+ Post New Thread
Page 11 of 11 FirstFirst ... 9 10 11
Threads 301 to 312 of 312
Forum: DPD-FAS based testing
Using a Taylor DPD-FAS based testkit? Questions & answers here.
  1. Sticky Thread Sticky: FAQs & Guides: DPD-FAS based testing
    ____________________________________________ FAQs & Guides: DPD-FAS based testing ____________________________________________ Guide to...
    Started by PoolDoc‎, 06-30-2018 05:46 PM
    06-30-2018 05:46 PM Go to last post
  1. question about Cal test
    I have a ps233 that I purchased late in the season last year. I only used it once at the end of September. I wish I had known about the new kit...
    Started by salinda‎, 04-20-2006 10:19 PM
    04-23-2006 08:01 AM Go to last post
  2. Is there a drop method for ph?
    I've seen this question posed before, but didn't read the replies because it didn't interest me at the time..lol. It must have been lost in the...
    Started by pedsrn‎, 04-22-2006 08:06 PM
    04-22-2006 09:20 PM Go to last post
  3. What first... 1st Test
    Hey... Appreciate any suggestions on what I should do first...Then 2nd, etc... What should I add? 28,500 16X40 Vinyl IG Pool Water Temp: 80 SWG...
    Started by The Pool Newbie‎, 04-19-2006 07:58 PM
    04-19-2006 11:06 PM Go to last post
  4. 233 results vs pool store
    For the first time since converting from Baq last July, I entered the dreaded pool store for a water analysis. I am out of CYA reagent and with the...
    Started by pedsrn‎, 04-17-2006 08:47 PM
    04-18-2006 11:35 PM Go to last post
  5. Help 1st test results - ZERO?
    Well it's that time to open the pool,and took my first reading.Here there are,now I need help with the cya.I have an oval 18x33 AG VINYL liner not...
    Started by sisie5‎, 04-17-2006 03:34 PM
    04-18-2006 01:21 PM Go to last post
  6. First test of the season, looks pretty good?
    I have the 233 kit. I’m not going to fully open the pool for another 3 weeks or so but the water is starting to get a little over 50 degrees so I...
    Started by Crispyc21‎, 04-16-2006 06:52 PM
    04-16-2006 08:09 PM Go to last post
  7. Question Opened early
    Here in cleveland we just had our first 70 degree day. I'm looking to replace the broken heater (been broken much longer than I've had the pool) so...
    Started by jbalcorn‎, 04-13-2006 07:41 PM
    04-13-2006 08:13 PM Go to last post
  8. 1st test this season
    Beautiful day here so I decided to test my water for the 1st time this season. The pool is still covered. My 1st question is at what temp would...
    Started by donfranko‎, 03-31-2006 03:12 PM
    04-12-2006 08:42 PM Go to last post
  9. New Gunite Pool startup questions
    I am doing an owner-built pool and have just added the water. I have Ben's PS233 test kit. I would appreciate any startup advice you can offer. ...
    Started by mshumack‎, 04-01-2006 09:01 AM
    04-01-2006 04:24 PM Go to last post
  10. Question about hardness test
    Hi, I got Ben's test kit at the end of last season and just started using it. It's all a bit overwhelming at first, but after several uses most...
    Started by Lenny‎, 03-26-2006 04:33 PM
    2 Pages
    1 2
    03-31-2006 11:06 PM Go to last post
  11. limits of the new test kit? ps234
    Hello, i was wondering what are the limits of the new test kit, how high can it test free chlorine levels and cya ect. i looked at the FAQ page but...
    Started by xoroniox‎, 03-31-2006 04:13 PM
    03-31-2006 08:47 PM Go to last post
  12. Ps 233
    I did my Baquacil to bleach conversion late last summer and bought Ben's kit. It is great! 2 questions: I have kept it inside. Will it still be...
    Started by VOLDADDY‎, 03-25-2006 08:14 PM
    03-26-2006 11:32 AM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
