+ Post New Thread
Page 1 of 11 1 2 3 ... LastLast
Threads 1 to 30 of 312
Forum: DPD-FAS based testing
Using a Taylor DPD-FAS based testkit? Questions & answers here.
  1. Sticky Thread Sticky: FAQs & Guides: DPD-FAS based testing
    ____________________________________________ FAQs & Guides: DPD-FAS based testing ____________________________________________ Guide to...
    Started by PoolDoc‎, 06-30-2018 05:46 PM
    06-30-2018 05:46 PM Go to last post
  1. Guide to Testkit Reagent Replacement
    _____________________________________________ This was discussed in a thread from 2015, but is now updated here. Since all the almost all the...
    Started by PoolDoc‎, 06-30-2018 03:05 PM
    06-30-2018 03:05 PM Go to last post
  2. DPD powder ( R-0870) has turned dark. Is it OK?
    Powder turned dark grey/black during the winter. Is it still usable and accurate?
    Started by Shredhead‎, 05-11-2015 12:15 PM
    05-26-2018 02:59 PM Go to last post
  3. Pool Opening - PS234 Test
    FC - 21 CC - .5 TC - 21.5 PH - 6.8 or < (yellow) Alk - 60 Cal - 40 CYA - 0 Temp - @40 IG, Vinyl liner @22,000 Gal. W/chlorine that high,...
    Started by rhosk‎, 05-04-2006 01:18 PM
    2 Pages
    1 2
    05-26-2018 02:01 PM Go to last post
  4. Taylor Reagents Refills
    Any suggestions on the best place to purchase Taylor reagent refills. The last two times I have gotten refills that expire within 2 to 3 months....
    Started by nepsa‎, 05-25-2018 12:25 PM
    #needvideo
    05-26-2018 12:08 PM Go to last post
  5. What reagents for PS200 / K1000 OTO/phenol red kit?
    I went to the pool store to buy reagent for testing chlorine, I was sold Taylor R-0003, this test reagent is not for testing chlorine. What is it...
    Started by ltpowel‎, 06-01-2017 03:51 PM
    06-04-2017 01:18 PM Go to last post
  6. Replacing reagents in the K2006 kit
    _________________________________________________ Admin Edit: Please use the updated version of this post. PoolDoc ...
    Started by mitchryan912‎, 04-26-2015 10:36 PM
    05-01-2015 03:26 PM Go to last post
  7. Accuracy of Taylor 2006 kit with high Chlorine water
    I shocked my 300 gallon spa with 12 oz of liquid chlorine 8.25%. This was a week following it's first fill of the season after I added an initial...
    Started by poolaris‎, 12-10-2014 10:51 AM
    12-10-2014 11:02 AM Go to last post
  8. PS234 regent replacement question
    I have the PS234 testing kit. I bought the correct replacement regents from Taylor. My question is do I need to put the Taylor regents into the PS234...
    Started by let_her_flicker‎, 06-14-2014 08:35 AM
    06-14-2014 08:35 AM Go to last post
  9. Rusty dipper?
    Is it typical for the little testing dipper that comes with the R-0870 reagent to turn a rusty brown color with use? I'm guessing it's oxidation?...
    Started by Big Splash‎, 06-10-2014 11:50 AM
    06-10-2014 06:30 PM Go to last post
  10. Post K-2006 Arrived! Results Within
    FC = 0.2ppm CC = 0.2ppm pH = < 7 - 6 Drops to 7.4/7.6 TA = 30ppm CH = 120ppm CYA = < 30ppm What should I add first using the BBB method? How...
    Started by JustAlex4tw‎, 06-03-2014 10:20 PM
    2 Pages
    1 2
    06-05-2014 09:39 PM Go to last post
  11. Testing cya with 2006
    I'm testing cya with my 2006 kit. Everything is ok, ch. is 3.0 but cya vile goes to the top with the water and its barely cloudy. So how do I get an...
    Started by dansdad‎, 05-28-2014 07:53 PM
    2 Pages
    1 2
    06-01-2014 04:29 PM Go to last post
  12. Taylor Kit Math Question
    Hypothetically speaking, I am testing my free chlorine and this is the equation, .02X6=0.12. How do i interpet this answer? Would I say my FC level...
    Started by dncellis2‎, 05-14-2014 11:44 AM
    05-14-2014 10:54 PM Go to last post
  13. K2005 vs K2006 vs K2006C test kits
    Can anyone tell me the difference in the Taylor K2005 and K2006 test kits? They also offer the same part numbers with a "C" on the end. Any help is...
    Started by rob001‎, 04-15-2014 11:42 AM
    04-15-2014 01:00 PM Go to last post
  14. Taylor K2006 vs. test strip results
    So I have been learning alot here and have been convinced that your collective advice is the best advice to follow. My local Leslie's still insists...
    Started by nefretrameses‎, 07-21-2013 10:42 AM
    07-24-2013 07:04 PM Go to last post
  15. Thought i could speed things up but noooo gooo
    Thought I could speed thing up with a small test kit BUT I soon learned I had to go back to my 2006 to be certain of anything. So I went down to buy...
    Started by dansdad‎, 06-18-2013 12:20 AM
    06-18-2013 09:51 AM Go to last post
  16. 2 oz. Refills - will they fit into my kit?
    My Taylor K-2006 came with 0.75 ounce bottles of reagents. If I purchase the 2 oz. refills, will I still be able to fit them into the blue kit and...
    Started by moblaine‎, 07-31-2012 12:39 PM
    08-27-2012 10:29 AM Go to last post
  17. Weird test result for Alkalinity
    I was testing a friends' pool today for alkalinity with the Taylor 2006c kit. I put the 5 drops in and the solution turned green, as it should. But...
    Started by sabres07‎, 08-14-2012 03:18 PM
    08-15-2012 11:14 AM Go to last post
  18. taylor test kit and borax
    I need to raise the ph in my pool- taylor test kit only provides info for raising with soda ash and I want to use Borax- how much to use? Do I...
    Started by shawnw‎, 08-03-2012 12:06 PM
    2 Pages
    1 2
    08-04-2012 08:58 PM Go to last post
  19. 10 ml vs 25ml or 44 ml Samples
    I've read on here and been told to use the 10 ml sample rather than the larger sample sizes in order to save the reagents.....can someone please tell...
    Started by fairfieldmania‎, 07-11-2012 10:15 AM
    08-01-2012 11:01 AM Go to last post
  20. First Time using Taylor HELP!!!!!!!!!!!!!!
    Filled pool week ago then shocked with liquid shock from Leslies and been using Chlor-Brite dichlor 1 ounce a day. Pool holds 5700 gallons. Today...
    Started by mroll‎, 06-28-2012 02:10 PM
    8 Pages
    1 2 3 ... 8
    07-19-2012 12:35 AM Go to last post
  21. Can't clear CC or reach an FC level after tons of bleach - FAS-DPD testing
    *** I'm starting a new post to keep it focused. Including the most relevant previous replies to the topic: Results of bucket testing...
    Started by JuJuBee‎, 05-26-2012 01:36 PM
    bucket test, combined chlorine, raising fc, removing cc, shocking
    06-05-2012 08:22 AM Go to last post
  22. refills
    where is best and cheapest place to get refills for k-2006 kit really just the 0871 reagent
    Started by airraid1999‎, 05-23-2012 09:49 AM
    06-04-2012 02:25 PM Go to last post
  23. Taylor Fas-DpD Test Kit K-2006
    Hello, I'm somewhat new to this forum, so please excuse me if this question is redundant. I have an issue with CC, when I use the...
    Started by hvactech2‎, 05-27-2012 06:48 PM
    2 Pages
    1 2
    05-29-2012 08:28 PM Go to last post
  24. How to test the liquid shock from pool store for it's available chlorine
    Basically, I need to know exactly how to use my FAS-DPD kit to test the Malibu Pool Shock (liquid chlorine 12.5%) itself. I'm suspicious that it is...
    Started by JuJuBee‎, 05-23-2012 10:12 AM
    dilution chemistry, dilutions
    05-23-2012 02:17 PM Go to last post
  25. Lost Parts
    I have a Taylor K-2006 test kit. I lost the caps for my comparator. I am getting tired of using my palm to close off the test comparator when...
    Started by jhk49‎, 05-06-2012 05:23 PM
    05-06-2012 07:16 PM Go to last post
  26. saving on reagent for chlorine testing
    I've been using my k2006 to get my pool in order this year and since I have a lot of chlorine testing early in the process, I could see I'd run out...
    Started by keastman‎, 04-07-2012 03:08 PM
    04-07-2012 03:46 PM Go to last post
  27. K-2006 test kit, just a few thoughts
    I got my K-2006 test kit a few weeks ago and I think Taylor kinda missed the boat on the Powder with the little dipper for the chlorine test. My...
    Started by BigTallGuy‎, 08-17-2011 08:33 PM
    2 Pages
    1 2
    11-25-2011 11:20 PM Go to last post
  28. Question Refill R-0871
    Love my K-2006! I will clearly need to replenish R-0871 soon. The larger bottles of R-0871 are quite a bit cheaper than the 0.75 oz. The...
    Started by BigDave‎, 08-15-2011 11:00 AM
    2 Pages
    1 2
    08-15-2011 08:35 PM Go to last post
  29. Tested Water to Start BBB method
    Ok...Figured out how to use my testing kit. It's a taylor K-2006. This is just water out of my tap...since we are starting to fill the pool today. ...
    Started by HollyClo‎, 07-20-2011 03:52 PM
    2 Pages
    1 2
    08-05-2011 01:57 PM Go to last post
  30. I want the CC test only
    Is there a way, using the Taylor K-2006 kit, to just skip over the FC test and go directly to the CC test? When doing the CC test following the...
    Started by famousdavis‎, 07-28-2011 01:46 PM
    08-02-2011 11:13 AM Go to last post
+ Post New Thread
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 15 replies or 150 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
