+ Post New Thread
Page 5 of 49 FirstFirst ... 3 4 5 6 7 15 ... LastLast
Threads 121 to 150 of 1454
Forum: Using Chlorine and Chlorinating Chemicals
Bleach, cal-hypo, trichlor, dichlor, shock and STABILIZER: when, where & how.
  1. Sticky Thread Sticky: FAQs & Guides: Chlorine & Chlorinating Chemicals
    ______________________________________ FAQs & Guides: Chlorine & Chlorinating Chemicals ______________________________________ Pool...
    Started by PoolDoc‎, 06-02-2018 02:00 PM
    06-02-2018 02:00 PM Go to last post
  2. Sticky Thread Sticky: What's the BBB method?
    The BBB page has been expanded, and moved to the-BBB-method-of-swimming-pool-care.html Ben / PoolDoc
    Started by PoolDoc‎, 03-25-2011 09:16 PM
    03-25-2011 09:16 PM Go to last post
  1. chlorine level in attached spa
    My in-ground pool has an attached spa with a spillover (not sure if that's the right word) cut into the wall between spa and pool, so water can flow...
    Started by johninmartinez‎, 08-03-2013 04:01 PM
    08-04-2013 08:43 PM Go to last post
  2. vacation chlorinating
    Ever since I first became educated through this site I've been using bleach in my above ground pool. The problem is that when I leave town for a few...
    Started by rbossert‎, 08-04-2013 12:02 PM
    08-04-2013 03:50 PM Go to last post
  3. Shock with sodium hypochlorite
    I stopped using calcium hypochlorite to shock due to the sediment it left in my pool. I've used store bought bleach (8.25%) one time and it took...
    Started by dgcpe‎, 08-01-2013 08:21 PM
    08-03-2013 10:26 PM Go to last post
  4. Converting from 3" pucks to bleach
    Hi all, Due to our CYA count going through the roof, we've switched over from 3" pucks to bleach. Have my Taylor kit we've been using for over a...
    Started by Enterline‎, 07-30-2013 05:51 PM
    07-30-2013 11:39 PM Go to last post
  5. DIFFERENCE IN 12% and 8.25
    Ok I am adhering to everything on this site, but one question I am buying 8.25 bleach from WM to bump and 12% from pool store. Now, WM for 3.00 is...
    Started by dansdad‎, 07-29-2013 04:09 PM
    07-29-2013 06:28 PM Go to last post
  6. Using tablets as a supplement for granular?
    Hi. I have a 40k gallon, in-ground pool with vinyl siding and a DE filter. I usually add 6 to 12 grams of granular chlorine daily, depending on...
    Started by Racker‎, 07-10-2013 05:15 PM
    3 Pages
    1 2 3
    07-25-2013 08:40 PM Go to last post
  7. Very Low Free Chlorine Level.
    I have a 9400 gallon rectangular in-ground pool with color plaster surface. I am trying to balance the water in the pool. Everything works fine...
    Started by jytchu‎, 07-24-2013 01:06 AM
    07-24-2013 03:32 PM Go to last post
  8. taking charge of my pool
    I am in the process of taking over the upkeep and basic maintenance of my pool as the cost of having a outside pool company is becoming very...
    Started by jtmears‎, 07-12-2013 10:17 AM
    07-23-2013 10:54 AM Go to last post
  9. Liquid chlorine or bleach will destroy pool liner and equipment
    My pool installer is telling me that I should never use liquid chlorine or bleach in the pool. He said that he has had to replace several above...
    Started by corymunson‎, 06-24-2013 03:56 PM
    07-19-2013 08:19 PM Go to last post
  10. Soon to be pool owner checking in...
    Hello everyone! We just bought a 12x20 IG Vinyl pool which is scheduled for installation on 7/29 (2ft bury). After browsing this forum, it seems...
    Started by VladSI‎, 07-17-2013 01:59 PM
    2 Pages
    1 2
    a-links
    07-18-2013 01:18 PM Go to last post
  11. CYA increasing faster than possible...
    Before replacing the water in my pool: tested cya at 0 after opening (water didn't turn cloudy at all). Attempted to treat pool for ammonia/nitrates...
    Started by Themadczar‎, 07-09-2013 08:24 PM
    07-15-2013 12:09 AM Go to last post
  12. Switching from Sustain Cal-Hypo to BBB
    This is my first year with a pool and the pool store talked me into the Sustain Cal-Hypo system. I purchased what was supposed to be enough for the...
    Started by amber‎, 07-09-2013 12:20 PM
    2 Pages
    1 2
    07-12-2013 08:29 AM Go to last post
  13. Unhappy What is "CC"?
    What is CC??
    Started by nottapooltech‎, 07-11-2013 11:45 AM
    combined chlorine, sticky, urea
    07-11-2013 03:09 PM Go to last post
  14. Going on vacation
    If I use bleach to chlorinate and my cya is 60, what is the recommended method when I know I won't be home to add the bleach each night? I have a...
    Started by Leehicks79‎, 07-11-2013 01:14 AM
    07-11-2013 12:46 PM Go to last post
  15. Feeback on HTH Chorinating Modules at Walmart
    I was looking for feedback on HTH Chorinating Modules available on walmart. I found the Dichlor recommended in this thread at Amazon, but it...
    Started by gnac8‎, 07-09-2013 03:30 PM
    07-09-2013 08:58 PM Go to last post
  16. clorox Triple Bleach
    its at HD in a 1 gal green bottle , cannot find anything about it on inernet what % is it?
    Started by vinper‎, 06-20-2013 02:10 PM
    07-09-2013 04:01 PM Go to last post
  17. Bulk chlorine Houston Tx
    why cant I find it? looking for 15 gallon deldrums of 10-12% or even 5 gallon carboys . Houston biggest chem. city in nation , I see it avalible all...
    Started by vinper‎, 06-19-2013 10:39 AM
    07-09-2013 03:54 PM Go to last post
  18. Is 10 ppm chlorine too high?
    I have a 16x48 vinyl intex pool, the free chlorine is testing at 10ppm. Is this too high? If so, does it need to be lowered and how? The ph and TA...
    Started by jt2918‎, 07-04-2013 11:14 PM
    07-04-2013 11:36 PM Go to last post
  19. just put up new pool
    hi sorry i know u get this a lot. and i want to say this site is awesome thx i just put up my new pool what is a 18X48 full it with well water....
    Started by Gibby‎, 06-19-2013 08:27 PM
    2 Pages
    1 2
    07-04-2013 12:28 AM Go to last post
  20. Adding CL with no circulation? Help!
    My pump motor is dying. Today it was giving off a burning smell so I shut it off. Since I'm using a SWCG, I'll need to manually add bleach until...
    Started by JimK‎, 06-20-2013 06:48 PM
    2 Pages
    1 2
    07-03-2013 10:59 PM Go to last post
  21. new and confused about using bleach in pools
    we just got an 18x9x52" intext above ground. its all set up except the sand in the filter(its out there and dad will do it tomorrow, I have a back...
    Started by stargazingmommy‎, 07-03-2013 01:53 AM
    07-03-2013 10:24 AM Go to last post
  22. How much chlorine loss is normal?
    I've been testing my water nightly ever since switching to bleach. I've noticed that it seems to me that I'm losing chlorine quickly. Maybe it's...
    Started by dubbedout‎, 06-25-2013 10:58 PM
    2 Pages
    1 2
    07-02-2013 08:51 PM Go to last post
  23. Thank You . . . for the BBB Method
    I don't have a question, just finally registered after years of stalking. I love this site and wanted to thank you all for making the site what it...
    Started by powerdan74‎, 06-26-2013 11:43 AM
    attaboy
    07-02-2013 05:45 PM Go to last post
  24. Benefit of high CYA and chlorine
    I have read several comments from "aylad" that say he runs his pool at high CYA levels (and presumably high chlorine as well). What's the advantage?...
    Started by nefretrameses‎, 06-30-2013 07:18 PM
    07-01-2013 08:11 AM Go to last post
  25. Why does stabilized CL test as fc instead of cc?
    This is just a curiosity question... If cya locks away some CL by "combining" with it, then why doesn't it test as combined chlorine like CL that is...
    Started by Themadczar‎, 06-28-2013 10:02 AM
    06-29-2013 09:10 PM Go to last post
  26. Higher chlorine use this year with BBB method
    using the BBB method and Im using about 3-4 quarts of bleach a day is this ok seems like I was using less last year when my CYA was high 7-10. this...
    Started by Mrbaadboy‎, 06-24-2013 02:58 PM
    06-27-2013 09:44 AM Go to last post
  27. When to test CYA?
    Finally got my cya to consistently test at 50. What is a good rule of thumb for testing for it from here on out?
    Started by Leehicks79‎, 06-25-2013 11:33 AM
    06-25-2013 12:01 PM Go to last post
  28. Difference in Water Analysis
    Have been using a fair amount of bleach on my pool especially with the rainy weather we have been having .Have to continue to pump out water ....
    Started by gfritz1‎, 06-13-2013 04:33 PM
    amz, culator
    06-24-2013 06:59 PM Go to last post
  29. Stabilizer help please......
    I had my pool water tested today and the CYA was low (20) so they told me to add some stabilizer through the skimmer which I have just done - I read...
    Started by maggie2712‎, 06-21-2013 06:54 PM
    06-23-2013 07:01 AM Go to last post
  30. Do these things work?
    I have an acquaintance who has one of these. http://www.zodiacpoolsystems.com/Products/Water-Sanitizers/Nature2-Express.aspx What do they do?
    Started by Bosch232‎, 06-21-2013 09:12 AM
    06-22-2013 11:19 AM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
