+ Post New Thread
Page 1 of 67 1 2 3 11 51 ... LastLast
Threads 1 to 30 of 2006
Forum: Testing and Adjusting Pool Water Chemistry
Which kit? Why? How? What does it all mean?
  1. Sticky Thread Sticky: How to Get the Testkits You Need!
    ____________________________________ How to Get the Testkits You Need! ____________________________________ We constantly ask people to get...
    Started by PoolDoc‎, 06-29-2018 09:20 AM
    06-29-2018 09:20 AM Go to last post
  2. Sticky Thread Sticky: Beginner's Guide to Pool Chemistry & the BBB Method
    __________________________________________ Beginner's Guide to Pool Chemistry & the BBB Method __________________________________________ . ....
    Started by PoolDoc‎, 06-28-2018 01:20 PM
    06-28-2018 01:20 PM Go to last post
  3. Sticky Thread Sticky: FAQs & Guides: Testing & Adjusting Pool Chemistry
    __________________________________________________ FAQs & Guides: Testing & Adjusting Pool Chemistry Getting the RIGHT test kit for your pool ...
    Started by PoolDoc‎, 05-30-2018 03:51 PM
    05-30-2018 03:51 PM Go to last post
  1. Cal-Hypo impact on PH
    Hi I am using Cal Hypo and seeing rise in PH (from 7.5 to about 8). I know Cal Hypo has a PH of 10.8-11 and i know i can bring down ph using...
    Started by CJDahl‎, 06-18-2022 11:16 AM
    cal-hypo impact on ph
    05-26-2023 06:16 PM Go to last post
  2. Angry High Chlorine Demand / PH stubborn to go up
    Hello ! ok , so I built up the CYA to respectable 20-30ppm and threw in 3.5 gallons of liquid chlorine from my pool store. Put in 3 floating...
    Started by tommypenngotti‎, 04-19-2021 05:25 PM
    04-20-2021 02:51 PM Go to last post
  3. Is anyone here?
    I see there have been no replies since June. It's probably been 10 years since I visited, but this site save my bacon more than once. I have a...
    Started by sdbob‎, 09-27-2020 07:52 PM
    09-27-2020 07:52 PM Go to last post
  4. 17K AG pool, High pH, No Chl or CNY, Visible algea
    I've been doing BBB method by learning & using this forum for years. I'm trying to help friends who just had a 17K gallon, AG, vinly pool, with sand...
    Started by ksherman‎, 08-28-2020 11:19 AM
    algea, high ph, low cny
    08-28-2020 11:19 AM Go to last post
  5. Averaging 1 gallon of liquid chlorine per day
    I’m having a strange issue which I’ve never had before. Little back story, I got a little lazy and ended up with an algae bloom for the first time in...
    Started by Jacob99‎, 07-30-2020 02:12 PM
    07-30-2020 02:12 PM Go to last post
  6. Cloudier than pH and mineral content justfy?
    My water is much cloudier than I ever remember it--I can only see down a couple of inches. I tested it with my K-1006 and the pH is 7.2 and the...
    Started by Whetstone613‎, 07-08-2020 02:30 PM
    07-08-2020 02:30 PM Go to last post
  7. foam and somwhat cloudy.
    Currently light white foam on top, can see down 8 to 10 inches clearly, beyound that lightly cloudy, whiteish. Using a salt water chlorinator. ...
    Started by bssage‎, 06-25-2019 12:51 PM
    06-25-2019 12:51 PM Go to last post
  8. Smile Muriatic Acid Useful Life or Expiration Date
    How long does Muriatic Acid last in its original gallon bottle? I have some that must be at least 3 yrs. old. Thanks.
    Started by swimer‎, 04-27-2018 07:20 PM
    2 Pages
    1 2
    06-18-2019 11:20 AM Go to last post
  9. What is the glue used in vinyl repair kits
    I have seen profesional pool companies using the same glue that comes in vinyl repair kits but in a can like PVC cement comes in. What is that glue...
    Started by wgregww‎, 06-16-2019 07:49 PM
    06-16-2019 07:49 PM Go to last post
  10. Excessive amounts of baking soda needed to raise TA
    Following a few weeks of heavy rains my TA dropped to 30. I then started adding 5# at a time of baking soda every few days but each time the TA...
    Started by poolaris‎, 06-09-2019 09:33 PM
    06-09-2019 09:33 PM Go to last post
  11. CYA and PH
    I understand that when you add cyanuric acid it lowers PH. My question is by how much? I'm needing 10lbs of CYA to raise my level to 50 in my 25000...
    Started by beaverplt‎, 05-25-2019 10:08 AM
    05-28-2019 12:19 PM Go to last post
  12. My water needs help
    I'll keep this brief. 1. Last weekend I vacuumed the brown winter algae to waste and topped off the pool. Water clarity was decent. I could...
    Started by Bosch232‎, 05-12-2019 08:53 PM
    05-15-2019 11:03 PM Go to last post
  13. Is there a basic test kit with distinctive yellow colors?
    My ph and chlorine test kit was purchased at Menards. I see the red shades of color for ph just fine, but I struggle to match the very subtle yellow...
    Started by Booter‎, 06-27-2018 07:09 PM
    12-17-2018 04:36 PM Go to last post
  14. Rookie Pool Owner
    Hello everyone. I stumbled upon this website recently and found a lot of great information. I'm still learning how to properly maintain my pool, and...
    Started by MrGammo‎, 09-02-2018 09:01 PM
    09-05-2018 07:40 AM Go to last post
  15. Chlorine orange; pH high
    I have tried everything. My pool water is clear but it looks green and cloudy. I shocked it, added sodium bromide to reduce PH. I emptied the pool...
    Started by lildixidechic49‎, 07-18-2018 08:16 PM
    07-18-2018 10:49 PM Go to last post
  16. Cloudy water & strange test results - pH 9.0
    I have always had a cartridge filter for my Hydro Force above ground pool. This year a friend gave us a Hayward Ultra-ProLx pump and a Hayward Pro...
    Started by nanny2017‎, 06-18-2018 01:17 PM
    06-18-2018 04:37 PM Go to last post
  17. New user / question about FC test with the K2006
    First let me start by saying as a first time pool owner that the Poolsolutions.com site has been a HUGE help for me to get my solid green swamp pool...
    Started by Pannhead-Pool‎, 06-03-2018 10:12 AM
    06-03-2018 01:29 PM Go to last post
  18. Do You Need a pH Meter to Test Pool pH?
    Many color-blind people can use most of the tests in the Taylor K-2006 without problems. Color does is not usually a problem with the DPD-FAS test...
    Started by PoolDoc‎, 05-02-2012 05:54 PM
    05-31-2018 04:05 PM Go to last post
  19. Borax dosing
    Is there a chart or guidelines to dosing borax? Like ____ amount of borax will raise the ph ______amount for every ____gallons of pool water. Have...
    Started by paigemetoo‎, 05-22-2018 10:50 AM
    05-23-2018 07:17 AM Go to last post
  20. Pool with high CYA levels
    Hello, I recently purchased my first house which also has my first pool! Right now I am swamped in the learning curve of figuring out water...
    Started by vwchris528‎, 05-03-2018 09:49 AM
    05-16-2018 06:30 PM Go to last post
  21. Homemade liquid CYA?
    With the amount of rain we get during the season, requiring pumping out excess water, I usually have to add CYA several times a season. Adding dry...
    Started by JimK‎, 05-13-2018 06:10 PM
    05-16-2018 12:41 AM Go to last post
  22. New pool owner
    What test kit do I order? How do I determine gallon size of pool? After I get kit how do I know how much BBB to add?
    Started by Kimandkris‎, 10-11-2017 12:12 PM
    05-03-2018 09:51 PM Go to last post
  23. Replacing liner Bromine pool
    I am planning on replacing my vinyl liner after 14 years, which obviously means replacing my water. I have had a Bromine pool since the start and...
    Started by Dcape‎, 04-28-2018 08:49 AM
    05-02-2018 09:40 PM Go to last post
  24. Why not Hydrogen Peroxide
    What is the thought process concerning h2o2 vs chlorine. I just bought an Intex 9' x 18' rectangle pool. I have been reading that Hydrogen peroxide...
    Started by ljarosz‎, 08-10-2014 08:52 PM
    05-02-2018 05:58 PM Go to last post
  25. New to pool ownership and care
    I joined the forum and then read the note at the very bottom of the "New Directions for PoolForum in 2018 (in revision)" page saying that this site...
    Started by TheOzz‎, 04-21-2018 08:20 AM
    04-23-2018 10:05 PM Go to last post
  26. Frog leap system
    I recently purchased a new 18 X 52 above ground pool, it came with a frog leap system. I am seeing much positive and much negative with this...
    Started by laxboater‎, 04-19-2018 03:11 PM
    04-21-2018 09:24 PM Go to last post
  27. Exclamation Is boric acid/borax a health concern??
    It appears there is a concern with the Canadian Government with "over" exposure to boric acid. There are no level indicated??? :confused:...
    Started by kamkuda‎, 10-09-2016 07:42 AM
    04-16-2018 12:01 PM Go to last post
  28. steps to getting pool chemistry right
    In what order to adjust these numbers? What are the targets that I'm working towards? My pool is a 25,000 gallon inground, sand filter. CyA...
    Started by marciastz‎, 06-05-2017 10:59 AM
    06-12-2017 02:57 PM Go to last post
  29. Taylor K2006 Videos on YouTube
    Taylor has a number of fairly helpful videos on the K2006 -- but they are huge and hard to access. So, I put them on YouTube. Here they are: K2006...
    Started by PoolDoc‎, 06-22-2012 02:07 PM
    03-14-2017 12:26 PM Go to last post
  30. Chlorine level
    My chlorine level is coming back at less than 0.5 ppm. The sample is pretty much clear after adding the OTO. And when using the Taylor kit with the...
    Started by Barry J‎, 07-24-2016 05:01 PM
    2 Pages
    1 2
    07-29-2016 12:29 PM Go to last post
+ Post New Thread
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 15 replies or 150 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
