+ Post New Thread
Page 12 of 49 FirstFirst ... 2 10 11 12 13 14 22 ... LastLast
Threads 331 to 360 of 1454
Forum: Using Chlorine and Chlorinating Chemicals
Bleach, cal-hypo, trichlor, dichlor, shock and STABILIZER: when, where & how.
  1. Sticky Thread Sticky: FAQs & Guides: Chlorine & Chlorinating Chemicals
    ______________________________________ FAQs & Guides: Chlorine & Chlorinating Chemicals ______________________________________ Pool...
    Started by PoolDoc‎, 06-02-2018 02:00 PM
    06-02-2018 02:00 PM Go to last post
  2. Sticky Thread Sticky: What's the BBB method?
    The BBB page has been expanded, and moved to the-BBB-method-of-swimming-pool-care.html Ben / PoolDoc
    Started by PoolDoc‎, 03-25-2011 09:16 PM
    03-25-2011 09:16 PM Go to last post
  1. Looking for a good online site to buy pool chemicals/supplies
    Just bought a pool and will be opening up next spring. Looking for a good online site to buy from. Tried to view posts but I do not have enough...
    Started by TonyA.‎, 09-07-2011 09:30 AM
    09-07-2011 01:22 PM Go to last post
  2. High PH level while shocking pool question??
    I'm in the process of shocking my pool. It is very GREEN at the moment. My readings at the moment are: Cl: 3.6 PH 8.2 ALK 97 I have a...
    Started by Pipecrew‎, 09-03-2011 09:03 PM
    09-04-2011 02:07 PM Go to last post
  3. Question Chlorine / Bleach
    Hello, I'm kind of new to the forum and have a question. I read an awful lot about using bleach, one even stated unscented bleach. Do people use...
    Started by ts8181‎, 08-31-2011 10:13 PM
    09-01-2011 06:31 AM Go to last post
  4. @CarlD: Liquid Chlorine testing
    Carl: I've seen you mention something similar to the below quote several times- I'd like to know how you go about testing the percent value...
    Started by dhanger‎, 07-14-2010 08:06 PM
    2 Pages
    1 2
    08-31-2011 04:25 PM Go to last post
  5. Question Need 2nd Opinion on % vs Volume vs $ calculation/assumptuion
    Hi Eh! Up here (in the Great White North) Walmart doesn't have an Ultra Wally brand. (there is an Ultra Javex jug, but it's only 5% and $4?..can't...
    Started by Sponge1971‎, 08-26-2011 11:46 AM
    3 Pages
    1 2 3
    08-30-2011 10:17 AM Go to last post
  6. Trichlor Feeder
    So from everything I have read on the forums, and my own experience over the last 3 weeks, I am thinking I should just discontinue using this...
    Started by Redtickbeer‎, 08-29-2011 06:58 PM
    08-29-2011 09:08 PM Go to last post
  7. Angry Wal-mart bleach $ increase
    Don't know if the same everywhere but our local Wally World just raised the price of the big jugs (182 oz) great value 6% bleach from $2.54 to $2.98....
    Started by oldkingcole‎, 08-12-2011 04:05 AM
    bleach cost, sticky
    08-27-2011 01:20 PM Go to last post
  8. Going back to Freshwater
    Just wondering, how hard or what should I be aware of if I converter from Saltwater back to semi freshwater? My SW Cell needs replacement and I...
    Started by stuckpipe‎, 07-30-2011 06:13 PM
    08-25-2011 01:12 PM Go to last post
  9. SWG and Heaters
    I have a Rome Electric Heater. I am going to sell it and go Solar. I also am planning a SWG. I believe my Rome is copper and not Titanium. In...
    Started by les_garten‎, 08-21-2011 10:45 AM
    08-21-2011 10:45 AM Go to last post
  10. CYA level and chlorine level and pool store recomendation
    Hi and thanks for a great forum. I sure am lucky to have found it as I am a new pool owner and knew nothing at all about pools and water chemistry...
    Started by Fishcrazy‎, 08-07-2011 08:32 AM
    4 Pages
    1 2 3 ... 4
    08-21-2011 10:25 AM Go to last post
  11. Wink Thank you!
    This forum is awesome! I am a former "pool store" employee but found that the way I was taught was not working - my pool was green, sad since I...
    Started by melissa‎, 08-20-2011 05:23 PM
    08-20-2011 08:12 PM Go to last post
  12. Need and experts help, my pool can't hold chlorine.
    I opened my pool in May and shortly after had a problem with goopy green algae. When that was resolved we took apart the filter and cleaned it...
    Started by redlady‎, 08-17-2011 04:34 PM
    08-18-2011 08:51 PM Go to last post
  13. Normal Chlorine Usage?
    I've read most of the similar posts on what is normal chlorine usage. Still haven't seen a straight answer as to what is "normal". I know every pool...
    Started by Labpool‎, 08-14-2011 08:06 PM
    08-15-2011 05:12 PM Go to last post
  14. Mixing pool chemicals
    I have had my pool for 23 years and it has been a struggle keeping a clean balanced pool. This year using bleach and the Taylor test kit, it has...
    Started by nepsa‎, 08-14-2011 09:16 PM
    08-15-2011 11:34 AM Go to last post
  15. high Chlorine usage
    1981 15,500 gal fiberglass in ground (11x32 8ft deep 3.5 ft shallow) with a sand filter. Location: HOT Arizona Desert water is crystal clear (I...
    Started by oldkingcole‎, 08-11-2011 04:33 PM
    08-13-2011 12:51 AM Go to last post
  16. Bleach
    I am trying to use household bleach to super chlronate my pool because of a terrible green algae outbreak. My problem is that after I balance my pool...
    Started by poser‎, 08-06-2011 07:00 PM
    2 Pages
    1 2
    08-09-2011 07:54 PM Go to last post
  17. Chlorine shock raising PH level
    I am just wondering approxiamately how much a 1 lb bag of Chlorine Shock will raise a pools Ph level. I know a bag of shock has a ph of around 11. ...
    Started by Pipecrew‎, 08-08-2011 09:36 PM
    08-08-2011 10:57 PM Go to last post
  18. Sudden cloudiness
    I went in the pool last night and it was perfect, I had a mask on and I could see from one end of the pool to the other, clear as day. The filter...
    Started by Barry J‎, 07-24-2011 05:21 PM
    4 Pages
    1 2 3 ... 4
    08-08-2011 08:50 AM Go to last post
  19. The use of Lithium Shock
    Hello, I have an inground 18 x 36 vinyl pool; 24,000 gallon. I use Lithium shock (3 lbs.) weekly and it works great. However it is very...
    Started by goldslinger‎, 07-25-2011 03:42 PM
    3 Pages
    1 2 3
    08-06-2011 01:30 PM Go to last post
  20. New Pool-Starting the chemical regimen
    HI there, first pool and first post on the forum. I have a 21' round dough boy (approx. 10,000 gal) pool. Just setup and filled yesterday. I've got a...
    Started by Labpool‎, 08-05-2011 03:30 PM
    08-06-2011 11:26 AM Go to last post
  21. bleach clouding water?
    I was just wondering if anyone would know why my pool turned cloudy on Saturday when I added two 3/4 gallons of 6% bleach to my water. I watched it...
    Started by mbar‎, 08-01-2011 03:54 PM
    2 Pages
    1 2
    08-05-2011 06:02 PM Go to last post
  22. Using Bleach
    Hello, I am new to the fourm and have found alot of great information. Thank you everyone. I have a question about using Liquid shock 12% or ...
    Started by familyfun‎, 08-03-2011 11:58 AM
    08-03-2011 09:43 PM Go to last post
  23. cya low, alk a little high, ph keeps rising
    I am back with new questions...26,000 gals. gunite. I have not been able to afford the really good test kit yet so i have the dealer test for cya. I...
    Started by hkcon‎, 07-29-2011 11:33 PM
    07-31-2011 03:58 PM Go to last post
  24. cost
    lets say I get 6% bleach at $2.50 for the 182oz bottle I can get a 40lb bucket of tri-chlor whatever is is at Costco for $90 (85% cl) I can get a...
    Started by sunofthebeach‎, 05-31-2011 11:17 PM
    2 Pages
    1 2
    07-30-2011 10:42 PM Go to last post
  25. Help! Our new 30ft. above ground pool will be full tonight. What next?
    We have never had a pool before and I would like to do it right, especially since my husband has put me in charge of this project. This site helped...
    Started by Scarfie‎, 07-28-2011 10:25 PM
    07-30-2011 05:49 AM Go to last post
  26. Be aware of 101 bleach
    After all the great help here i got things figured out. Then I saw Wal mart got some new bleach in. .87 3qt 101 bleach. Been using it for 2 weeks...
    Started by shub_31‎, 07-29-2011 06:54 PM
    07-29-2011 06:54 PM Go to last post
  27. Unhappy Please help with chlorine calculation?
    I have an 8ft pool that hold 2300 litres of water. I bought the chlorine granules but not quite sure how much to use and how often. Looked online...
    Started by Teggo65‎, 07-29-2011 04:47 AM
    07-29-2011 11:39 AM Go to last post
  28. Going on Vacation - how to maintain CL level?
    Been using bleach as need about every other day. but going away for a week and not sure how to maintain my CL level. I do not have a chlorinator,...
    Started by herb396‎, 07-28-2011 09:49 PM
    07-28-2011 11:28 PM Go to last post
  29. How often should I be adding bleach?
    I just switched from baquacil this spring and started out with chlorine tablets until I ran onto the site about using bleach. I'm new to chorine and...
    Started by Charles‎, 07-26-2011 11:56 PM
    07-27-2011 12:45 PM Go to last post
  30. Post chlorine disapearing
    last week I had no chlorine even though been adding ,having to scrub at algea patches everday.My ph is low I have 4 pucks in the skimmer 6 in an...
    Started by vinper‎, 06-14-2011 12:25 PM
    4 Pages
    1 2 3 ... 4
    07-26-2011 09:52 PM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
