+ Post New Thread
Page 4 of 49 FirstFirst ... 2 3 4 5 6 14 ... LastLast
Threads 91 to 120 of 1454
Forum: Using Chlorine and Chlorinating Chemicals
Bleach, cal-hypo, trichlor, dichlor, shock and STABILIZER: when, where & how.
  1. Sticky Thread Sticky: FAQs & Guides: Chlorine & Chlorinating Chemicals
    ______________________________________ FAQs & Guides: Chlorine & Chlorinating Chemicals ______________________________________ Pool...
    Started by PoolDoc‎, 06-02-2018 02:00 PM
    06-02-2018 02:00 PM Go to last post
  2. Sticky Thread Sticky: What's the BBB method?
    The BBB page has been expanded, and moved to the-BBB-method-of-swimming-pool-care.html Ben / PoolDoc
    Started by PoolDoc‎, 03-25-2011 09:16 PM
    03-25-2011 09:16 PM Go to last post
  1. Dichlor / Trichlor & CYA (and an oddity)
    Planning to open on Saturday and pulled a water sample for testing (two actually yesterday & today). The pool has been closed since September and my...
    Started by dgcpe‎, 05-22-2014 07:17 PM
    05-22-2014 08:51 PM Go to last post
  2. I've read through a bunch of posts
    Here's my situation. My skimmer line has a small leak so my vacuum doesn't suck like it should. Then add in the bottom drain, I assume has a leak...
    Started by DonDon1145‎, 05-20-2014 12:00 PM
    05-21-2014 12:48 PM Go to last post
  3. Calcium and sodium question
    I noticed bleach is sodium hypochlorite, my chlorine is calcium..any difference
    Started by dansdad‎, 05-16-2014 02:38 PM
    2 Pages
    1 2
    05-18-2014 01:44 PM Go to last post
  4. Calcium and sodium
    I noticed that not mixing calcium hypo to anything. If I use a granular cal hypo 73% and I would normally sanitize with bleach which is sodium hypo...
    Started by dansdad‎, 05-16-2014 02:47 PM
    05-16-2014 11:05 PM Go to last post
  5. CYA levels
    I just emptied and refilled my 25k Pebble tec pool a few months ago because the CYA levels were so high. Once the pool was filled I used 2 gallons...
    Started by dubbedout‎, 06-11-2013 05:47 PM
    4 Pages
    1 2 3 ... 4
    05-09-2014 03:45 PM Go to last post
  6. New to BBB method
    Hello all, I am new to this forum and the BBB method, but really like what I am reading here. This is the first spring with our new above ground...
    Started by Slachey‎, 04-15-2014 11:52 AM
    2 Pages
    1 2
    05-04-2014 11:05 AM Go to last post
  7. Chlorination using Cal Hypo Shock only
    As an alternative to using tablet containing CYA and experiencing a buildup which, according to the local pool store personnel, is only resolved with...
    Started by schmitty1223‎, 05-01-2014 05:08 PM
    05-02-2014 03:21 PM Go to last post
  8. Increasing CYA
    Did a resurface of the pool, so the pool has 0 (zero) CYA. Should we add CYA? Or do we just use shock until the CYA level start coming up? ...
    Started by Jujube‎, 04-28-2014 04:31 PM
    04-29-2014 10:53 PM Go to last post
  9. Alternative to using chlorine
    Is there any alternatives to using chlorine. I would rather keep from using it if possible in my Above ground. I''ll be running a DE filter is that...
    Started by rdefino‎, 03-16-2014 08:19 PM
    04-29-2014 06:46 PM Go to last post
  10. Great deal on chlorine
    Not sure if it's local or national, but Menards has 12.5% pool chlorine on sale... Buy one gallon at $3.99 get one free. Sale is until early-mid May...
    Started by Themadczar‎, 04-27-2014 11:17 AM
    04-27-2014 12:10 PM Go to last post
  11. cya & chlorine levels
    First year not using easy pool. Trying to understand how to calculate cya levels to know how much chlorine to add. Bought the taylor kit so it says...
    Started by newgirl‎, 04-17-2014 07:41 PM
    04-23-2014 08:53 PM Go to last post
  12. Tabs or No Tabs
    Is it OK for me to totally ditch the 3" tabs in the chlorinator, or do they have their place in maintaining chlorine levels without having to add...
    Started by johnway2‎, 04-09-2014 08:10 PM
    04-09-2014 08:44 PM Go to last post
  13. I Like The Smell
    Okay, this might be a little weird, but while I am planning on redirecting my approach to working my pool chemistry, I wonder if the pool will...
    Started by Tom.B‎, 03-30-2014 10:18 PM
    04-03-2014 06:49 AM Go to last post
  14. High CYA + high chlorine pool
    We are relatively new pool owners! In ground, 24,000 gal, DE filter, non heated pool. We use Chlorox and muratic acid and pretty much nothing else...
    Started by mkberg‎, 03-28-2014 01:52 PM
    03-28-2014 04:25 PM Go to last post
  15. How does high CYA affect chlorine use?
    does a high cya level us up chlorine faster thanks
    Started by clayton2000‎, 03-26-2014 05:13 PM
    03-27-2014 03:31 PM Go to last post
  16. Clorox shock
    How much chlorox to shock a 20x40, 28,000 gal., in-ground? What are the advantages of chlorox over cal hypo?
    Started by Rickmart‎, 03-16-2014 11:33 AM
    03-16-2014 05:34 PM Go to last post
  17. Liquid Chlorine (Bleach) concentration or lack thereof...
    I need some advise as I think my local pool store is trying to swindle me. My 10,000 gallon in ground salt water vinyl pool started to turn slightly...
    Started by Isailer‎, 02-12-2014 09:34 AM
    03-07-2014 12:31 PM Go to last post
  18. swithing from cal hypo to bleach????
    how long do you have to wait to start using bleach if you have just sanitized with cal hypo? days or just until your chlorine level goes down. ...
    Started by mspool‎, 05-11-2006 07:06 PM
    12-31-2013 12:08 PM Go to last post
  19. *** Hayward Chlorine Feeder Help ***
    I am a newbie pool owner, so I am not familiar with the pool equipment yet. I bought a Hayward Chlorine Feeder (CL220 Off-Line Automatic), but I...
    Started by poolg‎, 10-27-2013 01:53 AM
    2 Pages
    1 2
    amz2fix
    11-22-2013 06:26 PM Go to last post
  20. dichlor and trichlor adulteration How to know
    Hi, i have been trying to save a couple of dollars in my dichlor purchasings and i happen to find stores where dichlor ios sold at very competitive...
    Started by javox‎, 10-12-2013 05:27 PM
    sticky
    10-13-2013 06:30 AM Go to last post
  21. FC/CYA/Temperature relationship?
    Florida. I have learned that my pool needs FC to be about 10% of CYA in summer to keep algae away. (FC=7 when CYA=70). If FC drops to 5 for even a...
    Started by nefretrameses‎, 10-10-2013 05:44 PM
    10-10-2013 09:07 PM Go to last post
  22. Swimming pool chemicals prices
    I have a 26,000 gallon IGP. I see on here recommendations for borax 20 mule team instead of expensive ph up which I use a lot of. i have been...
    Started by apearso‎, 08-23-2013 09:36 AM
    09-02-2013 02:37 PM Go to last post
  23. How long to wait before re-test
    After adding liquid bleach, how long should I wait in order to get an accurate re-test? I have a small algae bloom, so raised the cl to shock...
    Started by billp‎, 08-29-2013 05:27 PM
    08-30-2013 10:34 PM Go to last post
  24. Can plain household bleach be used as a swimming pool sanitizer
    Hello, This is my first post to this forum. Can household bleach containing NO additives be used as a sanitizer? Is sodium hypochlorite used in...
    Started by stevenh496‎, 08-24-2013 09:17 AM
    bleach decomposition, fixed-pix, sticky
    08-27-2013 02:13 PM Go to last post
  25. Lithium Hypochlorite question
    In reading in the booklet that came with my Taylor test kit, it's claimed that lithium hypochlorite is the "Cadillac" of pool shocks, along with the...
    Started by TORQUED455‎, 08-17-2013 12:01 PM
    08-18-2013 04:18 PM Go to last post
  26. chlorine and solar covers
    Will keeping my solar cover on help preserve the chlorine in the water? just curious.
    Started by Bosch232‎, 06-12-2013 12:18 PM
    08-17-2013 01:19 AM Go to last post
  27. Shelf life of bleach and test kit question
    I seem to remember reading somewhere on the forum about bleach having a limited shelf life. How long can bleach sit before its effectiveness is...
    Started by giffman‎, 08-05-2013 10:47 PM
    08-10-2013 11:11 PM Go to last post
  28. Red face Thinking about bleach...
    Hello all. I recently took a 25k gallon pool under my wing. Things have been pleasant so far, no algae, water stays clear, no CC's that I can...
    Started by trainwrecked‎, 07-28-2013 09:21 AM
    pool-stored
    08-06-2013 09:33 PM Go to last post
  29. small algae blooms
    I've been getting small algae blooms on various places in my pool. i brush them off and they disappear in the water. The water is very clear. They...
    Started by 392papa‎, 08-04-2013 04:27 PM
    2 Pages
    1 2
    algae, biofilm, polaris, sticky
    08-05-2013 08:00 PM Go to last post
  30. Pool is Eating Chlorine - CLOSED THREAD
    I have a pool, it has a lot of dead algae on the bottom which I haven't vacuumed and its eating chlorine but I can't figure out why. Here is a...
    Started by DDawgCleaningPools‎, 08-05-2013 09:12 AM
    08-05-2013 11:44 AM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
