+ Post New Thread
Page 51 of 67 FirstFirst ... 41 49 50 51 52 53 61 ... LastLast
Threads 1501 to 1530 of 2006
Forum: Testing and Adjusting Pool Water Chemistry
Which kit? Why? How? What does it all mean?
  1. Sticky Thread Sticky: How to Get the Testkits You Need!
    ____________________________________ How to Get the Testkits You Need! ____________________________________ We constantly ask people to get...
    Started by PoolDoc‎, 06-29-2018 09:20 AM
    06-29-2018 09:20 AM Go to last post
  2. Sticky Thread Sticky: Beginner's Guide to Pool Chemistry & the BBB Method
    __________________________________________ Beginner's Guide to Pool Chemistry & the BBB Method __________________________________________ . ....
    Started by PoolDoc‎, 06-28-2018 01:20 PM
    06-28-2018 01:20 PM Go to last post
  3. Sticky Thread Sticky: FAQs & Guides: Testing & Adjusting Pool Chemistry
    __________________________________________________ FAQs & Guides: Testing & Adjusting Pool Chemistry Getting the RIGHT test kit for your pool ...
    Started by PoolDoc‎, 05-30-2018 03:51 PM
    05-30-2018 03:51 PM Go to last post
  1. ? regarding the Walmart/Aquachem 6 way
    If anyone uses this kit...When I do the water hardness test, the first step is to add 2 drops of the hardness solution A and mix. It says a violet...
    Started by jnorris‎, 07-17-2006 09:18 PM
    07-18-2006 08:52 PM Go to last post
  2. Smile Best Guess Chart
    I can't seem to find Ben's best guess chemical level chart for the correct levels based on CYA etc. Any help would be great
    Started by cav‎, 07-17-2006 03:42 PM
    07-18-2006 05:13 PM Go to last post
  3. ph & chlorine test meter -can someone help me to calibrate it
    i bought this "electro tester" a few seasons ago. It runs on one AA battery and I don't have the directions to calibrate it anymore. can anyone help?...
    Started by sflaster‎, 07-18-2006 11:42 AM
    07-18-2006 05:02 PM Go to last post
  4. Adjusted? Total ALk?
    Hi, It's been very, very hot here recently. To compound matters I had our heater fixed and the tech cranked the thermostat up which I missed. ...
    Started by CoffeeBean‎, 07-18-2006 11:09 AM
    07-18-2006 01:35 PM Go to last post
  5. how long to get accurate cc reading
    I have noticed after doing the test for cc and fc that at first the cc is clear. But after sitting there for a while it slowly goes from light pink...
    Started by newtopools‎, 07-17-2006 10:24 PM
    07-18-2006 12:54 PM Go to last post
  6. High Alk with stable PH question
    Hi everyone. Here are my numbers from this morning: TC - 2 PH - 7.5 ALK- 220 I know the Alk is high. I've tried to lower it using the "how...
    Started by denanbob‎, 07-18-2006 11:11 AM
    07-18-2006 12:10 PM Go to last post
  7. pH color deciphering
    I thought that what I was experiencing with my pH tests had to do with older reagents - but I replaced them Friday and I have the same issue: ...
    Started by KirstenHW‎, 07-17-2006 01:38 PM
    07-18-2006 11:07 AM Go to last post
  8. Help with pool!
    I am trying to help my mom and dad with their pool in Illinois. It's a vinyl liner in-ground pool, L-shaped, between 30K and 40K gallons (I'm trying...
    Started by illinipdx‎, 07-17-2006 06:01 PM
    07-18-2006 09:50 AM Go to last post
  9. Uncle used "copper" something or other.....
    Hi All, While trying to educate my family with pools on the BBB method my uncle informed me of his problem. He has an ag pool and he says his water...
    Started by cruzmisl‎, 07-17-2006 10:30 PM
    07-18-2006 07:23 AM Go to last post
  10. New pool, 1st water test results, suggestions?
    Well, with a lot of great advice and kind words from you all here, the manual labor is over and the pool is finally filled - (5400 gallon Intex) - I...
    Started by amyinraleigh‎, 07-17-2006 08:39 AM
    07-17-2006 09:21 PM Go to last post
  11. Lightbulb Testing kit ps234
    I can't seem to find out where to buy this testing kit, or a 'better' one. Can I send someone an email? Please advise. Thanks, Doug
    Started by PurpleTurkey‎, 07-17-2006 06:19 PM
    07-17-2006 06:55 PM Go to last post
  12. Taylor k2005 vs k2006 kit
    Since, I live in Canada and Ben does not ship his test kits to Canada, I have decided to get the next best thing which I have been told is the Taylor...
    Started by hancop‎, 07-17-2006 10:59 AM
    07-17-2006 05:03 PM Go to last post
  13. PH, Alk, Borax and Acid oh-my
    OK, maybe I am playing the yo-yo game with my pool water chemistry... and after getting my new ps234, I now realize how OFF my "wally world" kit...
    Started by darenjones‎, 07-15-2006 06:44 PM
    07-17-2006 03:02 PM Go to last post
  14. Where to buy reagent refills
    I need to buy reagent refills and will have to buy via the internet. Any suggestions as to the best source? Thanks, Dave
    Started by dhale63‎, 07-17-2006 12:14 AM
    07-17-2006 01:11 AM Go to last post
  15. New Donut pool owner Questions
    We got our little 14x42 donut for fathers day. We have managed to keep it fairly clean. I am reading here about usinc common bleach instead of the...
    Started by edlentz‎, 07-16-2006 09:27 AM
    07-16-2006 09:26 PM Go to last post
  16. 50 ppm Borax
    Hi, What's the advantage to having Borax level at 50ppm? I noticed it on Mike's calculator, and on the "Alex" printout from the pool store (listed...
    Started by Henry3‎, 06-14-2006 07:53 PM
    2 Pages
    1 2
    07-15-2006 07:53 PM Go to last post
  17. Help with raising ph
    I have a vinyl pool 22,000 gal Icant get the ph up Ihave put 3 boxes of borax in and still get a 6.8 reading. Clorine is hi and alk is about 110. can...
    Started by ccc‎, 07-15-2006 03:52 PM
    07-15-2006 04:42 PM Go to last post
  18. Is this a decent test kit?
    It's the one at Leslie's. I will probably buy Ben's kit, but I need it this week....
    Started by court475‎, 07-15-2006 02:27 PM
    07-15-2006 03:45 PM Go to last post
  19. lowering alkaline
    Happy Summer Everyone :) 16k gallon IG Vinyl FC=6 CC=0 TC=6 PH=7.6 TA=200 CYA=39
    Started by maryberrye‎, 07-14-2006 09:37 PM
    07-15-2006 01:13 PM Go to last post
  20. help with chlorine
    I cant get chlorine to regester Ph is 6.9 I put boraxo in to bring it up. Alk is at about 80. Iuse 6way tester from Walmart
    Started by ccc‎, 07-13-2006 07:42 PM
    07-15-2006 01:41 AM Go to last post
  21. OTO test
    Ok super newbie here but I have been reading as much as I can. I have a 27' AG pool. I recently added Borox to correct low ph. However after...
    Started by resormar‎, 07-14-2006 10:56 AM
    07-14-2006 10:09 PM Go to last post
  22. Testing my tap water pH
    Using Taylor reagents, my pool water pH tests at 7.8. My tap water is also 7.8. I always assumed tap water would have a neutral pH of 7 or at least...
    Started by hulla‎, 07-11-2006 09:59 PM
    2 Pages
    1 2
    07-14-2006 09:32 PM Go to last post
  23. Should I be worried....
    I have be come a faithfull reader of the pool forum..pretty much check it every day to see if i am having the same problems as someone else. I don't...
    Started by dkdog68‎, 07-14-2006 09:35 AM
    07-14-2006 01:09 PM Go to last post
  24. New Kit or new reagents
    I'm still reading and trying to get a handle on this stuff. Question about test kits. I have a kit but the readings only go to 3.0 on the chlorine...
    Started by H2OLogged‎, 07-11-2006 09:16 AM
    2 Pages
    1 2
    07-14-2006 12:10 PM Go to last post
  25. Testing Bleach Strength
    Back in my previous life (about 1969) I worked at a chemical company in the Houston area that made industrial strength Sodium Hypochlorite. I think...
    Started by fcfrey‎, 07-13-2006 10:52 PM
    07-13-2006 11:13 PM Go to last post
  26. safe depth to drain vinyl pool w/vinyl stairs
    I'm getting ready to drain my inground vinyl lined pool at least halfway. My husband is freaking out that we shouldn't drain it. One place on the...
    Started by ScottsdaleSwim‎, 07-01-2006 02:26 PM
    2 Pages
    1 2
    07-13-2006 12:47 AM Go to last post
  27. A stupid "old bee" question
    I have been reading posts that the chlorine level needs to be higher than "normal" based on your CYA level. I was hoping someone might be able to...
    Started by cleancloths‎, 07-12-2006 11:02 AM
    07-12-2006 06:11 PM Go to last post
  28. New SWG and 300 CYA problem
    Newbie here from 112 degree Phoenix. I have had a clorine pool and have been proud of the condition I kept it in. Just had a topline SWG installed....
    Started by Reggie‎, 07-11-2006 11:02 PM
    07-12-2006 05:31 PM Go to last post
  29. Leslie's (Same as Poolmaster?)OTO Kit - Need Instructions
    I have used the basic five bottle kit bought at Leslie's for years. Unfortunately the lid fell off & got lost so there went the instructions....
    Started by pspercy‎, 07-09-2006 06:42 PM
    07-12-2006 01:56 PM Go to last post
  30. The scariest water I have ever seen in my life!
    As some of you know I work in a pool store full time summers and part time when the school I work at is in session. Today I tested the water for a...
    Started by waterbear‎, 07-11-2006 07:33 PM
    07-12-2006 09:28 AM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
