+ Post New Thread
Page 4 of 67 FirstFirst ... 2 3 4 5 6 14 54 ... LastLast
Threads 91 to 120 of 2006
Forum: Testing and Adjusting Pool Water Chemistry
Which kit? Why? How? What does it all mean?
  1. Sticky Thread Sticky: How to Get the Testkits You Need!
    ____________________________________ How to Get the Testkits You Need! ____________________________________ We constantly ask people to get...
    Started by PoolDoc‎, 06-29-2018 09:20 AM
    06-29-2018 09:20 AM Go to last post
  2. Sticky Thread Sticky: Beginner's Guide to Pool Chemistry & the BBB Method
    __________________________________________ Beginner's Guide to Pool Chemistry & the BBB Method __________________________________________ . ....
    Started by PoolDoc‎, 06-28-2018 01:20 PM
    06-28-2018 01:20 PM Go to last post
  3. Sticky Thread Sticky: FAQs & Guides: Testing & Adjusting Pool Chemistry
    __________________________________________________ FAQs & Guides: Testing & Adjusting Pool Chemistry Getting the RIGHT test kit for your pool ...
    Started by PoolDoc‎, 05-30-2018 03:51 PM
    05-30-2018 03:51 PM Go to last post
  1. Test results, a little help please
    Ok I got the k2006 test kit and finally got the pool tested. Here are my results. Intex 20x52 9,400 gallons sand filter with Salt generator ...
    Started by dtjoseph95‎, 07-15-2014 02:25 PM
    07-16-2014 01:02 PM Go to last post
  2. Phosphate testing
    Algae keeps trying to come back to my pool. I'm all over it with shock levels as needed and regular cleaning. No biggie really. The water is nice and...
    Started by Big Splash‎, 06-27-2014 11:43 AM
    4 Pages
    1 2 3 ... 4
    phosphate remover, sticky, sticky-phosphate
    07-15-2014 04:05 PM Go to last post
  3. How to test for borates
    I have the 2006 by taylor, and all I ever test for is cl, ta, ph,cya, so how do I test to see if I need borates and how much? Thank you Dave G
    Started by dansdad‎, 07-13-2014 03:49 PM
    07-13-2014 08:57 PM Go to last post
  4. CYA test interpretation
    These three images, snagged from Taylor's website illustrate correct CYA test interpretation: Take your CYA reading AFTER you reach...
    Started by PoolDoc‎, 07-11-2014 04:46 PM
    07-11-2014 04:46 PM Go to last post
  5. should algea preventer be used if none present
    I have been using BBB method all year for the first time and all my test results with the taylor kit adding bleach ea day are where they should...
    Started by rajung‎, 07-10-2014 09:29 AM
    07-10-2014 04:43 PM Go to last post
  6. Adjusting pH and TA
    My pool is running crystal clear after the algae debacle that lead me to this forum... Thanks so much for all of the assistance :) My pH is very...
    Started by Traxl‎, 07-05-2014 02:08 PM
    07-05-2014 03:44 PM Go to last post
  7. Methold of pouring bleach
    I looked everywhere for this answer because I know it has to be here somewhere...but couldn't find it When you pour bleach directly into the...
    Started by rdbrya1‎, 06-26-2014 02:36 PM
    07-03-2014 05:28 PM Go to last post
  8. Two months of Pool testing results on a new pool...
    I had a 15,000 gallon in-ground gunite/plaster pool built this spring. It has a waterfall from the spa to the pool and a pool fountain. It has a...
    Started by Usilpool‎, 07-02-2014 06:23 PM
    07-03-2014 03:33 PM Go to last post
  9. high chlorine or lower chlorine + polyquat
    Are either of these methods much better than the other in preventing algae or other problems? My CYA is around 100. Up until now I am just using...
    Started by rdbrya1‎, 07-02-2014 04:54 PM
    07-02-2014 05:29 PM Go to last post
  10. what to add first
    just opening pool, 21,000 inground, vinyl liner, sand filter. pool is clear, but does appear to have some light brownish on deep end of pool. it's...
    Started by poolhelp101‎, 06-27-2014 06:21 PM
    06-28-2014 12:36 AM Go to last post
  11. Opinion on my pool chemical maintenance
    I've been browsing the forum reading previous post since 8am (sorry boss!!) and as long as it has taken me to finally grasp my pool chemistry, I feel...
    Started by rdbrya1‎, 06-26-2014 02:11 PM
    06-27-2014 11:21 AM Go to last post
  12. High reading for CC after shock treatment
    I was going to drain my spa water into the pool, The water looked good with a CL reading of 3 & ph at 7.4. Just to be on the safe side I poured 8 oz...
    Started by poolaris‎, 06-26-2014 09:31 AM
    2 Pages
    1 2
    06-27-2014 12:04 AM Go to last post
  13. How do I decrease the Ph
    The Ph in my pool looks to be above 8.2, Please help me, How do I decrease the ph by spending least amount of money
    Started by vrrpool‎, 06-25-2014 11:57 PM
    06-26-2014 08:43 PM Go to last post
  14. Question Rookie pool guy - 10K above ground vinyl liner - almost there, pool a little cloudy..
    Pool Forum, Hello! Thank you for building and maintaining this site, it has proven incredibly effective in assisting me with getting my...
    Started by jcrowejc4‎, 06-25-2014 01:50 PM
    06-26-2014 05:32 PM Go to last post
  15. Hello, New to Forum.
    Hello, We have recently installed the 22' x 52" intex AG pool. And of course we filled it before finding this site. So, I for see needing lots of...
    Started by mcbdz‎, 05-26-2014 10:51 AM
    5 Pages
    1 2 3 ... 5
    06-26-2014 07:29 AM Go to last post
  16. Total and Adjusted Alkalinity - Should I be adding Baking Soda?
    I have been using my K2006 test kit and adjusting my own water for about 2 months now and so far so good :) Occasionally I will take a sample to...
    Started by rdbrya1‎, 06-25-2014 04:17 PM
    06-25-2014 05:07 PM Go to last post
  17. TA Creeping High - Why?
    Facts: Indoor Home Pool Age 4 years Plaster finish Size 12x16 – approx. 7000 gallons Sanitation via UV and a 3” chlorine tab each week...
    Started by blentz‎, 06-24-2014 01:16 PM
    06-24-2014 11:10 PM Go to last post
  18. Chlorine advice
    Stumbled upon this site looking for solutions to our problem of our pool not being able to hold chlorine for the last couple of years. Has been a...
    Started by nsandbloom‎, 06-23-2014 01:25 PM
    06-24-2014 12:57 PM Go to last post
  19. Recruiting FLA, GA, SC, NC pool owners for paid participation ($75) concept testing
    Hello pool community. First time posting and hope this outreach reaches you well as your input will be tremendously important. I wanted to reach out...
    Started by Macadamian‎, 06-23-2014 09:59 AM
    06-24-2014 11:37 AM Go to last post
  20. Green Pool (Was black at first)
    Hi, Just opened my 30k gallon pool a week ago. Some background info: Pool has a sand filter and sand was replaced last year. Pool is...
    Started by like2ct‎, 05-30-2014 06:57 PM
    4 Pages
    1 2 3 ... 4
    sticky, sticky-colorq
    06-24-2014 09:44 AM Go to last post
  21. Frustrated!!!!
    So I put up our new pool, Pro Series 14x42 steel frame. I am guilty of not doing my complete research and have myself in a mess. It took us a week...
    Started by Elisabeth‎, 06-21-2014 10:26 PM
    2 Pages
    1 2
    06-23-2014 09:29 PM Go to last post
  22. Question Did I just measure my pool volume by comparing before/after chlorine levels?
    I am lazy and don't want to measure my new pool. It's an odd twisted peanut shape. Maybe I would like to measure it but I don't really know how. So I...
    Started by svenborgia‎, 06-23-2014 02:26 AM
    06-23-2014 06:41 PM Go to last post
  23. Starting resurfaced pool
    My pool just got resurfaced with pebble sheen and a measure at the water meter during fill up showed it is 14,000 gallons. I've been following...
    Started by Kidney‎, 06-08-2014 12:10 PM
    4 Pages
    1 2 3 ... 4
    sticky, sticky-cripto
    06-21-2014 10:34 PM Go to last post
  24. Testing CC with K-2006
    I just bought my first real test kit (K-2006) and tried to test Free and Combined Cl. I used the 25 ml sample size. Free Cl measures 1.0 ppm (5...
    Started by bottomcat‎, 06-19-2014 10:06 PM
    06-20-2014 08:54 PM Go to last post
  25. Cool cloudy water
    We took the mesh safety cover off of our pool Memorial Day weekend, only to find that the pump died. Finally had a new pump installed this past...
    Started by poolmompa‎, 06-12-2014 03:20 PM
    2 Pages
    1 2
    06-20-2014 05:07 PM Go to last post
  26. Cool Daily Chlorine amount
    Hello Everyone! Just a quick question from a very pleased BBB method user. All of my levels are good thanks to this method. Saves me lots and lots of...
    Started by tnalaskan‎, 06-16-2014 11:14 AM
    06-18-2014 06:30 PM Go to last post
  27. First post current numbers
    FC 6ppm CC 0.2 PH 8.0 very red TA 150ppm CH 60ppm CYA 0 30L x 12W x 8D x 4D x 7.48 = 16157 Gallons In ground pool. Very old. We had it...
    Started by lfriederichsen‎, 06-16-2014 02:20 PM
    06-18-2014 03:28 PM Go to last post
  28. Testing CYA with dilution
    Watermom, please explain this more? I'm curious... Here is what you had said: Mix a cup of pool water with a cup of distilled water and use...
    Started by Hermskii‎, 06-11-2014 09:11 AM
    06-17-2014 07:26 PM Go to last post
  29. My cloudy pool
    Long story short Just bought the house in September. My first pool. It never was crystal clear last year, so I had it closed by a local pool co....
    Started by nateshirk‎, 06-09-2014 02:32 PM
    3 Pages
    1 2 3
    06-17-2014 01:52 PM Go to last post
  30. Good numbers, no slime, but still VERY CLOUDY???
    For the most part, I've had good numbers since I got rid of the swamp. I have had up to 2.5 CC and my pH has been a little low, needing as many as 6...
    Started by RandiBGood‎, 06-15-2014 05:40 PM
    06-16-2014 09:11 PM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
