 PM Go to last post
  4. Cool Questions about alkalinity and scale
    I was on this forum a while back and purchased the FAS-DPD chlorine test and I also have the total poolcare dpd test kit : I have a 25,000 gallon...
    Started by ddanderson2024‎, 07-18-2018 07:45 PM
    07-18-2018 10:43 PM Go to last post
  5. Having difficulty lowering TA or alkalinity
    I have 27' x 4' Roung AGP with 24" hayward sand filter and 2 speed 1.5 hp pump. New pool set up showed no FC, no CYA, TA at 325, PH 7.0 Using BBB...
    Started by Sugarfoot‎, 07-12-2018 07:24 PM
    07-13-2018 07:57 PM Go to last post
  6. Calcium buildup in SWCG
    I have a 16x32x52 above ground pool with a sand filter and salt generator. I have to clean the elements of the SWCG just about every other day. We...
    Started by Cdavidson77351‎, 06-15-2018 10:49 AM
    06-15-2018 12:04 PM Go to last post
  7. Increased Ph 8.0? Should I decrease and if so, how?
    Pool looks good but numbers are so so. Cl is 4-6 cya 80 ph has been 8.0. Should I decrease it and if so how? I use the Taylor test kit. It's great....
    Started by cdingess‎, 06-16-2016 03:47 PM
    2 Pages
    1 2
    05-31-2018 06:59 PM Go to last post
  8. Question about CH Test Coloration
    When using my Taylor test kit to test my CH the instructions say if CH is present the water will turn red. My water does not turn "red" it turns a...
    Started by jmarcum‎, 07-31-2015 05:18 PM
    2 Pages
    1 2
    08-02-2015 02:34 PM Go to last post
  9. How much Calcium it too much?
    Since a Vinyl lined pool does not need calcium, how much is too much and what kind of problems can it cause?
    Started by LearningCurve‎, 05-12-2015 04:36 PM
    05-30-2015 07:12 PM Go to last post
  10. Calcium Source and others...
    Is a calcium blend ( with cacl2, nacl, kcl, mgcl2) such as many brands sold online okay to use for increasing calcium hardness? How do you know...
    Started by Redwolf‎, 06-22-2013 04:13 PM
    2 Pages
    1 2
    05-12-2015 03:31 PM Go to last post
  11. Strange issue with Alkalinity and pH
    I have a in ground pool, ~13,000 gallons, about 10 years old with pebble tech finish. It has a spa that spills into the main pool. I've always kept...
    Started by Charlie‎, 02-08-2015 03:32 PM
    2 Pages
    1 2
    02-21-2015 04:05 PM Go to last post
  12. low alkalinity
    Ok...so I have a 2500 splash pad (slide, water features). For the last couple weeks I can't keep my alkalinity up. I am continually adding alkalinity...
    Started by angiedubberke‎, 08-19-2014 08:01 PM
    08-20-2014 11:32 AM Go to last post
  13. One year Pool Owner and enjoying every minute of it.
    My pool is approximately 22,000 gallons with spa. It is salt water and uses Pentair equipment with four pumps. They are the filter pump, wet edge...
    Started by Spaceman‎, 07-14-2014 09:01 PM
    07-17-2014 09:24 AM Go to last post
  14. Cannot Get Total Alkalinity to Go Down
    I'm new here. Hi to everyone and Thanks for having me as a member. This is the 1st time I have ever had a problem with Alkalinity being too high....
    Started by Dino1956‎, 07-13-2014 01:47 PM
    07-13-2014 08:18 PM Go to last post
  15. Post New to forum - high Alkalinity
    3rd year with my Intex 9x18 pool. I had been going to the pool store for help, with lousy results. Finally tried the BBB method instead, and low...
    Started by Casauribe‎, 07-06-2014 03:18 PM
    07-12-2014 10:54 PM Go to last post
  16. Calcium turned pool like skim milk
    Hi, I have a 16 x 24 above ground pool; took water to pool store for testing and it was recommended to add calcium; I did so and now my pool is like...
    Started by Jacqueline‎, 07-05-2014 12:38 PM
    07-06-2014 01:58 PM Go to last post
  17. cloudy darkish water
    Hope I'm posting in right place. Chlorine-6 TA-80 CH-300 Ph-7.6 Those are my chemical readings and I use the taylor kit to test , but my...
    Started by fhorta‎, 06-18-2014 10:23 PM
    2 Pages
    1 2
    07-04-2014 03:24 PM Go to last post
  18. pool got cloudy after adding pH UP
    Hello and thank you for reading this. Yesterday my pool was crystal clear. I checked the water and I was low on pH (7 - 7.2) as well as low on...
    Started by Limoges_swimmer‎, 06-23-2014 07:48 PM
    2 Pages
    1 2
    06-26-2014 02:09 PM Go to last post
  19. Calcium Hardness
    I was told I need to add 45lbs of hardness plus to my pool and 8 lbs of conditoner. We have only lived in this house for 2 years. Pool was already...
    Started by elliott4865‎, 06-20-2014 02:46 PM
    2 Pages
    1 2
    06-24-2014 10:57 AM Go to last post
  20. Smile New Pool build
    I am retired and had a pool (gunite) and spa built this spring for my wife and I and we have been enjoying it immensely. It is a small freshwater...
    Started by Usilpool‎, 06-18-2014 02:40 PM
    2 Pages
    1 2
    06-23-2014 09:08 AM Go to last post
  21. Alkalinity High and pH low
    Just joining the pool world. Starting with 16ft 48" above ground Intex before we go bigger. Having a tough time bringing the alkalinity down without...
    Started by BMomma‎, 06-16-2014 02:42 PM
    06-17-2014 06:59 PM Go to last post
  22. Lowering alkalinity on the cheap
    I've been seeing a lot about how to substitute expensive pool store stuff with things like grass clippings and paper (j/k) but the one thing I do...
    Started by Whetstone613‎, 06-14-2014 09:05 PM
    06-15-2014 11:05 AM Go to last post
  23. total alkalinity & ph questions
    Although several people have told me that these two are the same, from what I read online they are connected but in fact not a single issue. My TA is...
    Started by jimcopland‎, 06-11-2014 05:47 PM
    06-14-2014 03:01 PM Go to last post
  24. New here
    Hello all :) Great forum! New pool owner. I'll save my questions for after doing some reading first. Just wanna say thanks for having a great...
    Started by Big Splash‎, 06-03-2014 08:26 PM
    2 Pages
    1 2
    06-09-2014 09:24 PM Go to last post
  25. New user looking for help with scale
    We put our pool in and started it up in the spring of 2005. It is a Hydraazo finish 18 x 36 at 9 feet at the deepest end. We figure it is about...
    Started by motion guru‎, 05-30-2014 07:20 PM
    2 Pages
    1 2
    06-07-2014 01:51 PM Go to last post
  26. White Cloudy Water
    Hello: I have very cloudy/milky white water, I think because I mistakenly added PH minus and calcium increaser at roughly the same time, and I think...
    Started by ScosheOwn‎, 05-26-2014 02:46 PM
    06-05-2014 05:18 PM Go to last post
  27. Stone tile calcium deposits problem
    How to clean stone tile off gunite pool thanks Dave
    Started by dansdad‎, 06-03-2014 05:04 PM
    06-03-2014 11:01 PM Go to last post
  28. Thumbs up Calcium Hardness increasing (just curious)
    We had a monsoon that flooded our pool, so it took a couple days to get it back in order. I have been taking daily readings and noted that CH test...
    Started by banjeman‎, 06-02-2014 06:35 PM
    06-02-2014 10:53 PM Go to last post
  29. Do I need to worry about low hardness?
    If this doesn't get moved to the right place, when I can post to the right place, it'll look like this: I have soft water, so my hardness is often...
    Started by Whetstone613‎, 05-30-2014 12:57 PM
    bioguard
    05-31-2014 03:05 PM Go to last post
  30. Question Water Balance: Adjust alkalinity first, then PH . . . Or Not
    Alkalinity is over 200 PPM. In the past I have used muratic acid to lower it, but when I use the Arm and Hammer sodium carbonate, recommended by you,...
    Started by Marter, Dave‎, 05-10-2014 08:39 PM
    2 Pages
    1 2
    05-30-2014 06:00 AM Go to last post
+ Post New Thread
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 15 replies or 150 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
