+ Post New Thread
Page 8 of 11 FirstFirst ... 6 7 8 9 10 ... LastLast
Threads 211 to 240 of 312
Forum: DPD-FAS based testing
Using a Taylor DPD-FAS based testkit? Questions & answers here.
  1. Sticky Thread Sticky: FAQs & Guides: DPD-FAS based testing
    ____________________________________________ FAQs & Guides: DPD-FAS based testing ____________________________________________ Guide to...
    Started by PoolDoc‎, 06-30-2018 05:46 PM
    06-30-2018 05:46 PM Go to last post
  1. First test.. first post
    Thanks for all the info I've read in the past, I just revieved my PS234s and here are the results... FC - 5 CC - 1 pH - 7.6 Alk - 70 Cal - 320...
    Started by davebva‎, 06-14-2006 09:02 PM
    06-15-2006 11:10 PM Go to last post
  2. Question First test results
    Pool builder finally came and added stabilizer. After running pump/filter 4 hours I did initial tests. FC 3 CC 1 pH 7.2 Alk 110 Cal 170...
    Started by poolbee‎, 06-14-2006 08:29 PM
    06-15-2006 10:27 PM Go to last post
  3. Red face test results
    These are my results right now- FC- 2.5, CC zero, TC- 1-2, ph 7.8, alk- 80, ca 450, cya 35 I have Ben's kit. My ph always drifts up to 7.8. I...
    Started by pirate-arghh‎, 06-13-2006 07:20 PM
    06-15-2006 02:46 AM Go to last post
  4. First Test Results
    I just received my test kit and here are my numbers. I have a 35K gallon in ground vinyl pool with salt generator. TC 5ppm TA 180 pH 7.2 ...
    Started by Cutter‎, 06-14-2006 07:22 PM
    06-14-2006 07:30 PM Go to last post
  5. Got the 234s kit, no pool yet so tested my tap water
    I will have my pool gunited tomorrow or Thursday so I'm a couple of weeks away from having a pool to enjoy. In the meantime I have figured I'd test...
    Started by GTakacs‎, 06-13-2006 10:37 PM
    06-14-2006 10:00 AM Go to last post
  6. PS234 test discrepency?
    I've noticed acouple people mention they get different results with the PS234 than other test kits. Does anyone have a fresh Taylor K2005 or...
    Started by falken‎, 06-13-2006 10:18 AM
    06-13-2006 11:33 PM Go to last post
  7. Necessity for ordering Salt Test in PS234 test kit
    Am I correct in assuming that there is no necessity for a Salt Test if you do not have a salt water generator? Many thanks! Scarlett
    Started by Scarlett‎, 06-12-2006 12:04 PM
    06-13-2006 12:04 AM Go to last post
  8. Question PS200 Chlorine Chart - Am I color blind?!
    I'm wondering if anyone else has this problem. When I look at the Cl side of the Cl / pH tester in the PS200 kit, the 2, 3 and 5 levels all look the...
    Started by sharknj‎, 06-11-2006 09:00 PM
    06-12-2006 07:44 PM Go to last post
  9. Exclamation PS233 Results--Your input please!
    Got the liner leak found and fixed (the pool drained all but 14" of water over the winter!). It's funny how a tiny, tiny hole can leak a LOT of...
    Started by SandyDittmer‎, 06-12-2006 09:50 AM
    06-12-2006 10:46 AM Go to last post
  10. Bulk DPD Powder - worth it?
    I know from info here DPD powder lasts a year. That would seem to be because it is opened often and exposed to the atmosphere (absorbs moisture I...
    Started by RocKKer‎, 06-05-2006 01:26 AM
    06-09-2006 10:13 PM Go to last post
  11. Using Test Kit on Aquarium?
    I figured I would order my test kit while the pool is under construction to make sure that I had it if the pool ever gets done:( . So I understand...
    Started by Simmons99‎, 06-07-2006 12:14 PM
    06-09-2006 10:30 AM Go to last post
  12. Exclamation PS234 & HTH 5-way difference...
    I've tested with my two test kits, P234 & 5-Way HTH. The HTH test kit is from Walmart and is brand new. All the numbers match except for the...
    Started by csevel‎, 06-09-2006 10:08 AM
    06-09-2006 10:08 AM Go to last post
  13. Ca Hardness Testing - Interpretation
    28K GA / IG / Diamondbrite / SWC / DE filter pH 7.4 / FC 5 / CC 0 / CYA 50 / Ca 220 / TA 100 / 87 degrees My PS233 test kit readings of Ca...
    Started by Slam Pool Guy‎, 06-09-2006 12:02 AM
    06-09-2006 07:13 AM Go to last post
  14. green gone now blue still cloudy
    I have done everything. I stuck pool is now blue but still cloudy. Please help I have 10,000 above ground pool sand filter. I believe I have kill all...
    Started by chriss14‎, 06-08-2006 04:25 PM
    06-08-2006 10:46 PM Go to last post
  15. Received PS234 kit today and here are numbers
    FC = 12.5 Lowered dial down on SWG ( now at 20 was on 40) CC = .5 TC = 13 PH = 7.2 Trying to lower TA TA = 140 CAL = 200 CYA = Was below 100...
    Started by KPROMERO‎, 06-08-2006 07:10 PM
    06-08-2006 08:01 PM Go to last post
  16. calculation for borax
    Is there a nifty chart/formula/calculator (like the bleach one) somewhere for adding Borax? something like... to raise you pH: for every .1...
    Started by BW-poolmom‎, 06-03-2006 10:51 AM
    2 Pages
    1 2
    06-08-2006 03:43 PM Go to last post
  17. 45000 gallon pool first results
    We plastered and filled our gunite pool on 6/3. It's 50x20x10deep, but with large benches and shallow play area, so we watched our meters and got a...
    Started by jdburton‎, 06-07-2006 11:45 AM
    06-08-2006 10:39 AM Go to last post
  18. Bleach Calculator
    Is anyone working on getting the Bleach Calculator link to work?:confused:
    Started by ThePoolFool‎, 06-06-2006 05:57 PM
    06-07-2006 11:44 AM Go to last post
  19. PS233 test kit and CYA test question
    I am using the PS233 kit for the first time and I want to be sure that I am doing the CYA test correctly. The instructions say to use the #9194...
    Started by mshumack‎, 04-01-2006 08:33 AM
    06-06-2006 10:28 PM Go to last post
  20. First Test Results for ThePoolFool
    Just starting the PoolSolutions regimen and have the PS234 kit. Opened pool this weekend and: Water is cloudy (can barely see the bottom step in...
    Started by ThePoolFool‎, 06-04-2006 04:53 PM
    06-06-2006 09:58 PM Go to last post
  21. 1st test results using PS234
    I just filled my pool with trucked water yesterday. I get full sun from about 9am til 7 pm with partial shade from 3-4 pm. We got about 5 small...
    Started by tjcat‎, 06-06-2006 11:04 AM
    06-06-2006 07:05 PM Go to last post
  22. CC test question
    When testing for CC, is any change in color supposed to happen immediately? In my tests, after the five drops, the tube stays clear 99 percent of the...
    Started by GolfTop‎, 06-01-2006 09:01 PM
    06-06-2006 11:36 AM Go to last post
  23. Question Confused as to what to add now...
    18' A/G pool 8000 gallons Have had some electrical problems with pool pump among various other issues. but DID add the stabilizer to the skimmer...
    Started by csevel‎, 06-05-2006 09:19 PM
    06-05-2006 09:35 PM Go to last post
  24. Smile High Chlorine
    I have a 14 by 28 inground vinyl liner pool. My chlorine is high should I just let it burn off and shock it? FC 18.0 CC 0 TC 20 + Brown PH 6.8...
    Started by ltpowel‎, 06-04-2006 07:55 PM
    06-04-2006 08:19 PM Go to last post
  25. Salt test with new kit - problems
    Hello, I added 320 pounds of salt to my 13,500 fiberglass pool last night and today I tried to test it with my new kit with salt testing. It...
    Started by haeffnkr‎, 06-03-2006 05:56 PM
    06-04-2006 03:50 PM Go to last post
  26. My first post and first test numbers
    First of all, I've been lurking on this forum since last summer and I'm amazed at the wealth of valuable knowledge! I have a 26,000 gallon IG vinyl...
    Started by sharknj‎, 06-01-2006 08:58 AM
    06-04-2006 03:26 PM Go to last post
  27. PS234 kit and tip problem
    I've found a work-around solution to the tip problem, which causes undersized drops with the CHL#2 and SALT#2 reagents. Wipe the tips with a damp...
    Started by PoolDoc‎, 06-04-2006 03:24 PM
    06-04-2006 03:24 PM Go to last post
  28. 1st PS234 Test Results
    5/24/06 pm FC=1.5 CC=0 TC=1.5 pH=7.1 Alk=60 Cal=80 Cya=0 Temp=83 (Solar cover) Water is clean and clear.
    Started by Cannonball‎, 06-04-2006 11:12 AM
    06-04-2006 01:46 PM Go to last post
  29. Different results with CYA refill?
    Last year maintaining my pool was a nightmare, spent $1500 in one season on poolsupplies!!:( Found this site over the winter, got Ben's kit,studied...
    Started by dancu‎, 06-03-2006 08:11 PM
    06-04-2006 09:57 AM Go to last post
  30. Question Help with 1st PS234 Test Results
    18' Above Ground, 8000 gallons or so. I'm assuming I need stabilizer. I put 2 stabilized pucks in a floater three days ago since I didn't have my...
    Started by csevel‎, 06-01-2006 05:37 PM
    06-01-2006 07:03 PM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
