+ Post New Thread
Page 3 of 11 FirstFirst 1 2 3 4 5 ... LastLast
Threads 61 to 90 of 312
Forum: DPD-FAS based testing
Using a Taylor DPD-FAS based testkit? Questions & answers here.
  1. Sticky Thread Sticky: FAQs & Guides: DPD-FAS based testing
    ____________________________________________ FAQs & Guides: DPD-FAS based testing ____________________________________________ Guide to...
    Started by PoolDoc‎, 06-30-2018 05:46 PM
    06-30-2018 05:46 PM Go to last post
  1. Check_In and Advice Needed
    Good Evening all (good morning and good afternoon to anyone in other parts of the world). Wanted to get your recommendation on a couple of things:...
    Started by Orkalovesfood‎, 06-06-2007 09:33 PM
    06-08-2007 10:22 AM Go to last post
  2. Cloudy water
    IG Vinyl 25,000 Gal pool New filter last year. New heater last year Water got a little away from me: Ph too high (8+), and some vague green...
    Started by jbalcorn‎, 06-02-2007 12:32 PM
    06-06-2007 07:27 PM Go to last post
  3. Need help on first time results
    Haven't been able to keep chlorine all summer long in 2 yr old pool. Leslie's was having me spend lots of money "trying" different methods and no...
    Started by Aggie 88‎, 07-15-2006 08:45 PM
    2 Pages
    1 2
    06-06-2007 08:19 AM Go to last post
  4. How often do you test?
    How often do you test your pool water? I test chlorine 1-2 times a week and PH/TA once every other week. Just curious what others out there...
    Started by nicole12‎, 05-25-2007 03:15 PM
    06-01-2007 01:00 PM Go to last post
  5. Question Delayed reaction with chlorine tests
    In the spring of 2006 I purchased a PS234S testkit (serial # 6616) and was extremely pleased with the accuracy and ease of use. This year however, I...
    Started by papa6‎, 05-24-2007 08:55 PM
    06-01-2007 11:02 AM Go to last post
  6. Opening test results
    After opening to a very green pool. Added about 10 gals 12.5 % liquid pool clear from FF. I have a fairly clear pool. Some brown stuff all over...
    Started by Bnelson‎, 05-30-2007 03:37 PM
    05-30-2007 05:51 PM Go to last post
  7. Oxone and Calcium Hardness Test
    Has anyone had any problems with the calcium hardness test (Taylor K-2006) after shocking with non-chlorine (potassium monopersulfate) product? Per...
    Started by Pool in Carolina Blue‎, 05-29-2007 12:23 PM
    05-29-2007 12:23 PM Go to last post
  8. PH over 15 - what reduced ph?
    2 questions for a 25000 gal, in ground, vinyl lined pool: 1) Ph is above 15, how do I reduce? Why is my ph above 15 you ask? We had to replace...
    Started by 4KidsSwim‎, 05-28-2007 08:09 PM
    05-29-2007 06:50 AM Go to last post
  9. ps234 test results, first of the season
    here are my results: Ph 7.2 FC 1 CC .5 TC 1.5 Alk 60 Cal 230 CYA 40 last year I recorded this as my goals on the last column of the test...
    Started by vinouspleasure‎, 05-27-2007 09:19 PM
    05-27-2007 10:48 PM Go to last post
  10. 1st of the season test results, not bad??
    Hello everyone. It has been a long time since I posted, but I've enjoyed and benefitted from this forum for years. I own both a "new last year"...
    Started by faithfulfrank‎, 05-24-2007 05:10 PM
    05-27-2007 07:29 AM Go to last post
  11. Test results
    Here are my results: Ph 7.2 TA 80 FC 14.5 CC 0.5 CYA around 80 I use bleach to shock and tri-chlor as my usual chlorine...still trying...
    Started by nicole12‎, 05-25-2007 03:02 PM
    05-26-2007 08:15 PM Go to last post
  12. Test results for opening
    I have to say I am completely happy with all of the great advice I received from everyone last year!This is our first opening and my numbers are as...
    Started by tjcat‎, 05-26-2007 03:55 PM
    05-26-2007 08:12 PM Go to last post
  13. Wink PS23x Label for Results
    I have a PS233 kit, and I like the label on the outside of the box, but mine's wearing a bit. I'd like to print a new one, laminate it and use a...
    Started by PhantomAndy‎, 05-18-2007 11:21 AM
    05-21-2007 08:48 PM Go to last post
  14. Test results
    Using Ben's kit here are my results: Ph 7.5 FC 2.5 CC 0 Alk 90 Cal 130 CYA 0 (pool store said I had 70--but I have tested and retested) Salt...
    Started by kolwecoon‎, 05-20-2007 12:21 PM
    05-20-2007 08:24 PM Go to last post
  15. First Test Results
    Hello, Everyone. I opened the pool (50,000 gallon, concrete pool) on Thursday afternoon. We really dosed it with bleach on Thu and Fri. and the...
    Started by psbailey‎, 05-13-2007 10:51 AM
    05-14-2007 06:48 PM Go to last post
  16. First Test Results
    My Taylor K-2006 came today and here are my results. Some suggestions would be greatly appreciated. The water is fairly clear/slightly cloudy. The...
    Started by adesalvo‎, 05-10-2007 11:06 PM
    05-11-2007 02:23 PM Go to last post
  17. Anyone having trouble with Salt test?
    I have the PS234S - upgraded form the 233. I just did the salt test last night and it says I have 4000ppm Salt. I did it a second time (same water...
    Started by mshumack‎, 08-03-2006 11:17 AM
    3 Pages
    1 2 3
    05-11-2007 12:54 PM Go to last post
  18. Watertesting speadsheet
    Does anyone have/use a speadsheet to track water chemistry? I guess I could make one, but if somebody has a good one that they are willing to...
    Started by adesalvo‎, 05-08-2007 11:55 PM
    05-09-2007 10:17 AM Go to last post
  19. New Label for PS234
    My old PS233 test kit's label is quite worn and wrinkly. Any ideas on where to get the label printed so it can be erased without removing the ink...
    Started by DavidD‎, 04-09-2007 06:36 PM
    04-09-2007 06:36 PM Go to last post
  20. 1st test results - CYA down to ZERO?
    OK, so really it is my second full test, but I thought the 51 degree H2O might have affected things. Here are my numbers: FC 1 CC 0 TC .5 pH 7.6...
    Started by bhelme‎, 04-10-2006 01:49 PM
    2 Pages
    1 2
    03-31-2007 03:51 PM Go to last post
  21. Instructions for PS234 test kit
    Instructions for PS234 test kit >CHLORINE DROP-COUNT (FAS/DPD TEST (record as ‘FC’ and/or ‘CC’ above) 1. Rinse and fill clear chlorine test...
    Started by Poolidiot‎, 02-12-2007 05:36 PM
    02-25-2007 01:11 PM Go to last post
  22. Should I raise my TA now?
    Back in September I aerated and successfully lowered my TA to 80 in response to some useful guidance in this forum. I still test weekly, and am now...
    Started by halefmly‎, 02-10-2007 05:07 PM
    02-12-2007 04:07 AM Go to last post
  23. Test results
    I've had my pool since late July and with the information I've learned here and Ben's test kit, I've been able to keep my pool in beautiful shape...
    Started by kolwecoon‎, 01-15-2007 12:56 PM
    01-15-2007 03:55 PM Go to last post
  24. Question Late season results
    Hi folks, It's the first truly chilly (<40 deg.) week here in NoCal and here are my results: FC 4.0 CC 0 TC 4.0 PH 7.8 ALK 110 Cal 260
    Started by kearpaul‎, 12-17-2006 08:01 PM
    12-31-2006 11:14 AM Go to last post
  25. Replacing CYA #1 - just checking
    Hi again folks, I'm enjoying my PS234, but had to refill the "CYA #1" solution. Ordered and received some Taylor R-0013 Cyanuric Acid Reagent....
    Started by kearpaul‎, 12-30-2006 09:12 PM
    12-31-2006 10:59 AM Go to last post
  26. Smile Chlorine Question??
    Hi folks, It has been relatively easy pool summer and as the weather cools, I am running into an issue I did not expect. My pool is...
    Started by mkfmedic‎, 11-08-2006 02:01 PM
    11-13-2006 02:28 PM Go to last post
  27. First water test results
    No, not from the vaunted but still unseen test kit, but from the PB who re-plastered. TDS 223 CYA 39 Alk 100 Ca 212 pH 7.5 Cl 1.0...
    Started by Daggit‎, 11-01-2006 01:24 PM
    11-02-2006 01:49 PM Go to last post
  28. New pool results from PS234s
    Looking for confirmation that my pool is headed in the right direction. It is a 20,000 gallon inground gunite pool (hydrazzo finish). SWG is not...
    Started by micon2‎, 10-22-2006 04:49 PM
    10-24-2006 05:16 PM Go to last post
  29. Wink New pool start up
    Pool is finally done. It has been several years since I had to maintain a pool and I feel like I need to "re-learn" all over again. Can anyone help...
    Started by micon2‎, 10-20-2006 08:03 PM
    10-20-2006 10:54 PM Go to last post
  30. Question Could this be Right?
    Hello Again, As the summer transitions to fall and the weather cools, I have gone about 10days between tests. There has been no swimming load in...
    Started by mkfmedic‎, 10-13-2006 03:46 PM
    10-13-2006 05:01 PM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
