+ Post New Thread
Page 10 of 67 FirstFirst ... 8 9 10 11 12 20 60 ... LastLast
Threads 271 to 300 of 2006
Forum: Testing and Adjusting Pool Water Chemistry
Which kit? Why? How? What does it all mean?
  1. Sticky Thread Sticky: How to Get the Testkits You Need!
    ____________________________________ How to Get the Testkits You Need! ____________________________________ We constantly ask people to get...
    Started by PoolDoc‎, 06-29-2018 09:20 AM
    06-29-2018 09:20 AM Go to last post
  2. Sticky Thread Sticky: Beginner's Guide to Pool Chemistry & the BBB Method
    __________________________________________ Beginner's Guide to Pool Chemistry & the BBB Method __________________________________________ . ....
    Started by PoolDoc‎, 06-28-2018 01:20 PM
    06-28-2018 01:20 PM Go to last post
  3. Sticky Thread Sticky: FAQs & Guides: Testing & Adjusting Pool Chemistry
    __________________________________________________ FAQs & Guides: Testing & Adjusting Pool Chemistry Getting the RIGHT test kit for your pool ...
    Started by PoolDoc‎, 05-30-2018 03:51 PM
    05-30-2018 03:51 PM Go to last post
  1. We're new and in deep!
    Hello, we're newly registered members to the forum, although we've been using the forum for a few months now in reference to our Intex 16x48 pool....
    Started by bzbrown‎, 07-08-2013 04:34 PM
    07-09-2013 02:47 PM Go to last post
  2. Full refill ballpark chemical amounts
    I just replaced the liner in my 18' AG that is about 7000 gallons, which I am filling now. I am ordering the Taylor K-2006, but would like to get...
    Started by db4570‎, 07-07-2013 01:52 AM
    07-08-2013 01:29 PM Go to last post
  3. Use of algaecide
    I've posted several times before that my husband is frustrated/not completely supportive of the BBB method. Mostly because I keep messing it up...
    Started by onemsmom‎, 06-29-2013 09:10 AM
    07-07-2013 04:33 PM Go to last post
  4. Another new pool owner and BBB convert
    Bought a house over the winter that came with a 12 year old, 38x18, above ground, 20,000 gallon pool. Wasn’t looking to be a pool owner, but here I...
    Started by ccs717‎, 07-03-2013 02:35 PM
    07-05-2013 01:28 PM Go to last post
  5. Use of muratic acid with indoor pool that uses bromine?
    Can i use muratic acid to lower the PH of my indoor pool that uses bromine??? I have constant high readings of PH. My local pool store says it is...
    Started by greg1234‎, 07-03-2013 11:27 PM
    07-04-2013 11:12 PM Go to last post
  6. Question Nefretrameses: HI2C pool
    Ben, I have a HI2C pool, not by design,but by circumstances. Draining half the pool to lower CYA is not appealing. You mention "adjustments to...
    Started by nefretrameses‎, 07-03-2013 10:06 PM
    07-04-2013 12:17 PM Go to last post
  7. Question OTO chlorine test is orange . . . for a month
    For over a month I've been trying to figure out why my chlorine test turn an orange color instead of yellow. After being told to shock the pool we...
    Started by Houseofhutch‎, 07-01-2013 05:03 PM
    hic2, orange oto, sticky
    07-03-2013 10:49 PM Go to last post
  8. How to keep water clean without running pump and filter?
    Hi, I'm a first time pool owner. Two weeks ago I opened my pool (21' round that came with the home I bought last winter), and with some help was...
    Started by mike83‎, 07-01-2013 06:54 PM
    07-01-2013 07:42 PM Go to last post
  9. Hello from Texas.... Getting Started with the BBB Method
    Not new to pools. I've had a 36'x18' in ground pool since 2005. What i AM new to is the BBB method, and all the great advice on this forum. Thanks to...
    Started by Lonestar‎, 06-29-2013 12:38 PM
    07-01-2013 05:54 PM Go to last post
  10. starting fresh with new liner....
    We are patiently waiting for our new IG liner to be installed....looking forward to not having to deal with liner pulls and shrunken old liner issues...
    Started by heatherc‎, 06-28-2013 07:42 AM
    07-01-2013 05:52 PM Go to last post
  11. CYA Craziness !
    OK.... 2 weeks ago, I received readings of ZERO on the CYA Test... I picked up a container of CYA Stabilizer and after doing the math and based on...
    Started by stma‎, 06-30-2013 10:09 AM
    06-30-2013 10:09 AM Go to last post
  12. High alkalinity, but everything else great
    This is my second year with our Intex 5,000 gallon pool. We have the bigger pump and also the SWG system. Last year, things went really well once I...
    Started by Pool8‎, 06-29-2013 05:20 PM
    06-30-2013 01:36 AM Go to last post
  13. Compatibility of Walmart 6-way and Taylor R-0013
    Hi all been lurking for a while just finaly joined. My questioin is will the Taylor Cyanuric Acid 2 oz R-0013-C be compatible with my 6-way hth kit...
    Started by cpg0626‎, 06-26-2013 08:45 AM
    06-27-2013 05:40 PM Go to last post
  14. Test results on my new pool
    FC 6 CC 0 PH 7.8 TA 130 CA 170 CYA 30 What do all you seasoned people think? This is my first pool.
    Started by t-cell‎, 06-23-2013 10:56 AM
    06-26-2013 09:27 PM Go to last post
  15. new test kit - checking combined chlorine?
    I got my new K-2006 kit in and started the learning process. I know that to check combined chlorine, you begin to drop one drop the R-0871 reagent...
    Started by samtex‎, 07-12-2011 05:38 PM
    06-26-2013 12:16 AM Go to last post
  16. Brainiacs .......need numbers please
    Since I was told on this forum the 2006 Chemistry book is worthless info, I need to make a list of ch,ph etc...Thank You dave
    Started by dansdad‎, 06-23-2013 12:07 AM
    06-25-2013 09:19 PM Go to last post
  17. New pool, trichlor tabs for the past 17 years, Where do I go from there?
    I've bought a house with a 30K gallon pool, and I'm completely new to pool maintenance. It has a vinyl liner with an opaque cover, and since i'm in...
    Started by dmeyer‎, 06-23-2013 06:37 PM
    06-24-2013 10:08 PM Go to last post
  18. Hello new friends and first test numbers.
    Hello everyone. I came across this site after my last run-in with the teenager at the pool store who was analyzing my pool water. I only resorted to...
    Started by shastablast‎, 06-20-2013 09:11 PM
    06-24-2013 09:51 PM Go to last post
  19. Question Different set of numbers for fiberglass????????
    As you can tell I have a fiberglass pool and am seeing different numbers. Is there a set of numbers for a fiberglass? Such is ph 7.2-7.6 or maybe 7.5...
    Started by dansdad‎, 06-23-2013 10:17 PM
    06-24-2013 12:12 AM Go to last post
  20. What to do first?
    I started using a K-2006 for testing this year. These are my most recent results but I'm really not sure what to correct first. FC 102 ppm PH 7.2...
    Started by spongebob55‎, 06-23-2013 03:13 PM
    06-23-2013 09:26 PM Go to last post
  21. Might be a good idea for us unknowns
    I look to see any top info from the TOP GUNS and put it on my desktop on Windows 8 tile. Well worth it
    Started by dansdad‎, 06-23-2013 05:27 PM
    06-23-2013 05:27 PM Go to last post
  22. Using 2006 pool and spa water chemistry book
    I am going by my k-2006 booklet before I add anything? yes ? no? I was using it as a guide. Should I use it as a pool Bible
    Started by dansdad‎, 06-22-2013 03:35 PM
    06-23-2013 01:35 PM Go to last post
  23. Ben.......watermom..someone
    how can a pool with a chlorine level of 5.0 and low ph have yellow on the edge of the pool??
    Started by dansdad‎, 06-21-2013 03:43 PM
    06-22-2013 08:35 PM Go to last post
  24. Chlorine high and Ph low but the algae is gone...now what?
    I had an algae problem that I got rid of by following information from this site... I added a few bottles of bleach (3 gal then 2 days later 2 gals...
    Started by karenib‎, 06-22-2013 12:43 PM
    06-22-2013 08:23 PM Go to last post
  25. Would you folks even bother??????
    Hey Thanks to all you c l is 3.3 ph is 7.5 and pool looks good. Calculator says I could add 3/4 cup muriatic acid for my 13000 pool. Would you even...
    Started by dansdad‎, 06-22-2013 03:09 PM
    06-22-2013 08:09 PM Go to last post
  26. OTO or FAS DPD for testing Chlorine
    Hi! I have read that the OTO is the most reliable test yet have not tried it. I purchased the FAS DPD test I believe 2 years ago from Ben (??) or...
    Started by Redwolf‎, 06-20-2013 05:28 PM
    06-22-2013 05:00 PM Go to last post
  27. First test readings of season
    To start off with, I messed up big time. I didnt cover my pool in the fall and we started with a frog pond, yes we had frogs. I didnt have the...
    Started by michael3‎, 06-02-2013 07:28 PM
    12 Pages
    1 2 3 ... 12
    amz
    06-22-2013 04:29 PM Go to last post
  28. Unable to keep chlorine level and CYA level has dropped from 38 to 21 in 1 day.
    Unable to keep a chlorine level in my pool. Shock it again yesterday and my reading is zero. My CYA level dropped from 38 yesterday to 21. Pool store...
    Started by lizbyrne2000‎, 06-17-2013 12:48 PM
    pool-stored, sticky
    06-22-2013 11:41 AM Go to last post
  29. How to Use Trichlor Tabs
    Hi, Today's test results using Taylor K-2006: FC: 2 ppm, CC: 0.0, pH: 7.4, Alkalinity: 100, CYA: 30, Borates: 50 Because we've had a lot of...
    Started by TheKs‎, 06-20-2013 07:14 AM
    06-20-2013 07:14 AM Go to last post
  30. Replacing old reagents in Taylor test kit
    Do they all need replacing every year or does storing them in a mild dark location make a difference? I need to order some CYA test reagent i am...
    Started by jilted‎, 06-19-2013 11:11 AM
    06-19-2013 03:17 PM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
