+ Post New Thread
Page 4 of 11 FirstFirst ... 2 3 4 5 6 ... LastLast
Threads 91 to 120 of 312
Forum: DPD-FAS based testing
Using a Taylor DPD-FAS based testkit? Questions & answers here.
  1. Sticky Thread Sticky: FAQs & Guides: DPD-FAS based testing
    ____________________________________________ FAQs & Guides: DPD-FAS based testing ____________________________________________ Guide to...
    Started by PoolDoc‎, 06-30-2018 05:46 PM
    06-30-2018 05:46 PM Go to last post
  1. testing for bromine
    I have the ps233 test kit and use this to test CL in my pool. Is there any way to test bromine levels using this same kit? If the answer is no is...
    Started by dsmith6666‎, 10-06-2006 09:41 AM
    10-06-2006 11:04 AM Go to last post
  2. my chlorine is good but water is green
    Can anyone help me understand where things went wrong for me? :( I've been maintaining the chlorine at about 3ppm with my SWG and things were...
    Started by river-wear‎, 09-25-2006 09:29 PM
    09-26-2006 01:55 PM Go to last post
  3. PS234 -vs- Pentair (All-In-One)
    I had a quick question (newbie) :cool: . So our PBs finally brought our Pentair All-In-One test kit, which come's with Total and Combined Chlorine...
    Started by Pool_Mike‎, 09-20-2006 07:45 AM
    09-20-2006 10:54 AM Go to last post
  4. CYA Testing Results
    Okay - I have Ben's kit - but I am getting very different test results for the CYA reading than the dreaded pool store. 2 weeks ago: My test =...
    Started by Simmons99‎, 09-18-2006 04:23 PM
    09-19-2006 09:48 PM Go to last post
  5. PS233 Results
    My Alk was over 220 and I have been using acid and airation over the last weel to get things on track. Here are my current readings so I am...
    Started by aswetich‎, 09-16-2006 12:36 PM
    09-16-2006 02:11 PM Go to last post
  6. Finally got Ben's kit! First results....
    FC - 2.5 CC - .5 TC - 3 Alk - 150 CA - 10 PH - 7.8 CYA - 25 Temp - 84 I think that's everything. This really seems like a great and...
    Started by court475‎, 09-08-2006 02:28 PM
    09-12-2006 03:49 PM Go to last post
  7. Smile More Test Results!
    Hi Again Everyone, Thank you for your continued patience. I have had my test kit for approximately three weeks, and while I continue to hone my...
    Started by mkfmedic‎, 09-11-2006 05:16 PM
    09-12-2006 01:15 PM Go to last post
  8. Smile Recieved my Kit - FIRST RESULTS!
    OK Folks, I received Ben's PS234S kit and was able to finally see what all the "hub-bub" is all about. This kit exceeds any others I have seen,...
    Started by mkfmedic‎, 09-01-2006 09:01 PM
    2 Pages
    1 2
    09-06-2006 02:17 PM Go to last post
  9. When to replace FAS-DPD #1
    I received Ben's PS234 Kit in May. The FAS-DPD #1 powder is starting to turn dark grey. It seems to work OK but, does the test remain accurate when...
    Started by tbatti‎, 09-04-2006 10:38 AM
    09-04-2006 11:50 AM Go to last post
  10. Have my numbers ever changed !!
    Been lazy and did not keep up on things and now my numbers are way off. What should I adjust 1st ? Using PS233 Kit, 32K Inground Liner. FC 1...
    Started by aswetich‎, 08-31-2006 02:27 PM
    08-31-2006 03:20 PM Go to last post
  11. FAS-DPD Chlorine Test Question
    When you put the powder into the water - should it turn pink? If it doesn't - does it mean there is no chlorine (combined or otherwise) in the water?
    Started by Simmons99‎, 08-22-2006 08:23 AM
    08-22-2006 10:16 AM Go to last post
  12. Question CYA reagent refill instructions?
    I have a PS 233 kit. My original small bottle of CYA reagent is empty. I haved the larger refill bottle that came with the kit. It says to see the...
    Started by salinda‎, 08-16-2006 03:34 PM
    08-16-2006 05:17 PM Go to last post
  13. Results: alk too high?
    I tested my water just now with a PS233. My pool needs a little balancing because I went on vacation and the ph drifted. Also, I just changed my...
    Started by salinda‎, 08-14-2006 04:36 PM
    08-15-2006 07:18 AM Go to last post
  14. Post Borax test?
    Before I was introduced to this forum, my local pool store sold me hundreds of dollars of "optimizer" (Borax) which was part of my algae eradication...
    Started by halefmly‎, 08-12-2006 10:06 AM
    08-13-2006 09:53 AM Go to last post
  15. CYA test - Just an FYI
    The first several times I did my CYA test I filled the mixer bottle to the arrows on the label, which should have given me a 50/50 mix. I was...
    Started by Sherra‎, 07-31-2006 01:53 PM
    08-11-2006 03:08 PM Go to last post
  16. DPD powder
    I just opened a new bottle of dpd powder. I put in two scoops and begin adding drops of fas-dpd reagent. The pink disappears around 2.8 but the...
    Started by gldungan‎, 07-11-2006 01:00 AM
    2 Pages
    1 2
    08-11-2006 09:35 AM Go to last post
  17. Cloudy Water - New ps234 kit results
    Preface: I have metals in my water. I believe I've got them under control. The cloudy water is a bit of a pain so I figured I'd post my new...
    Started by szampino‎, 08-09-2006 08:35 PM
    08-09-2006 08:35 PM Go to last post
  18. New PS234-First Results
    Our pool is 20,000gal, fiberglass, and looks beautiful now that we have switched to bleach. Here are our first set of test results: FC-9 CC-0...
    Started by lskeate‎, 08-09-2006 10:41 AM
    08-09-2006 01:14 PM Go to last post
  19. Current testing results from PS234-Calcium too high?
    I have a IG salt water, 11,000 gallon plaster pool with spa. My water is clear and enjoyable however I am getting white deposits around the edge of...
    Started by Pinman24‎, 08-06-2006 08:14 PM
    08-06-2006 08:29 PM Go to last post
  20. Question Test results - bluish cloudy pool
    I have been using Ben's kit all summer and have been quite happy. It is so great to know what the CC is! I'm sure I've saved a ton on chlorine. ...
    Started by 4KidsSwim‎, 08-04-2006 04:46 PM
    08-04-2006 11:36 PM Go to last post
  21. Red face My first test. Any suggestions?
    Hi, I have vinyl pool about 35k with 400k gas heater. Just put a new liner in about 1 month ago. My first "real" test results are as follows: ...
    Started by mrrudedog‎, 08-03-2006 09:33 PM
    08-04-2006 01:30 PM Go to last post
  22. New Kit Owner - First Test Results - Not Good
    I have a newly resurfaced/redone inground pool. I am located in central Florida just east of the Tampa Bay Area. Here are the specifics: IG...
    Started by Nevets‎, 07-30-2006 01:54 PM
    08-03-2006 06:40 PM Go to last post
  23. My PS233 Results and Questions
    I have a 20x40 IG vinyl pool, I am using the PS233 test kit. Here are my results: FC=2 CC=0 TC=5 PH=7.5 ALK=60 CYA=5
    Started by errodr27‎, 07-19-2006 05:16 PM
    08-03-2006 04:50 PM Go to last post
  24. PS234 Results Please Advise
    Been fighting algae for the last couple of weeks. The pool is clear but has a green tint maybe from the algae, it seems embedded in my liner. Since...
    Started by aceman‎, 08-03-2006 02:44 PM
    08-03-2006 04:30 PM Go to last post
  25. Post Converted to BBB first test results with ps234
    I started the BBB method 3 weeks ago and have been amazed by the results. I removed a Nature2 cartridge along with an automatic chlorinator. Added...
    Started by ddtoavs‎, 08-01-2006 09:52 PM
    08-03-2006 07:30 AM Go to last post
  26. New to this can you help?
    Hello I would like to say that this is a great site. I have a 15 x 30 ABG that my son and I moved to our house, so we have just opened it. A good...
    Started by flyers141‎, 07-21-2006 11:33 AM
    2 Pages
    1 2
    08-02-2006 06:08 PM Go to last post
  27. Today's test results, please advise....
    FC=4.5 CC=0 TC=4.5 PH=7.5 ALk=90 CYA=55 Temp=92 28' AG Round with vinyl liner. I am using Autopilot digital with the SC-60 cell. I am...
    Started by klondrie‎, 08-02-2006 04:49 PM
    08-02-2006 04:56 PM Go to last post
  28. Question Please help a newbie...
    Hi everyone! I just received Ben's test kit and tried it for the first time today. Loved it! It was very easy to use. However, I'm a little...
    Started by Aviendha‎, 08-01-2006 08:46 PM
    08-02-2006 04:41 PM Go to last post
  29. Why is a PS234 better?
    Recently, I read somewhere on here, that the PS234 was better than another comparable brand name test kit, but I cant find the post, and I dont...
    Started by troykristoffer‎, 07-30-2006 05:22 PM
    08-01-2006 03:12 PM Go to last post
  30. First test results with PS234
    FC 8.5 CC 0 TC 8.5 pH 7.2 Alk 200 CAL 220 Cya 30 temp 85 15000 IG gunite
    Started by julespool‎, 07-29-2006 12:43 PM
    07-29-2006 06:03 PM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
