+ Post New Thread
Page 9 of 11 FirstFirst ... 7 8 9 10 11 LastLast
Threads 241 to 270 of 312
Forum: DPD-FAS based testing
Using a Taylor DPD-FAS based testkit? Questions & answers here.
  1. Sticky Thread Sticky: FAQs & Guides: DPD-FAS based testing
    ____________________________________________ FAQs & Guides: DPD-FAS based testing ____________________________________________ Guide to...
    Started by PoolDoc‎, 06-30-2018 05:46 PM
    06-30-2018 05:46 PM Go to last post
  1. New User First Test - Help
    I have a 20x40 vinyl pool ~32000 gal. Sand filter. Pump 24x7 Waiting for test kit I dumped MANY gals of bleach. 2 2lb boxes of Borax and 8 lbs of...
    Started by psteward‎, 05-25-2006 07:12 PM
    2 Pages
    1 2
    06-01-2006 03:56 PM Go to last post
  2. ps234 test results - first post
    I have been visiting this site for 3 years -- learned a lot. I finally bought the test kit. My results are fc-2.5 cc - 0 ph - 7.2 alk - 70 cal...
    Started by charlie75‎, 05-27-2006 11:53 AM
    05-31-2006 09:11 PM Go to last post
  3. Test Results questions
    I have a 19,200 gallon pool. Last year was my first year of pool ownership and I used Baquacil. The prior owners used chlorine. This year I've taken...
    Started by DaveInPA‎, 05-23-2006 07:27 PM
    05-30-2006 10:50 PM Go to last post
  4. What to do with test result water?
    Hello, Like the post says....Is it OK to pour the test vile/water/chemicals back in the pool or should I pour it on the lawn or what? I have not...
    Started by haeffnkr‎, 05-23-2006 06:14 PM
    2 Pages
    1 2
    05-30-2006 10:06 AM Go to last post
  5. 1st Time test results
    I just tested my pool and got these results. 16000 Gal FC-4 TC-5 PH-7.2 ALK-140 CAL-210 CYA-20 Pool temp is 83
    Started by Bnelson‎, 05-29-2006 12:30 PM
    05-29-2006 02:16 PM Go to last post
  6. PS233 test (1st this year)
    I opened my 24 agp 2 days ago and have been fixing a leak in the return. Water weas crystal clear! 14k gallons or so. Just tested: FC - 13...
    Started by cvoytek‎, 05-29-2006 10:17 AM
    05-29-2006 10:35 AM Go to last post
  7. PS234s results (trying to run high pH)
    I am a few days into converting to an AutoPilot Dig220/SC-60, so I expect to see the Cl levels fluctuate as I adjust the unit. But, here is what I...
    Started by CAL7‎, 05-26-2006 03:50 PM
    05-28-2006 10:38 PM Go to last post
  8. Exclamation First Results PS234 - Please Help!
    My pool is an 18' above ground with a capacity of about 8000 gallons. (54") deep. I tested the water to get an initial reading but it is only half...
    Started by csevel‎, 05-28-2006 04:04 PM
    05-28-2006 05:11 PM Go to last post
  9. New IG vinyl liner - initial results
    I have a 16X40 IG pool, about 25,000 gallons. The liner went in Tuesday night and it took nearly two days to fill it. (This is in metro Atlanta....
    Started by Zaphod‎, 05-27-2006 11:43 AM
    05-28-2006 09:50 AM Go to last post
  10. Question My Results...Do I need to do anything?
    20x40 pool....3.5 ft - 8ft vinyl.....400K BTU Heater water temp about 70F FC = 5 CC = 0 TC = 5 Ph = about 7.3 or 7.4 Alk = about 140 CYA =...
    Started by albertgarrido‎, 05-27-2006 12:30 AM
    05-27-2006 07:28 AM Go to last post
  11. First test results with the PS234
    First time posting. Here are the results from the PS234 kit FC:10.5 CC:0 TC:5 (was slightly darker than the highest reading of 5) PH:7.4...
    Started by metalman‎, 05-24-2006 10:00 AM
    05-26-2006 10:20 PM Go to last post
  12. first test results
    Hi Received my ps234 and tested my 24' AG pool last night. I uncovered the pool yesterday for the first time this year. Here are the results: FC 22...
    Started by jazzbone‎, 05-26-2006 08:18 AM
    05-26-2006 03:19 PM Go to last post
  13. Smile First set of results
    Got my kit today and thought I'd get some input on the results. I have a plaster pool. FC 4 CC 0 TC 4 PH 7.4 ALK 240 CAL 200 - 240 (The...
    Started by maker‎, 05-24-2006 09:49 PM
    05-25-2006 08:48 PM Go to last post
  14. 1st Test Results with my PS233
    As a continuation from my post in the other forum, I had my water tested at the pool store prior to opening my pool and the results were as follows:...
    Started by Phulish‎, 05-24-2006 09:52 PM
    05-25-2006 12:12 PM Go to last post
  15. First Run, Kit arrived today
    Hi everyone, Had a package by the door today. My DPD powder opened during shipment so I don't have FC or CC readings. How does these numbers look...
    Started by Condo Steve‎, 05-23-2006 10:02 PM
    05-24-2006 10:03 PM Go to last post
  16. PS234 Kit Salt Option/No Instructions
    I have received the PS234 Kit and have been using it for ~2 weeks for testing my pool. Love the Kit so far. I am ready to bring my SWG on-line...
    Started by squirrel49‎, 05-23-2006 07:51 PM
    2 Pages
    1 2
    05-24-2006 09:31 PM Go to last post
  17. Talking Distilled water?
    What does the distilled water do in the testing? I am curious because I think I am gonna need this little info for awhile at least till I get my kit.
    Started by Bowlin‎, 05-24-2006 02:46 PM
    05-24-2006 07:25 PM Go to last post
  18. Exclamation Important PS234 Info
    I'm very sorry, but we've been in a 'hold' mode on the kits since last Wed or Thurs, since discovering widespread problems with the dropper tips on...
    Started by PoolDoc‎, 05-24-2006 01:20 PM
    05-24-2006 01:20 PM Go to last post
  19. PS234 First Test results... Am I doing this correctly?
    FC=39PPM (Yikes!!!) added a level scoop of DPD powder, not a rounded scoop correct? DPD #2 solution dropper bottle is VERY difficult to control! ...
    Started by leejp‎, 05-17-2006 09:51 PM
    2 Pages
    1 2
    05-24-2006 09:12 AM Go to last post
  20. first complete test - does this sound right?
    Hello - My numbers are FC 5.5 CC .5 TC 6 ph 7.8 ALK 170 cal 160 cya 20
    Started by haeffnkr‎, 05-20-2006 02:37 PM
    2 Pages
    1 2
    05-23-2006 06:11 PM Go to last post
  21. yellow green H2O
    Been overbusy and just getting at my pool - had to add water to fill about 4 days ago. Treated with pool magnet and algaecide and let filter do it's...
    Started by huskerfan‎, 05-21-2006 05:59 PM
    05-23-2006 02:56 PM Go to last post
  22. How Much Bleach ??
    I have the PS 233 kit that I got last year and now have all my numbers dialed in real good. This is my 1st year trying the bleach thing and I was...
    Started by aswetich‎, 05-23-2006 01:05 PM
    05-23-2006 01:23 PM Go to last post
  23. Red face Got my 234 today...and boy do I need help! (newbie alert)
    Hi everyone, I'm a complete pool newbie! I've really got no idea what to do or where to start. But I'm hoping I get things straightened...
    Started by gonefishin‎, 05-02-2006 08:27 PM
    05-23-2006 11:40 AM Go to last post
  24. PS234 DPD Reagent #2 Conundrum - Ben?
    I received my PS234 Saturday. Yesterday I checked my chlorine with last year's DPD powder and reagent # 871, then did same with the new DPD powder...
    Started by elsie‎, 05-22-2006 10:05 AM
    05-23-2006 09:36 AM Go to last post
  25. CYA test, optical illussion??
    i dont get this test, you fill the solution of pool water and CYA reganent untill you cant see the dot... well i filled it to about the top and held...
    Started by Dooms_day‎, 05-21-2006 04:07 PM
    05-22-2006 09:00 AM Go to last post
  26. Question DPD powder
    Should the dpd powder go bad before a year? I keep my kit (PS233) in doors at all time. I bought a few refills last year, including dpd powder. Now I...
    Started by Poolidiot‎, 05-17-2006 08:01 PM
    2 Pages
    1 2
    05-20-2006 10:05 PM Go to last post
  27. cal and alk off
    so we know the cl bottle is bad so just wait for my new tip, in the mean time use my 233 despencer. so okay on my 233 (purchased the last halve...
    Started by omg‎, 05-20-2006 08:46 PM
    05-20-2006 08:46 PM Go to last post
  28. Question Test results - pool is green still
    I've learned alot here - enough to think I know what is going on... am I misunderstanding something? I have a green, can't see to the bottom of...
    Started by lora13‎, 05-20-2006 11:01 AM
    05-20-2006 11:01 AM Go to last post
  29. Talking First Test Results
    This is an excellent site for beginners and seasoned pool owners. Thanks to the pool cleaner forum my Polaris is back to cleaning the whole pool with...
    Started by pinkivory_99‎, 05-18-2006 07:23 PM
    05-19-2006 10:48 AM Go to last post
  30. results with PS233 with questions(of course)
    PS233 kit results AG vinyl 21' X 52" appr 13,500 gallons pH 7.2 (I know I want 7.3-7.8 but I am thinking I am pretty close right?) TC this...
    Started by marocema‎, 05-18-2006 04:37 PM
    05-19-2006 07:00 AM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
