+ Post New Thread
Page 6 of 49 FirstFirst ... 4 5 6 7 8 16 ... LastLast
Threads 151 to 180 of 1454
Forum: Using Chlorine and Chlorinating Chemicals
Bleach, cal-hypo, trichlor, dichlor, shock and STABILIZER: when, where & how.
  1. Sticky Thread Sticky: FAQs & Guides: Chlorine & Chlorinating Chemicals
    ______________________________________ FAQs & Guides: Chlorine & Chlorinating Chemicals ______________________________________ Pool...
    Started by PoolDoc‎, 06-02-2018 02:00 PM
    06-02-2018 02:00 PM Go to last post
  2. Sticky Thread Sticky: What's the BBB method?
    The BBB page has been expanded, and moved to the-BBB-method-of-swimming-pool-care.html Ben / PoolDoc
    Started by PoolDoc‎, 03-25-2011 09:16 PM
    03-25-2011 09:16 PM Go to last post
  1. New here! Would appreciate some help
    Hi all, glad to be part of the "revolution!" Unfortunately, I was "pool stored" prior to finding this forum. I did an initial superchlorination 2...
    Started by rexmobile‎, 06-19-2013 10:20 PM
    06-21-2013 10:16 PM Go to last post
  2. hasa liquidator
    thinking about going this route , who uses one. and are you happy with it? or is there a simpler better way
    Started by vinper‎, 06-14-2013 12:31 PM
    06-18-2013 10:35 AM Go to last post
  3. Kiddie Pool Chemicals
    We have a larger kiddie pool and want to try and keep it set up for more than a day with out algae and yuckiness. We may follow some of the...
    Started by ercvt‎, 06-15-2013 09:31 PM
    06-17-2013 02:45 PM Go to last post
  4. is bleach really cheaper?
    I read on one of the guides or tips that one gallon of 6% bleach is comparable to 3/4 lb. of Calcium Hypochlorite. I can get a 3.78 jug of 8.25%...
    Started by tfrailey‎, 06-09-2013 10:18 PM
    06-16-2013 11:39 AM Go to last post
  5. little bit of green
    I keep adding bleach every few days but I still getting some green algea drive my wife crazy . gonna add 3 bags chlor bright tonight over 24hrs...
    Started by vinper‎, 05-10-2013 03:08 PM
    06-14-2013 09:14 PM Go to last post
  6. Chlorine tabs vs chlorine bleach generic
    After reading Some of your posts I want to know if using chlorine in jugs from the store are better than using the pool store tablets?
    Started by Cahoonh‎, 06-09-2013 06:47 PM
    attaboy
    06-13-2013 09:28 AM Go to last post
  7. New guy to the pool forum
    Hello moderators! My name is K.C. and my family and I have just purchased and moved into an older home (30 yrs old). The home has a concrete...
    Started by USMC-DAV‎, 06-11-2013 11:09 AM
    06-13-2013 09:27 AM Go to last post
  8. Are my Levels OK?
    Pool running since Memorial Day. At that time FC and CC were .5 and TA was 80 with CYA 40.. Finally got CC 0 FC 3 but I'm putting in between 1 1/2...
    Started by mroll‎, 06-04-2013 07:42 PM
    06-12-2013 11:21 PM Go to last post
  9. Liners
    I recently had the liner replaced in my 19,000 gal inground pool. The old one had lasted 10 yrs. For the last 9 yrs, I only used Clorox bleach for...
    Started by Ziggy‎, 06-11-2013 11:24 PM
    06-12-2013 12:54 PM Go to last post
  10. Sam's Wholesale Chlorine
    Anyone have any experience with this stuff? I use about 120lbs through out the year.....looking to save a few bucks, over Leslie's. ...
    Started by coj79‎, 03-15-2013 06:57 PM
    2 Pages
    1 2
    06-11-2013 07:54 PM Go to last post
  11. Chlorine/bleach in calculator
    Ok forgive me if I ask stupid questions...maybe someone else needs an answer too but I'm going to be a genius at this BBB method no matter what. Now...
    Started by dansdad‎, 06-09-2013 12:31 PM
    06-09-2013 09:03 PM Go to last post
  12. Testing cheap bleach
    Wife bought bleach from the dollar store, just says sodium hypochlorite on the label but not percentage. What is the proper way to test to see the...
    Started by dansdad‎, 06-07-2013 08:35 PM
    06-09-2013 08:04 AM Go to last post
  13. CYA test
    Just put in new liner so total refill(26,000 gal) added bleach until it was in range next I added 4 CHLOR-GUARD pucks (1 per 5000 gal) still some of...
    Started by not2high2fly‎, 06-08-2013 05:52 AM
    06-08-2013 07:53 AM Go to last post
  14. BBB/Black liner
    Just put a new black liner in my 16x36 8' deep end inground. Is it ok to add the CL(bleach) into the skimmer? I don't want a bleach stain from a...
    Started by not2high2fly‎, 06-06-2013 11:38 AM
    06-07-2013 05:04 PM Go to last post
  15. 10% sodium hyperchlorite
    Is 10% sodium hyperchlorite ok or does it need to be 12
    Started by dansdad‎, 06-04-2013 07:23 PM
    06-07-2013 03:17 PM Go to last post
  16. Clueless...
    These are my chlorine levels and actions over the last couple of weeks... can anyone make sense of this? Date - Time - ...
    Started by Themadczar‎, 06-05-2013 11:24 PM
    06-07-2013 11:01 AM Go to last post
  17. Percentage sodium hypochlorite?
    Silly me picked up some reasonably priced Giant Grocery brand bleach and thought the percentage sodium hypochlorite was on the inside of the...
    Started by Mindiv‎, 06-02-2013 09:40 PM
    06-06-2013 03:31 PM Go to last post
  18. Question Chemistry question
    If I took 10 oz. of 67% trichloro ( available chlorine 60.3%) other ingredients 33% how many gallons of bleach could I use. my bleach at home...
    Started by dansdad‎, 06-05-2013 12:21 PM
    06-05-2013 09:25 PM Go to last post
  19. Questions
    Last year with a chlorine block issue the Forum worked me through it and since have been on the BBB method or at least I think . I have only been...
    Started by gfritz1‎, 06-01-2013 06:33 PM
    06-04-2013 04:26 PM Go to last post
  20. Opened for first time with old loop loc mesh cover green swamp
    Hi My first time using this pool. (18x36 vinyl) The cover is worn heavily, green pieces of the mesh are still in the pool and stuck in the filter...
    Started by Gretzky99‎, 05-29-2013 09:38 PM
    2 Pages
    1 2
    06-04-2013 09:01 AM Go to last post
  21. new member from ohio
    Thanks for all the great info. Found your site just this evening after wondering why my chlorine was getting 'eaten' up so fast. Forgot I added new...
    Started by cincyrick‎, 06-02-2013 01:42 AM
    06-03-2013 02:50 PM Go to last post
  22. Unhappy Will I have to shock daily to get rid of algae?
    My pool was left uncovered all winter and looked like a swamp, frogs and all. I've vacuumed, scooped and even used a leaf eater. So now my ph is 7.6...
    Started by duffmama‎, 06-01-2013 11:27 PM
    06-02-2013 01:37 PM Go to last post
  23. Switching from SWCG to liquid Chlorine.
    As I currently spend between 15-20 minutes a day in cleaning my salt gen cell I was thinking maybe I could save time and aggro by turning it off and...
    Started by poolaris‎, 05-09-2013 04:38 PM
    2 Pages
    1 2
    05-31-2013 03:24 AM Go to last post
  24. Pool opening - 2013
    Hello again! This will be my second year here. We opened the pool to lots of algae. My husband dumped in a ton of chlorine and about a week later,...
    Started by ajb8898‎, 05-04-2013 02:58 PM
    2 Pages
    1 2
    05-30-2013 10:31 PM Go to last post
  25. not sure where to put- vacation WTD
    Feel free to move if this is the wrong forum. We just opened our pool in Upstate NY. Water was crystal clear (thanks poolforum for all your help...
    Started by fiveUNDERfive‎, 05-29-2013 05:56 PM
    05-30-2013 12:51 PM Go to last post
  26. How much liquid chlorine to shock pool
    Hi. I have an 18 x 38 vinyl liner pool. About 31000 gallons. Hayward sand filter and heat pump. Opened the pool yesterday. Cloudy but blue. Using the...
    Started by ghostcat‎, 05-28-2013 08:15 AM
    05-28-2013 11:45 AM Go to last post
  27. New Homeowner, a few questions
    I bought my first house in September. The previous owners closed the pool prior to selling. I opening it last week and am struggling to learn...
    Started by videotonyk‎, 05-21-2013 05:40 PM
    05-27-2013 05:22 PM Go to last post
  28. 6% household bleach equivalent to lithium hypochoride granular?
    What volume of bleach would be equivalent to one (1) pound of lithium hypo granular "shock"?
    Started by magnus‎, 05-23-2013 10:04 AM
    05-24-2013 09:51 AM Go to last post
  29. Need help with my Free Chlorine
    Hello...I am new the pool game and boy is it kicking my butt right now! I just bought a house with a 24x14 above groud oval pool that is 4 feet deep....
    Started by videotonyk‎, 05-22-2013 09:32 PM
    05-23-2013 08:45 AM Go to last post
  30. Calcium Hypochlorite doesn't fully dissolve
    Whenever I use calcuim hypochlorite shock i get a fine sediment on the bottom of my pool that does not get trapped in the filter. I vacuum and its...
    Started by dgcpe‎, 05-22-2013 01:15 PM
    05-23-2013 12:43 AM Go to last post
+ Post New Thread
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
